Нестабильная скорость ptp линка на микротиках
День добрый!
Помоги пожалуйста разобраться в возможных причинах нестабильной скорости в радио линке.
Линк ptp, построен на микротиках RB411AH, карты микротиковские.
C обоих сторон антенны "24дБ Bester Polyaris". Расстояние ~4км.
настройка 1 стороны
/int wireless print advanced
Flags: X - disabled, R - running
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:2C:AB:9E arp=enabled disable-running-check=no interface-type=Atheros AR5413
radio-name="000C422CAB9E" mode=station-wds ssid="MikroTik" area="" frequency-mode=manual-txpower
country=no_country_set antenna-gain=0 frequency=2437 band=2.4ghz-g-turbo scan-list=2400-2500 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps
max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=br1 wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no
allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 hw-retries=4 frame-lifetime=0
adaptive-noise-immunity=none
/int wireless nstreme print
0 name="wlan1" enable-nstreme=yes enable-polling=yes disable-csma=no framer-policy=none framer-limit=3200
настройка 2 стороны
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:2C:F4:75 arp=enabled disable-running-check=no interface-type=Atheros AR5413
radio-name="000C422CF475" mode=ap-bridge ssid="MikroTik" area="" frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=2437 band=2.4ghz-g-turbo scan-list=default rate-set=default
enable-nstreme=yes enable-polling=yes disable-csma=yes framer-policy=best-fit framer-limit=4000
Результаты измерений iperf:
[ 5] 0.0-18.5 sec 872 KBytes 387 Kbits/sec
[ 5] 0.0-10.3 sec 21.0 MBytes 17.0 Mbits/sec
[ 5] 0.0-10.1 sec 45.3 MBytes 37.5 Mbits/sec
[ 5] 0.0-14.7 sec 26.1 MBytes 14.9 Mbits/sec
[ 5] 0.0-12.2 sec 11.6 MBytes 8.03 Mbits/sec
[ 5] 0.0-10.0 sec 46.9 MBytes 39.3 Mbits/sec
[ 5] 0.0-17.4 sec 600 KBytes 282 Kbits/sec
[ 5] 0.0-12.4 sec 2.87 MBytes 1.94 Mbits/sec
[ 5] 0.0-24.2 sec 9.12 MBytes 3.16 Mbits/sec
[ 5] 0.0-10.1 sec 13.7 MBytes 11.3 Mbits/sec
Вот мониторинг с первой стороны
[admin@RB1] /interface wireless> monitor 0
status: connected-to-ess
band: 2.4ghz-g-turbo
frequency: 2437MHz
tx-rate: "36Mbps*2"
rx-rate: "54Mbps*2"
ssid: "MikroTik"
bssid: 00:0C:42:2C:F4:75
radio-name: "000C422CF475"
signal-strength: -59dBm
noise-floor: -98dBm
signal-to-noise: 39dB
tx-ccq: 86%
p-throughput: 44800
overall-tx-ccq: 88%
authenticated-clients: 1
wds-link: yes
nstreme: yes
polling: yes
csma-disabled: yes
framing-mode: best-fit
framing-limit: 3999
routeros-version: "3.10"
last-ip: 172.16.0.1
802.1x-port-enabled: yes
compression: no
current-tx-powers: 6Mbps:19(19),9Mbps:19(19),12Mbps:19(19),18Mbps:19(19),24Mbps:19(19),36Mbps:18(18
),48Mbps:17(17),
54Mbps:16(16)
notify-external-fdb: no
frequency: 2437MHz
tx-rate: "54Mbps*2"
rx-rate: "54Mbps*2"
ssid: "MikroTik"
signal-strength: -57dBm
tx-signal-strength: -61dBm
noise-floor: -98dBm
signal-to-noise: 41dB
tx-ccq: 100%
rx-ccq: 100%
p-throughput: 55138
overall-tx-ccq: 100%
frequency: 2437MHz
tx-rate: "54Mbps*2"
rx-rate: "48Mbps*2"
ssid: "MikroTik"
tx-signal-strength: -62dBm
noise-floor: -98dBm
tx-ccq: 100%
rx-ccq: 100%
frequency: 2437MHz
tx-rate: "54Mbps*2"
rx-rate: "48Mbps*2"
ssid: "MikroTik"
signal-strength: -58dBm
noise-floor: -98dBm
signal-to-noise: 40dB
tx-ccq: 92%
rx-ccq: 87%
p-throughput: 52327
overall-tx-ccq: 92%
frequency: 2437MHz
tx-rate: "48Mbps*2"
rx-rate: "48Mbps*2"
ssid: "MikroTik"
noise-floor: -98dBm
tx-ccq: 86%
rx-ccq: 61%
p-throughput: 50018
overall-tx-ccq: 86%
frequency: 2437MHz
tx-rate: "54Mbps*2"
rx-rate: "48Mbps*2"
ssid: "MikroTik"
signal-strength: -60dBm
noise-floor: -98dBm
signal-to-noise: 38dB
tx-ccq: 98%
rx-ccq: 48%
p-throughput: 51328
overall-tx-ccq: 98%
frequency: 2437MHz
tx-rate: "48Mbps*2"
rx-rate: "48Mbps*2"
ssid: "MikroTik"
tx-signal-strength: -63dBm
noise-floor: -98dBm
tx-ccq: 85%
rx-ccq: 79%
p-throughput: 50249
overall-tx-ccq: 85%
frequency: 2437MHz
tx-rate: "48Mbps*2"
rx-rate: "48Mbps*2"
ssid: "MikroTik"
tx-signal-strength: -60dBm
noise-floor: -98dBm
tx-ccq: 91%
rx-ccq: 74%
p-throughput: 47903
overall-tx-ccq: 91%
frequency: 2437MHz
tx-rate: "48Mbps*2"
rx-rate: "54Mbps*2"
ssid: "MikroTik"
noise-floor: -98dBm
tx-ccq: 94%
rx-ccq: 69%
p-throughput: 49337
overall-tx-ccq: 94%
frequency: 2437MHz
tx-rate: "48Mbps*2"
rx-rate: "48Mbps*2"
ssid: "MikroTik"
noise-floor: -98dBm
tx-ccq: 92%
rx-ccq: 87%
p-throughput: 47196
overall-tx-ccq: 92%
frequency: 2437MHz
tx-rate: "54Mbps*2"
rx-rate: "36Mbps*2"
ssid: "MikroTik"
noise-floor: -98dBm
tx-ccq: 88%
rx-ccq: 82%
p-throughput: 48841
overall-tx-ccq: 88%
frequency: 2437MHz
tx-rate: "48Mbps*2"
rx-rate: "36Mbps*2"
ssid: "MikroTik"
noise-floor: -98dBm
tx-ccq: 93%
rx-ccq: 68%
p-throughput: 48501
overall-tx-ccq: 93%
Спасибо!
Частоту смените че ви мучитесь екстра ченелс и вперед.
А по каким данным Вы сделали вывод, что эфир зашумлен?
Екстра ченел это 2.3? А антенны будут работать на этой частоте? У них диапазон 2400-2483 МГц.
любая антенна немного более широкополосна, чем написано.
просто потеряете уровень сигнала (а заодно и шума)
антенны на 2.4ггц спокойно можно использовать на 1800-3600.
если конечно, запас по мощности сигнала есть.
на границах частот уже будет -10-15дб
но использовать антенну 2.4 под частоту 2.3 - почти норма.
кстати, антенны "bester polyaris" за антенну не считаю.
уж извините, но это какая-то пародия. сильно уже заметна разница в сигнале при сравнении с аналогичной моделью "bester parabolic"
Edited by [anp/hsw]
