Cramac Posted April 14, 2009 Posted April 14, 2009 (edited) Всем привет. Стоит сейчас vlc (0.8.6) из rpm Попытался собрать новый из исходников с поддержкой DVB но что то не пошло, при попытке запустить в логах: [00000616] inhibit interface error: Failed to connect to the D-Bus session daemon: Failed to execute dbus-launch to autolaunch D-Bus session [00000616] inhibit interface error: Failed to connect to the D-Bus session daemon: Failed to execute dbus-launch to autolaunch D-Bus session [00000616] main interface warning: no interface module matching "inhibit,none" could be loaded [00000616] main interface debug: TIMER module_Need() : 10,592 ms - Total 10,592 ms / 1 intvls (Avg 10,592 ms) [00000616] main interface error: no suitable interface module [00000001] main libvlc error: interface "inhibit,none" initialization failed [00000617] main interface debug: looking for interface module: 1 candidate [00000617] main interface debug: using interface module "screensaver" [00000617] main interface debug: TIMER module_Need() : 0,492 ms - Total 0,492 ms / 1 intvls (Avg 0,492 ms) [00000617] main interface debug: thread started [00000617] main interface debug: thread 3014708112 (interface) created at priority 0 (interface/interface.c:168) [00000617] screensaver interface warning: failed to connect to the D-BUS daemon: Failed to execute dbus-launch to autolaunch D-Bus session ...... access_directory access error: dvb:: Нет такого файла или каталога [00000622] access_file access debug: opening file `dvb:' [00000622] access_file access error: cannot open file dvb: (Нет такого файла или каталога) [00000622] cdda access warning: could not open dvb: [00000622] main access debug: TIMER module_Need() : 2,107 ms - Total 2,107 ms / 1 intvls (Avg 2,107 ms) [00000620] main input error: open of `dvb:' failed: could not create access: no suitable access module что делаю не так? конфигуре: ./configure --enable-dvb --disable-glx --disable-qt4 --disable-skins2 Или может кто знает как заставить vlc версии 0.8.6c Janus вещать больше 7 ТВ программ с 1 транспордера? Edited April 14, 2009 by Cramac Вставить ник Quote
Giga-Byte Posted April 15, 2009 Posted April 15, 2009 установить linuxtv либо video4linux либо v4l но это ещё не всё :))) Вставить ник Quote
Cramac Posted July 16, 2009 Author Posted July 16, 2009 (edited) вновь вернулся к старой теме, хотел обновить ВЛЦ, не хочет. Все стоит необходимое, при сборке не ругается, но не работает. Лог cramac.ru/vlc_1.log запускаю как на старой версии vlc_1.zip Edited July 16, 2009 by Cramac Вставить ник Quote
