Пробую собрать ipset для 2.6.28.1
#ipset -V
ipset v2.4.6 Protocol version 2.
#iptables -V
iptables v1.4.2
# ipset -N testset ipmap --network 172.16.32.0/24
# ipset -A testset172.16.32.1
# ipset -nL
Type: ipmap
References: 0
Default binding:
Header: from: 172.16.32.0 to: 172.16.32.255
Members:
172.16.32.1
Bindings:
iptables -A INPUT -m set --set testset dst
Ком*** так и не завершается, в dmesg
[ 1964.703747] ip_tables: © 2000-2006 Netfilter Core Team
[ 1964.718280] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
[ 1964.718379] IP: [<ffffffffa005d008>] 0xffffffffa005d008
[ 1964.718379] PGD 1369ec067 PUD 12cc2c067 PMD 0
[ 1964.718379] Oops: 0000 [#1] SMP
[ 1964.718379] last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/i2c-adapter/i2c-0/0-002e/vrm
[ 1964.718379] CPU 3
[ 1964.718379] Modules linked in: ipt_set iptable_filter ip_tables ip_set_ipmap ip_set lm85 hwmon_vid e1000 i2c_piix4 k8temp hwmon
[ 1964.718379] Pid: 8497, comm: iptables Not tainted 2.6.28.1-sirmax2-layer7-ipset #2
[ 1964.718379] RIP: 0010:[<ffffffffa005d008>] [<ffffffffa005d008>] 0xffffffffa005d008
[ 1964.718379] RSP: 0000:ffff8801364e9d50 EFLAGS: 00010282
[ 1964.718379] RAX: ffffffffa005d008 RBX: ffffffffa005d440 RCX: 0000000000000020
[ 1964.718379] RDX: 0000000000020000 RSI: 0000000000000020 RDI: ffff8801364e9db8
[ 1964.718379] RBP: 0000000000000000 R08: 0000000000000000 R09: ffffffff8148e550
[ 1964.718379] R10: ffff88013b57ea88 R11: 0000000000000000 R12: ffff8801364e9db8
[ 1964.718379] R13: ffff8801364c3000 R14: 0000000000000000 R15: 0000000000000000
[ 1964.718379] FS: 00007f9d17e766f0(0000) GS:ffff88013fc08b80(0000) knlGS:0000000000000000
[ 1964.718379] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1964.718379] CR2: 0000000000000020 CR3: 00000001364b3000 CR4: 00000000000006a0
[ 1964.718379] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 1964.718379] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 1964.718379] Process iptables (pid: 8497, threadinfo ffff8801364e8000, task ffff88013b57ea40)
[ 1964.718379] Stack:
[ 1964.718379] ffffffff81288337 0000000000000000 ffff8801364e9de0 ffff8801364c3070
[ 1964.718379] 0000000000000070 ffff8801364c3000 ffff880136428780 ffff8801364c3000
[ 1964.718379] ffffffffa004dced ffff8801364c3072 ffffffffa004df8e ffff8801364e9e38
[ 1964.718379] Call Trace:
[ 1964.718379] [<ffffffff81288337>] xt_check_match+0x12a/0x143
[ 1964.718379] [<ffffffffa004dced>] check_match+0x37/0x41 [ip_tables]
[ 1964.718379] [<ffffffffa004df8e>] translate_table+0x238/0x3cb [ip_tables]
[ 1964.718379] [<ffffffffa004f126>] do_ipt_set_ctl+0xda/0x163 [ip_tables]
[ 1964.718379] [<ffffffff8128700b>] nf_sockopt+0x5e/0x77
[ 1964.718379] [<ffffffff8128704d>] nf_setsockopt+0x1a/0x1d
[ 1964.718379] [<ffffffff812930e8>] ip_setsockopt+0x64/0x7b
[ 1964.718379] [<ffffffff81263905>] sys_setsockopt+0x77/0x9c
[ 1964.718379] [<ffffffff8100b0cb>] system_call_fastpath+0x16/0x1b
[ 1964.718379] Code: <0f> b7 39 53 48 89 cb e8 fb 60 fe ff 66 ff c0 75 2f 48 c7 c2 e4 d0
[ 1964.718379] RIP [<ffffffffa005d008>] 0xffffffffa005d008
[ 1964.718379] RSP <ffff8801364e9d50>
[ 1964.727499] ---[ end trace 8d4dc08ff3bc5dc4 ]---
ребут только через sysrq
Идеи?
Патчей на ядре - только Layer7 в виде модулей, не загружены.
Edited by sirmax
дело в изменения между 2.6.28 и 2.6.28.1
On Sun, 25 Jan 2009, sirmax wrote:
> I have downloaded and compiled kernel 2.6.28 instead of 2.6.28.1
> with same config and all ipset works OK.
> As far as I can see, there is some uncompatibility with ipset and kernel
> 2.6.28.1 (and may be latest (?) I'll check it tomorrow)
Then there were some incompatibility changes between 2.6.28 and 2.6.28.1
too. Sigh. I need to update ipset again. I'll release a new version
somtime late night tomorrow.
Edited by sirmax
  • 4 weeks later...
Не могу собрать ipset-2.4.9 на 2.6.28
[root@localhost ipset-2.4.9]# make
cd kernel; make -C /usr/src/linux-2.6.28 M=`pwd` V=0 IP_NF_SET_MAX=256 IP_NF_SET_HASHSIZE=1024 modules
make[1]: Entering directory `/usr/src/linux-2.6.28'
CC [M] /usr/src/ipset-2.4.9/kernel/ip_set.o
In file included from <command line>:1:
./include/linux/autoconf.h:237:1: warning: "CONFIG_IP_NF_SET_MAX" redefined
<command line>:1:1: warning: this is the location of the previous definition
./include/linux/autoconf.h:1102:1: warning: "CONFIG_IP_NF_SET_HASHSIZE" redefined
/usr/src/ipset-2.4.9/kernel/ip_set.c:241: ошибка: conflicting types for ‘ip_set_addip_kernel’
include/linux/netfilter_ipv4/ip_set.h:488: ошибка: previous declaration of ‘ip_set_addip_kernel’ was here
/usr/src/ipset-2.4.9/kernel/ip_set.c:275: ошибка: conflicting types for ‘ip_set_delip_kernel’
include/linux/netfilter_ipv4/ip_set.h:491: ошибка: previous declaration of ‘ip_set_delip_kernel’ was here
/usr/src/ipset-2.4.9/kernel/ip_set.c:2056: ошибка: conflicting types for ‘ip_set_addip_kernel’
/usr/src/ipset-2.4.9/kernel/ip_set.c:2057: ошибка: conflicting types for ‘ip_set_delip_kernel’
make[2]: *** [/usr/src/ipset-2.4.9/kernel/ip_set.o] Ошибка 1
make[1]: *** [_module_/usr/src/ipset-2.4.9/kernel] Ошибка 2
make[1]: Leaving directory `/usr/src/linux-2.6.28'
make: *** [modules] Ошибка 2
я так понял дублирование функций происходит
