Здравствуйте, имеется Cisco Catalyst 6509.
WS-X6K-S2-MSFC2 (PFC2, MSFC2) with 512MB
IOS Ver 12.2(18)SXF12 (s222-adventerprisek9_wan-mz.122-18.SXF12a.bin)
Режу скорость безлимитчикам следующим образом:
ip access-list extended acl_cl_001
permit ip any host 212.88.xxx.1
ip access-list extended client_002
permit ip any host 212.88.xxx.2
ip access-list extended client_003
permit ip any host 212.88.xxx.3
ip access-list extended client_004
permit ip any host 212.88.xxx.4
ip access-list extended client_005
permit ip any host 212.88.xxx.5
ip access-list extended client_253
permit ip any host 212.88.xxx.6
ip access-list extended client_254
permit ip any host 212.88.xxx.7
class-map match-all client_001
match access-group name acl_cl_001
class-map match-all client_002
match access-group name acl_cl_002
class-map match-all client_003
match access-group name acl_cl_003
class-map match-all client_004
match access-group name acl_cl_004
class-map match-all client_005
match access-group name acl_cl_005
class-map match-all client_253
match access-group name acl_cl_253
class-map match-all client_254
match access-group name acl_cl_254
mls qos aggregate-policer 512k_cl_001 520000 65000 65000 conform-action transmit exceed-action drop
mls qos aggregate-policer 512k_cl_002 520000 65000 65000 conform-action transmit exceed-action drop
mls qos aggregate-policer 256k_cl_003 264000 33000 33000 conform-action transmit exceed-action drop
mls qos aggregate-policer 128k_cl_004 200000 25000 25000 conform-action transmit exceed-action drop
mls qos aggregate-policer 128k_cl_005 200000 25000 25000 conform-action transmit exceed-action drop
mls qos aggregate-policer 256k_cl_253 264000 33000 33000 conform-action transmit exceed-action drop
mls qos aggregate-policer 128k_cl_254 200000 25000 25000 conform-action transmit exceed-action drop
policy-map unlim
class client_001
police aggregate 512k_cl_001
class client_002
police aggregate 512k_cl_002
class client_003
police aggregate 256k_cl_003
class client_004
police aggregate 128k_cl_004
class client_005
police aggregate 128k_cl_005
class client_253
police aggregate 256k_cl_253
class client_254
police aggregate 128k_cl_254
interface FastEthernet2/1
description Interface_to_Internet
switchport
switchport access vlan 3
no ip address
speed 100
duplex full
power inline never
no cdp enable
service-policy input unlim
И все бы хорошо, все работало замечательно до недавнего времени. Но однажды при применении очередного class-а к policy-map unlim все встало колом - пакеты практически перестали бегать, скорость канала упала практически до нуля. Сделал отмену class-а - все стало нормально. Применяю снова - снова проблемы. Ошибки быть не может - все проверил-перепроверил. Я думаю, что наступил какой-то предел class-ов в policy-map. Посчитал, сейчас 254 class-а в одном policy-map-е. Причем циска не ругается, команду проглатывает, все как обычно.
Может кто-нибудь подсказать, сколько максимум class-ов может быть в одном policy-map? Доки читал но ничего такого не нашел.
Edited by netman
Спасибо за ответ. Почитал, обидно..
Как же мне и дальше резать скорость, неужели все тупик - как же изобрести велосипед?
sup32 поставить
sup32 поставить
Злой Вы) Как серпом по яйцам)))
тоже железо
Cisco Catalyst 6509
IOS Ver 12.2(18)SXF12 (s222-entservicesk9_wan-mz.122-18.SXF14.bin)
прочитав данную тему решил с генерировать конфиг
ip access-list extended v_1_1
permit ip any host 172.20.1.1
ip access-list extended v_1_254
permit ip any host 172.20.1.254
ip access-list extended v_2_1
ip access-list extended v_2_254
class-map match-all v_1_1
match access-group name v_1_1
class-map match-all v_1_254
match access-group name v_1_254
class-map match-all v_2_1
match access-group name v_2_1
class-map match-all v_2_254
policy-map unlim_out
class local
class v_1_1
police cir 128000 bc 8000 be 8000 conform-action transmit exceed-action drop violate-action drop
class v_1_254
class v_2_1
class v_2_254
interface Vlan20
ip address x.x.x.x x.x.x.x
service-policy input unlim_out
и того получилось 508 class-ов вложенных в policy-map, но к сожалению пользователь был только один, нарезка работает без тормозов.
Edited by -=Ghost=-
