Чисто академический интерес.
Есть каталист 3750G, у которого в конфиге:
interface Port-channel1
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 1,2,4,5,7,8,10
switchport mode trunk
switchport block multicast
flowcontrol receive on
end
interface GigabitEthernet1/0/21
description DGS-3100 Trunk1
ip access-group 151 in
no cdp enable
channel-group 1 mode active
end
! и еще 3 порта-мембера с абсолютно одинаковыми настройками
На другом конце Ether-channel подключен D-Link DGS-3100-24TG, у которого порты-мемберы имеют включенный flow-control.
Смотрим на каталисте состояние канала:
Core3#sh int port-ch 1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0021.a16f.4798 (bia 0021.a16f.4798)
MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
reliability 255/255, txload 4/255, rxload 2/255
Encapsulation ARPA, loopback not set
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/21 Gi1/0/22 Gi1/0/23 Gi1/0/24
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:07, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 44765000 bits/sec, 8676 packets/sec
5 minute output rate 67984000 bits/sec, 9764 packets/sec
1028758349 packets input, 911529861569 bytes, 0 no buffer
Received 1296792 broadcasts (0 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 106996 multicast, 0 pause input
0 input packets with dribble condition detected
1077308766 packets output, 934911433934 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
Вопрос - и чего не хватает для того, чтобы flow-control включился?
