Продам Cisco Catalyst WS-C3550-12T + 2 MM GBIC (2 гигабитных оптических модуля) за 1000$.
File "flash:c3550-ipservicesk9-mz.122-25.SEE3.bin" uncompressed and installed, e
ntry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
© of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
© (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(25)SEE3,
RELEASE SOFTWARE (fc2)
Copyright © 1986-2007 by Cisco Systems, Inc.
Compiled Thu 22-Feb-07 15:35 by myl
Image text-base: 0x00003000, data-base: 0x00DC116C
Initializing flashfs...
flashfs[1]: 7 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 16128000
flashfs[1]: Bytes used: 7147008
flashfs[1]: Bytes available: 8980992
flashfs[1]: flashfs fsck took 12 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
POST: Ethernet Controller Tests : End, Status Passed
POST: Loopback Tests : Begin
POST: Loopback Tests : End, Status Passed
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco WS-C3550-12T (PowerPC) processor (revision S0) with 65526K/8192K bytes of
memory.
Processor board ID CAT0848Z1NW
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 2 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 7 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 8 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 9 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 10 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 11 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 12 has 1 Gigabit Ethernet/IEEE 802.3 interface
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:12:80:C4:25:80
Motherboard assembly number: 73-5527-17
Power supply part number: 34-0967-01
Motherboard serial number: CAT08480F44
Power supply serial number: DTH08275YXK
Model revision number: S0
Motherboard revision number: A0
Model number: WS-C3550-12T
System serial number: CAT0848Z1NW
Edited by amper
