weldpua2008 Posted May 28, 2009 Posted May 28, 2009 Вот как он PowerConnect 3424 загружается: Boot1 Checksum Test...............................PASS Boot2 Checksum Test...............................PASS Flash Image Validation Test.......................PASS BOOT Software Version 1.0.0.12 Built 04-Apr-2005 15:46:33 Carrier board, based on PPC8247 128 MByte SDRAM. I-Cache 16 KB. D-Cache 16 KB. Cache Enabled. Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom. Preparing to decompress... 100% Decompressing SW from image-1 f20000 OK Running from RAM... ********************************************************************* *** Running SW Ver. 1.0.1.13 Date 20-Feb-2006 Time 09:52:44 *** ********************************************************************* HW version is 00.00.01 Base Mac address is: 00:11:43:fb:84:8f Dram size is : 128M bytes Dram first block size is : 106496K bytes Dram first PTR is : 0x1800000 Flash size is: 16M 01-Jan-2000 01:01:04 %CDB-I-LOADCONFIG: Loading running configuration. 01-Jan-2000 01:01:04 %CDB-I-LOADCONFIG: Loading startup configuration. CPLD revision: 0. 1 Device configuration: ----------------------------------- -- Unit Number 5 Slave -- ----------------------------------- 01-Jan-2000 01:01:08 %INIT-I-InitCompleted: Initialization task is completed >? Unknown parameter May be one from the following list: debug help Вот перепрошивка: I have upgrade to PowerConnect_34XX-10113.ros but doesn't help: Startup Menu [1] Download Software [2] Erase Flash File [3] Password Recovery Procedure [4] Enter Diagnostic Mode [5] Set Terminal Baud-Rate Back Enter your choice or press 'ESC' to exit: Downloading code using XMODEM. -- Download complete -- Wrong file format. Writing aborted. Perform WARM BOOT ... Boot1 Checksum Test...............................PASS Boot2 Checksum Test...............................PASS Flash Image Validation Test.......................PASS BOOT Software Version 1.0.0.12 Built 04-Apr-2005 15:46:33 Carrier board, based on PPC8247 128 MByte SDRAM. I-Cache 16 KB. D-Cache 16 KB. Cache Enabled. Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom. Preparing to decompress... 100% Decompressing SW from image-1 f20000 OK Running from RAM... ********************************************************************* *** Running SW Ver. 1.0.1.13 Date 20-Feb-2006 Time 09:52:44 *** ********************************************************************* HW version is 00.00.01 Base Mac address is: 00:11:43:fb:84:8f Dram size is : 128M bytes Dram first block size is : 106496K bytes Dram first PTR is : 0x1800000 Flash size is: 16M 01-Jan-2000 01:01:04 %CDB-I-LOADCONFIG: Loading running configuration. 01-Jan-2000 01:01:04 %CDB-I-LOADCONFIG: Loading startup configuration. CPLD revision: 0. 1 Device configuration: ----------------------------------- -- Unit Number 5 Slave -- ----------------------------------- 01-Jan-2000 01:01:07 %INIT-I-InitCompleted: Initialization task is completed >? Unknown parameter May be one from the following list: debug help >en Unknown parameter May be one from the following list: debug help >enable Unknown parameter May be one from the following list: debug help > Вот содержимое: DEBUG>print files dir Name Type Size status RSCOD1 static 4224K exist RSCOD2 static 4224K exist SYSLOG1 static 256K exist SYSLOG2 static 256K exist CDB dynWithCopy 512K exist BACKUP1 dynWithoutCopy 512K not exist BACKUP2 dynWithoutCopy 512K not exist BACKUP3 dynWithoutCopy 512K not exist BACKUP4 dynWithoutCopy 512K not exist BACKUP5 dynWithoutCopy 512K not exist CLI dynWithCopy 256K not exist DHCPDB dynWithCopy 256K not exist SSHKEYS dynWithCopy 256K exist DIRECTRY dynWithCopy 256K exist AAAFILE dynWithCopy 128K exist обрящу внимание CLI dynWithCopy 256K not exist Вставить ник Quote
D^2 Posted May 29, 2009 Posted May 29, 2009 (edited) у Вас на коммутаторе есть service tag. звоните в ТП делла (495)9378357 - с помощью автоинформатора выбираете нужное направление. сообщаете сервис таг и Вам отвечают на любые вопросы. Edited May 29, 2009 by D^2 Вставить ник Quote
weldpua2008 Posted May 29, 2009 Author Posted May 29, 2009 у Вас на коммутаторе есть service tag. звоните в ТП делла (495)9378357 - с помощью автоинформатора выбираете нужное направление. сообщаете сервис таг и Вам отвечают на любые вопросы. тогда он выйдет намного дороже чем его купили (он же БУ)... Вставить ник Quote
D^2 Posted May 29, 2009 Posted May 29, 2009 там сервис таг не привязан к покупателю. только тсс =) Вставить ник Quote
weldpua2008 Posted May 29, 2009 Author Posted May 29, 2009 там сервис таг не привязан к покупателю. только тсс =)а если без звонков?По сервис тагу суппорт для свича "отсутствует" как сказано на Англ и Рус версии суппорт.делл Вставить ник Quote
weldpua2008 Posted May 31, 2009 Author Posted May 31, 2009 Что никто не сталкивался с такой хернёй? Вставить ник Quote
