CME поднял, софтовый телефон зарегился, и есть гудок. А вот с картой VIC2-2FXS какие-то траблы :(, во первых нет сигнала станции в телефоне, карта не показывает доступных портов
sh hard:
Cisco 2811 (revision 53.50) with 223232K/38912K bytes of memory.
Processor board ID FCZ1201727B
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
sh diag
Slot 0:
        C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 02:02:09 ago
        Onboard VPN             : v2.3.3
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC114954C8
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26920-04
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 04
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20071213
        Chassis Serial Number    : FCZ1201727B
        Chassis MAC Address      : 001e.be4f.9da0
        MAC Address block size   : 24
        CLEI Code                : COM7R00ARA
        Product (FRU) Number     : CISCO2811
        Part Number              : 73-10258-05
        Version Identifier       : V05
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 31 34 39 35 34 43 38 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
          0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 43 2D C2 8B 46 43 5A 31 32 30 31
          0x40: 37 32 37 42 C3 06 00 1E BE 4F 9D A0 43 00 18 C6
          0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
          0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
        WIC Slot 0:
        2nd generation - FXS Voice daughter card (2 port)
        Hardware Revision        : 3.1
        Top Assy. Part Number    : 800-21341-02
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 01
        PCB Serial Number        : FOC11374WLZ
        RMA History              : 00
        Product (FRU) Number     : VIC2-2FXS
        Version Identifier       : V01
        CLEI Code                : CNUIAPPAAA
          0x00: 04 FF 40 00 47 41 03 01 C0 46 03 20 00 53 5D 02
          0x10: 42 42 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 31 33 37 34 57 4C 5A 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 32 46 58 53 89 56 30 31 20
          0x40: C6 8A 43 4E 55 49 41 50 50 41 41 41 FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
вот список доступных портов
sh voice port summ
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
50/0/1          1      efxs     up    dorm on-hook  idle     y
50/0/2          1      efxs     up    up   on-hook  idle     y
50/0/3          1      efxs     up    up   on-hook  idle     y
50/0/4          1      efxs     up    up   on-hook  idle     y
50/0/5          1      efxs     up    up   on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
куда копать дальше, пока не совсем ясно.
т.е. я покупаю вот такой модуль: PVDM2-16, и будет счастье?
Тогда другой вопрос, на что влияет кол-во каналов?
P.S. и еще один вопрос, куда ставить этот модуль, на плату расширения? У меня сейчас VIC2-2FXS воткнут в маршрутизатор, без платы NM-HDV2
Edited by nOPTHOu
Для одного VIC2-2FXS за глаза хватит PVDM2-8. Вставить можно прямо на материнскую плату, там есть 2 слота.
На что влияет - здесь написано.
