add name="z.lan" address=172.16.0.100 ttl=1d
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m inactive-flow-timeout=15s
/ ip address
add address=192.168.0.222/16 network=192.168.0.0 broadcast=192.168.255.255 interface=Z-lan1 comment="" disabled=no
add address=172.16.0.100/24 network=172.16.0.0 broadcast=172.16.255.255 interface=wlan1 comment="" disabled=no
/ ip proxy
set enabled=no port=8080 parent-proxy=0.0.0.0:0 maximal-client-connecions=1000 maximal-server-connectons=1000
/ ip proxy access
add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" disabled=no
/ ip neighbor discovery
set Z-lan1 discover=yes
set wlan1 discover=yes
/ ip route
add dst-address=0.0.0.0/0 pref-src=0.0.0.0 gateway=192.168.1.111,192.168.1.111,192.168.0.1,192.168.0.1,192.168.0.133 scope=255 \
target-scope=10 comment="" disabled=no
/ ip firewall nat
add chain=srcnat src-address=172.16.0.0/24 action=masquerade comment="masquerade hotspot network" disabled=no
add chain=dstnat protocol=tcp dst-port=53 action=redirect to-ports=64872 comment="hotspotredirect" disabled=no
add chain=hotspot protocol=tcp dst-port=53 action=redirect to-ports=64872 comment="" disabled=no
add chain=dstnat hotspot=from-client action=jump jump-target=hotspot comment="" disabled=no
add chain=hotspot protocol=tcp dst-port=80 hotspot=local-dst action=redirect to-ports=64873 comment="" disabled=no
add chain=hotspot protocol=tcp dst-port=443 hotspot=local-dst action=redirect to-ports=64875 comment="" disabled=no
add chain=hotspot protocol=tcp hotspot=!auth action=jump jump-target=hs-unauth comment="" disabled=no
add chain=hotspot protocol=tcp hotspot=auth action=jump jump-target=hs-auth comment="" disabled=no
add chain=hs-unauth protocol=tcp dst-port=80 action=redirect to-ports=64874 comment="" disabled=no
add chain=hs-unauth dst-address=172.16.0.100 protocol=tcp dst-port=80 action=return comment="" disabled=no
add chain=hs-unauth protocol=tcp dst-port=443 action=redirect to-ports=64875 comment="" disabled=no
add chain=hs-unauth protocol=tcp dst-port=25 action=jump jump-target=hs-smtp comment="" disabled=no
add chain=hs-auth protocol=tcp hotspot=http action=redirect to-ports=64874 comment="" disabled=no
add chain=hs-auth protocol=tcp dst-port=25 action=jump jump-target=hs-smtp comment="" disabled=no
add chain=forward hotspot=from-client,!auth action=jump jump-target=hs-unauth comment="" disabled=no
add chain=forward hotspot=to-client,!auth action=jump jump-target=hs-unauth-to comment="" disabled=no
add chain=input hotspot=from-client action=jump jump-target=hs-input comment="" disabled=no
add chain=hs-input protocol=udp dst-port=64872 action=accept comment="" disabled=no
add chain=hs-input protocol=tcp dst-port=64872-64875 action=accept comment="" disabled=no
add chain=hs-input hotspot=!auth action=jump jump-target=hs-unauth comment="" disabled=no
add chain=hs-unauth protocol=icmp action=return comment="" disabled=no
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s \
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m tcp-syncookie=no
/ ip firewall filter
/ ip firewall service-port
set ftp ports=21 disabled=no
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set gre disabled=yes
set pptp disabled=yes
/ ip hotspot
add name="hotspot1" interface=wlan1 address-pool=pool1 profile=hsprof1 idle-timeout=5m keepalive-timeout=none addresses-per-mac=2 \
disabled=no
/ ip hotspot service-port
/ ip hotspot profile
set default name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 \
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
add name="hsprof1" hotspot-address=172.16.0.100 dns-name="Z.lan" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0 \
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=yes radius
Все равно редирект не работает на страницу авторизации у пользователей которые получили адрес по DHCP. Если вручную адрес набираешь, то страница открывается. Но надо чтоб автоматически. ПОМОГИТЕ !!!!!!!!
КАКИЕ ПРАВИАЛ ЕЩЕ ПРОПИСАТЬ ??? может что то удалить ???
Edited by Elmariachi
