adron2 Posted June 13, 2009 Posted June 13, 2009 Привет всем. Есть сервак: 00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 02) 00:02.0 VGA compatible controller: Intel Corporation 82G33/G31 Express Integrated Graphics Controller (rev 02) 00:03.0 Communication controller: Intel Corporation 82G33/G31/P35/P31 Express MEI Controller (rev 02) 00:19.0 Ethernet controller: Intel Corporation 82566DC-2 Gigabit Network Connection (rev 02) 00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02) 00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02) 00:1a.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 02) 00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02) 00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02) 00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02) 00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 02) 00:1c.2 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 3 (rev 02) 00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 02) 00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 02) 00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02) 00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02) 00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02) 00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02) 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92) 00:1f.0 ISA bridge: Intel Corporation 82801IH (ICH9DH) LPC Interface Controller (rev 02) 00:1f.2 SATA controller: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA AHCI Controller (rev 02) 00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02) 02:00.0 IDE interface: Marvell Technology Group Ltd. 88SE6101 single-port PATA133 interface (rev b2) 06:00.0 Ethernet controller: Intel Corporation 82541PI Gigabit Ethernet Controller (rev 05) 06:01.0 Ethernet controller: Intel Corporation 82541PI Gigabit Ethernet Controller (rev 05) 06:03.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22/A IEEE-1394a-2000 Controller (PHY/Link) ............................... 4 ядра. Это 4 -е. processor : 3 vendor_id : GenuineIntel cpu family : 6 model : 15 model name : Intel® Core2 Quad CPU Q6600 @ 2.40GHz stepping : 11 cpu MHz : 2400.187 cache size : 4096 KB physical id : 0 siblings : 4 core id : 3 cpu cores : 4 fdiv_bug : no hlt_bug : no f00f_bug : no coma_bug : no fpu : yes fpu_exception : yes cpuid level : 10 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx lm constant_tsc arch_perfmon pebs bts pni monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr lahf_lm bogomips : 4800.54 clflush size : 64 core1-sf:/# cat /proc/meminfo MemTotal: 2048072 kB MemFree: 696900 kB Buffers: 27396 kB Cached: 188836 kB SwapCached: 112 kB Active: 289324 kB Inactive: 200840 kB HighTotal: 1150964 kB HighFree: 681164 kB LowTotal: 897108 kB LowFree: 15736 kB SwapTotal: 3903752 kB SwapFree: 3903580 kB Dirty: 144 kB Writeback: 0 kB AnonPages: 273976 kB Mapped: 9044 kB Slab: 842244 kB SReclaimable: 9040 kB SUnreclaim: 833204 kB PageTables: 1088 kB NFS_Unstable: 0 kB Bounce: 0 kB CommitLimit: 4927788 kB Committed_AS: 659816 kB VmallocTotal: 114680 kB VmallocUsed: 7364 kB VmallocChunk: 106372 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 4096 kB eth2 Link encap:Ethernet HWaddr 00:1B:21:09:A6:1B inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1082343732 errors:25 dropped:55662030 overruns:0 frame:20 TX packets:999065892 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:2389107889 (2.2 GiB) TX bytes:3714315536 (3.4 GiB) Base address:0x1000 Memory:90020000-90040000 Так вот на eth2 нагрузка 150-200 мегабит на вход и 100 Мегабит на выход. И соответственно 30000-50000 pps На вход и 20000-30000 pps на выход. Как видно из кода крутится счетчик на интерфейсе(dropped). Сетевуха воткнута в свитч zyxel dimension 2024a. Сетевуха воткнута в гиговый порт этого свитча. Свитч ошибок не показывает на этом интерфейсе. Нагрузка на всех ядрах сервака не более 30 %. NAPI работает. В фаерволе около 1200 правил. Патчкорд длиной 5 метров. Вчера его заменил на экранированный кабель и заземлил. Ошибки все равно идут. Причем спонтанно. То по 50-200 в секунду то вообще не одной в течении 10 минут. Куда копать? Вставить ник Quote
nuclearcat Posted June 13, 2009 Posted June 13, 2009 Покажите ethtool -S eth2;ethtool eth2 Вставить ник Quote
adron2 Posted June 13, 2009 Author Posted June 13, 2009 Покажите ethtool -S eth2;ethtool eth2 ethtool -S eth2 NIC statistics: rx_packets: 74726387521 tx_packets: 65939805932 rx_bytes: 54849503950651 tx_bytes: 36361684495804 rx_broadcast: 2396184 tx_broadcast: 1864791 rx_multicast: 12814991 tx_multicast: 10908951 rx_errors: 5 tx_errors: 0 tx_dropped: 0 multicast: 12814991 collisions: 0 rx_length_errors: 13 rx_over_errors: 0 rx_crc_errors: 7 rx_frame_errors: 0 rx_no_buffer_count: 783807880 rx_missed_errors: 55667651 tx_aborted_errors: 0 tx_carrier_errors: 0 tx_fifo_errors: 0 tx_heartbeat_errors: 0 tx_window_errors: 0 tx_abort_late_coll: 0 tx_deferred_ok: 1113942 tx_single_coll_ok: 0 tx_multi_coll_ok: 0 tx_timeout_count: 2 tx_restart_queue: 42759842 rx_long_length_errors: 13 rx_short_length_errors: 0 rx_align_errors: 0 tx_tcp_seg_good: 0 tx_tcp_seg_failed: 0 rx_flow_control_xon: 1115116 rx_flow_control_xoff: 1116625 tx_flow_control_xon: 1066817116 tx_flow_control_xoff: 1139109330 rx_long_byte_count: 54849503950651 rx_csum_offload_good: 73895502749 rx_csum_offload_errors: 5709834 rx_header_split: 0 alloc_rx_buff_failed: 0 tx_smbus: 0 rx_smbus: 0 dropped_smbus: 0 ethtool eth2 Settings for eth2: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: Twisted Pair PHYAD: 0 Transceiver: internal Auto-negotiation: on Supports Wake-on: umbg Wake-on: g Current message level: 0x00000007 (7) Link detected: yes Вставить ник Quote
adron2 Posted June 13, 2009 Author Posted June 13, 2009 (edited) попробую сам ответить. ifconfig eth2 eth2 Link encap:Ethernet HWaddr 00:1B:21:09:A6:1B inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1802102316 errors:25 dropped:55668167 overruns:0 frame:20 TX packets:1589396076 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:1061946540 (1012.7 MiB) TX bytes:498181945 (475.1 MiB) Base address:0x1000 Memory:90020000-90040000 Обращаем внимание на dropped:55668167 а потом на rx_missed_errors: 55667651 Почти одинаково. А потом читаем http://forum.nag.ru/forum/index.php?showto...46335&st=60. И там: в e1000e можно этим параметром управлять динамически через ethtool -cА можно подробенее? Может кто-нибудь знает нормальную доку про ethtool? rx_missed_errors: 12471649 tx_deferred_ok: 4302243 tx_restart_queue: 1780921 tx_tcp_seg_good: 3654 rx_flow_control_xon: 4372530 rx_flow_control_xoff: 4367738 tx_flow_control_xon: 436942 tx_flow_control_xoff: 447152 rx_long_byte_count: 2801363193093 rx_csum_offload_good: 3014004698 rx_csum_offload_errors: 791 Это хорошо или плохо? Нигде не могу найти нормального описания значений. Стоит ли включать/выключать flow control? rx_missed_errors: 12471649Очень плохо. Но в зависимости от общего количества пакетов. Но все равно выглядит плохо. Говорит о том, что ваша железка не успевает переваривать пакеты. ethtool -g интерфейс покажите То есть как я понял мне нужно убирать iptables И переходить на ipset?Вот еще ethtool -g eth2 Ring parameters for eth2: Pre-set maximums: RX: 4096 RX Mini: 0 RX Jumbo: 0 TX: 4096 Current hardware settings: RX: 256 RX Mini: 0 RX Jumbo: 0 TX: 256 Edited June 13, 2009 by adron2 Вставить ник Quote
nuclearcat Posted June 14, 2009 Posted June 14, 2009 Попробуйте увеличить ring, ethtool -G Еще можно включить flow control (или выключить если включен) - но это не всегда хорошо и не всегда помогает. (ethtool -a / ethtool -A) Но если вкратце - система не держит нагрузку... а что уже причина - надо искать... прерывания разводить, систему профайлить... Вставить ник Quote
