Alex780 Опубликовано 21 апреля, 2009 · Жалоба diff --context -r new/open-sasc-ng/open-sasc-ng/dvblb_plugins/plugin_ffdecsa.c new2/open-sas *** open-sasc-ng/open-sasc-ng/dvblb_plugins/plugin_ffdecsa.c 2009-03-20 23:51:05.00000000 --- open-sasc-ng/open-sasc-ng/dvblb_plugins/plugin_ffdecsa.c 2009-04-02 12:08:31.00000000 *************** *** 15,22 **** #define DBG_NAME "CSA" #include "debug.h" //This is required to happen AFTER PLUGIN_ID is defined ! #define FF_MAX_IDX 16 ! #define FF_MAX_PID 16 #define push_empty_queue(_item, _queue) { \ pthread_mutex_lock(&list_lock); \ --- 15,22 ---- #define DBG_NAME "CSA" #include "debug.h" //This is required to happen AFTER PLUGIN_ID is defined ! #define FF_MAX_IDX 8 ! #define FF_MAX_PID 8 #define push_empty_queue(_item, _queue) { \ pthread_mutex_lock(&list_lock); diff --context -r new/open-sasc-ng/open-sasc-ng/sc/PLUGINS/src/sc-src/cam.c new2/open-sasc-n *** open-sasc-ng/open-sasc-ng/sc/PLUGINS/src/sc-src/cam.c 2009-03-20 23:48:37.00000000 --- open-sasc-ng/open-sasc-ng/sc/PLUGINS/src/sc-src/cam.c 2009-04-02 12:08:29.00000000 *************** *** 2264,2270 **** // -- cDeCSA ------------------------------------------------------------------- #define MAX_CSA_PIDS 8192 ! #define MAX_CSA_IDX 32 //#define DEBUG_CSA --- 2264,2270 ---- // -- cDeCSA ------------------------------------------------------------------- #define MAX_CSA_PIDS 8192 ! #define MAX_CSA_IDX 16 //#define DEBUG_CSA *** open-sasc-ng/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/sc-irdeto/sc-irdeto.c 2009 --- open-sasc-ng/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/sc-irdeto/sc-irdeto.c 2009 *************** *** 37,43 **** #define SC_NAME "Irdeto" #define SC_ID MAKE_SC_ID('I','r','d','t') ! #define L_SC 32 #define L_SC_ALL LALL(L_SC_LASTDEF) static const struct LogModule lm_sc = { --- 37,43 ---- #define SC_NAME "Irdeto" #define SC_ID MAKE_SC_ID('I','r','d','t') ! #define L_SC 8 #define L_SC_ALL LALL(L_SC_LASTDEF) static const struct LogModule lm_sc = { это для irdeto. Для остальных - ищите подобное в коде. Все равно когда много каналов работает хреново - т.к. кардшаринг не успевает ключи отдавать, sascng запускает сразу все потоки одновременно и шаринг сервер (даже свой) не успевает опросить карту. Нужен патч на задержку обращения потоков к шаринг серверу, чтобы они не все сразу обращались а по очереди с задержкой скажем в секунду - тогда можно уйму каналов одновременно открыть (ну если тачка потянет конечно) Проблема здесь https://opensvn.csie.org/traccgi/opensascng/ticket/13 Реально что получалось - 12 каналов, если больше тупить начинает. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
XmartiX Опубликовано 21 апреля, 2009 · Жалоба Огромное спасибо, Alex780. Моему проблема решена. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 21 апреля, 2009 (изменено) · Жалоба Спасибо Alex780! У меня открывается нормально 11 каналов (viaccess), пробовал 12 - открывается но начинает сыпаться... видимо действительно карты тормозят... Нужен патч на задержку обращения потоков к шаринг серверу, чтобы они не все сразу обращались а по очереди с задержкой скажем в секунду - тогда можно уйму каналов одновременно открыть (ну если тачка потянет конечно)И тут ты наверно тоже прав... нужно задержки...хотя... оно помещается в очередь карты и может быть задержками не решишь эту проблему P.S. Если у кого есть желание обменяться бэкапами по шарингу пишите в личку. Изменено 21 апреля, 2009 пользователем Hacker-CB Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Alex780 Опубликовано 22 апреля, 2009 · Жалоба да карты тут ни причем.. посмотри top нагрузку на сервер - мож не тянет он просто. А про задержки -я же вижу на шаринг сервере если чаще через 1 раз в сек идет запрос ECM то ответы NOT OK и sasc-ng не получает верный ключ. Тут у меня irdeto 2 карта - она тормозная сама по себе. На старых viaccess особо такой проблемы не замечаешь, она отдает ключи горазда быстрее. Но если зарядить много каналов - думаю тож самое будет! Вот поэтому нада както заставить sasc-ng посылать запросы с задержками, ну или getstream поправить так чтоб потоки с ТП не сразу все параллельно пускал а по очереди с задержкой пару сек. Тут вот ктото писал что 32 канала НТВ+ открыл - интересно как он такие проблемы решал? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 22 апреля, 2009 (изменено) · Жалоба да карты тут ни причем.. посмотри top нагрузку на сервер - мож не тянет он просто.А про задержки -я же вижу на шаринг сервере если чаще через 1 раз в сек идет запрос ECM то ответы NOT OK и sasc-ng не получает верный ключ. Тут у меня irdeto 2 карта - она тормозная сама по себе. На старых viaccess особо такой проблемы не замечаешь, она отдает ключи горазда быстрее. Но если зарядить много каналов - думаю тож самое будет! Вот поэтому нада както заставить sasc-ng посылать запросы с задержками, ну или getstream поправить так чтоб потоки с ТП не сразу все параллельно пускал а по очереди с задержкой пару сек. Тут вот ктото писал что 32 канала НТВ+ открыл - интересно как он такие проблемы решал? У меня 32 работают, но карт стоит штук 5 на двух серверах. одна карта вроде как не в состоянии обработать больше 15 запросов процессор коре квад. запас еще процентов 60 по загрузке. load avarage ~4 Изменено 22 апреля, 2009 пользователем Hacker-CB Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Cramac Опубликовано 22 апреля, 2009 · Жалоба Hacker-CB, а какие изменения сделали в плагине? или хватило изменений в первых двух файлах? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
zulu_radist Опубликовано 22 апреля, 2009 (изменено) · Жалоба Пропатчил, пересобрал, не помогает :( Больше 3-х каналов все равно не декодит, в лог сыпется вот такое Apr 22 15:17:06.234 CAM(cardclient.core): Wed Apr 22 15:17:06 2009: lagged cw 2083 ms (Newcamd) Called cSascDvbDevice::SetCaDescr Apr 22 15:17:06.240 CSA: Got command(5): E idx: 2 pid: 0 key: 0c9c...7f Apr 22 15:17:06.255 CAM(general.error): action logger 0/3 read: Buffer overflow Apr 22 15:17:12.515 CAM(core.auStats): EMM packet load average (1/4/10min) 566 491 367 pks/s Called cSascDvbDevice::SetCaDescr Apr 22 15:17:14.553 CSA: Got command(5): E idx: 3 pid: 0 key: 38bc...7d Called cSascDvbDevice::SetCaDescr Apr 22 15:17:15.594 CSA: Got command(5): O idx: 4 pid: 0 key: e1a0...83 Called cSascDvbDevice::SetCaDescr Apr 22 15:17:15.986 CSA: Got command(5): E idx: 1 pid: 0 key: d9b0...2c Apr 22 15:17:16.372 CAM(cardclient.core): Wed Apr 22 15:17:16 2009: lagged cw 2202 ms (Newcamd) Called cSascDvbDevice::SetCaDescr Apr 22 15:17:16.378 CSA: Got command(5): O idx: 2 pid: 0 key: 0181...3e Apr 22 15:17:16.384 CAM(general.error): action logger 0/2 read: Buffer overflow Apr 22 15:17:16.584 CAM(general.error): action logger 0/3 read: Buffer overflow Apr 22 15:17:16.784 CAM(general.error): action logger 0/4 read: Buffer overflow Apr 22 15:17:16.984 CAM(general.error): action logger 0/1 read: Buffer overflow Изменено 22 апреля, 2009 пользователем zulu_radist Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Cramac Опубликовано 22 апреля, 2009 (изменено) · Жалоба так же благодарю Alex780 за подсказку что где поменять. После данных манипуляций, стало открывать весь транспордер. Но на компьютере П4 2ггц, 1гб памяти, 9 каналов декодирует с трудом, заикаится, рассыпаится картинка. Изменено 22 апреля, 2009 пользователем Cramac Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 22 апреля, 2009 · Жалоба Hacker-CB, а какие изменения сделали в плагине? или хватило изменений в первых двух файлах?только первые два Но на компьютере П4 2ггц, 1гб памяти, 9 каналов декодирует с трудом, заикаится, рассыпаится картинка.так и будет! слабенькая это тачка для таких задач Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
vladd Опубликовано 22 апреля, 2009 · Жалоба У меня 32 работают, но карт стоит штук 5 на двух серверах. одна карта вроде как не в состоянии обработать больше 15 запросовпроцессор коре квад. запас еще процентов 60 по загрузке. load avarage ~4 Одной картой можно открыть до 50 каналов, эксперименты проводили на стенде как-то давно. Кардсервер должен быть mpcs. Ридер - только феникс через нативный ком-порт на 6 мгц. Ну и плюс на одном кваде можно декодить спокойно 30-35 каналов, одним запущенным sasc-ng. Судя по загрузке cpu - потянул бы и больше, только не хватает pci слотов в современных матерях для этого. Правда, тупит он долго в этом случае, перед тем как начать что-то показывать. Иногда до 10 минут. Решение непригодное для коммерческой эксплуатации, только побаловаться если :) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Alex780 Опубликовано 23 апреля, 2009 · Жалоба вот вот - тупит :) тупит как раз изза одновременных запросов Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 23 апреля, 2009 · Жалоба Поставил свои две карты. одна тачка с них вещает 39 каналов, вторая 11 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
zulu_radist Опубликовано 23 апреля, 2009 · Жалоба киньте кто-нить пожалуйста свой выхлоп dvbscan на 12475:v:0:22000 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 27 апреля, 2009 · Жалоба А кто-нибудь вещал HD каналы? С помощью какой карты? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
zulu_radist Опубликовано 27 апреля, 2009 · Жалоба купил ST 4200 PCI S2 (даже пультик есть:)) но еще не пробовал вещать Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Mallorn Опубликовано 27 апреля, 2009 (изменено) · Жалоба В общем, запустил я все-таки связку opensasc-ng + getstream. Версии брал с SVN самые свежие на данный момент. sasc-ng отказывался компилиться как на дебиан etch, так и на debian lenny. opensasc-ng компилится на ура на любой дебиане, но существует проблема со добавлением модуля dvbloopback.ko Мне удалось его запустить только на ядре 2.6.26-2, на более старых через 10-20 минут просмотра комп тупо уходил в перезагрузку с ошибками ядра. :( Да, для запуска sasc-ng использовал скрипты, которые предлагают сами разработчики. Свой вариант скрипта через start-stop-daemon работал хреново. Предлагаемый разработчиком скрипт юзает screen, а я чет не люблю его. Тем не менее, практика показала, что нормально sasc-ng работает ток с "родным" скриптом. Сейчас вещают в сеть два getstream: один 10 каналов с EAM1 (открытых), второй с НТВ+ 5 кодированных каналов. Вещание обычными http потоками. Держит стабильно более 100 одновременных коннектов. Нагрузка на процессор при 100 коннектах: 20% getstream c EAM1, 10% sasc-ng, 15% gestream c НТВ+. Изменено 27 апреля, 2009 пользователем Mallorn Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
moxjemi Опубликовано 27 апреля, 2009 · Жалоба У меня при вещании 13 каналов и декодировании 4 каналов в BISS одновременно загрузка 50 процентов.. в принципе некритично но хотелось бы поменьше... Может кто что нить подскажет? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Alexander Опубликовано 27 апреля, 2009 · Жалоба HD я попробовал вещать. уже, правда, не гетстримом. только VDR+VLC. причем гемор по сборке VDR'а и sasc'а еще тот :( но реально вещается :) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 27 апреля, 2009 · Жалоба Итак, после небольших плясок вокруг кода: Исходные данные: CORE QUAD 3HHz, 4RAM 5 * skystar 2.8 на выходе 51 канал в viaccess, загрузка около 60%: top - 00:37:53 up 5:29, 3 users, load average: 7.08, 7.25, 7.12 Tasks: 103 total, 4 running, 99 sleeping, 0 stopped, 0 zombie Cpu0 : 42.5%us, 4.2%sy, 0.1%ni, 50.2%id, 0.1%wa, 1.8%hi, 1.1%si, 0.0%st Cpu1 : 42.7%us, 4.8%sy, 0.1%ni, 49.7%id, 0.1%wa, 1.7%hi, 1.0%si, 0.0%st Cpu2 : 42.8%us, 4.5%sy, 0.1%ni, 49.6%id, 0.1%wa, 1.8%hi, 1.1%si, 0.0%st Cpu3 : 42.3%us, 4.7%sy, 0.1%ni, 50.1%id, 0.1%wa, 1.7%hi, 1.0%si, 0.0%st Mem: 4138016k total, 679268k used, 3458748k free, 153160k buffers Swap: 9068652k total, 0k used, 9068652k free, 153012k cached Рецепт: сначала обязательно пересобрать дрова v4linux с изменениями: --- v4l-dvb.OLD/linux/drivers/media/dvb/dvb-core/dvbdev.h 2009-04-04 13:48:34.000000000 +0400 +++ v4l-dvb/linux/drivers/media/dvb/dvb-core/dvbdev.h 2009-04-27 17:44:01.000000000 +0400 @@ -31,7 +31,7 @@ #define DVB_MAJOR 212 -#define DVB_MAX_ADAPTERS 8 +#define DVB_MAX_ADAPTERS 10 #define DVB_UNSET (-1) потом пропатчить сам opensasc (я брал 71 ревизию): diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/dvblb_plugins/plugin_ffdecsa.c opensasc-ng.new/open-sasc-ng/dvblb_plugins/plugin_ffdecsa.c --- opensasc-ng.orig/open-sasc-ng/dvblb_plugins/plugin_ffdecsa.c 2009-04-28 00:08:18.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/dvblb_plugins/plugin_ffdecsa.c 2009-04-27 19:31:00.000000000 +0400 @@ -15,8 +15,8 @@ #define DBG_NAME "CSA" #include "debug.h" //This is required to happen AFTER PLUGIN_ID is defined -#define FF_MAX_IDX 8 -#define FF_MAX_PID 8 +#define FF_MAX_IDX 16 +#define FF_MAX_PID 16 #define push_empty_queue(_item, _queue) { \ pthread_mutex_lock(&list_lock); \ diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/dvbloopback/module/dvbdev-2.6.v4l.h opensasc-ng.new/open-sasc-ng/dvbloopback/module/dvbdev-2.6.v4l.h --- opensasc-ng.orig/open-sasc-ng/dvbloopback/module/dvbdev-2.6.v4l.h 2009-04-28 00:08:17.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/dvbloopback/module/dvbdev-2.6.v4l.h 2009-04-27 16:35:47.000000000 +0400 @@ -31,7 +31,7 @@ #define DVB_MAJOR 212 -#define DVB_MAX_ADAPTERS 8 +#define DVB_MAX_ADAPTERS 10 #define DVB_UNSET (-1) Only in opensasc-ng.new/open-sasc-ng/dvbloopback/module: dvbdevwrap.h diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/dvbloopback/module/dvblb_internal.h opensasc-ng.new/open-sasc-ng/dvbloopback/module/dvblb_internal.h --- opensasc-ng.orig/open-sasc-ng/dvbloopback/module/dvblb_internal.h 2009-04-28 00:08:17.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/dvbloopback/module/dvblb_internal.h 2009-04-27 16:19:36.000000000 +0400 @@ -3,7 +3,7 @@ #include "dvbdev.h" #include "dvbloopback.h" -#define DVBLB_MAX_ADAPTERS 8 +#define DVBLB_MAX_ADAPTERS 10 struct dvblb; diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/dvbloopback/src/forward.c opensasc-ng.new/open-sasc-ng/dvbloopback/src/forward.c --- opensasc-ng.orig/open-sasc-ng/dvbloopback/src/forward.c 2009-04-28 00:08:17.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/dvbloopback/src/forward.c 2009-04-27 19:41:37.000000000 +0400 @@ -203,7 +203,7 @@ dprintf("Could not setup adapter link: %d != %d\n", real, tmp); return 0; } - for(int i=0; i < 3; i++) { + for(int i=0; i < 4; i++) { sprintf(str, "/proc/dvbloopback/adapter%d/%s", virt, dnames[link[i]]); FH = fopen(str, "w"); if(! FH) @@ -265,12 +265,12 @@ int main(int argc, char *argv[]) { unsigned long bufsize = 2000000; - struct parser_adpt pc_all[8]; - struct common_data common[8]; + struct parser_adpt pc_all[10]; + struct common_data common[10]; struct list_head *ptr; pthread_t msg_highpri_thread; pthread_t socket_thread; - int virt_adapt[8], real_adapt[8], adapter_cnt=0; + int virt_adapt[10], real_adapt[10], adapter_cnt=0; unsigned long debug_port = 5456; int longopt = 0; int c, Option_Index = 0; diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/Makefile opensasc-ng.new/open-sasc-ng/Makefile --- opensasc-ng.orig/open-sasc-ng/Makefile 2009-04-28 00:08:18.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/Makefile 2009-04-27 15:50:58.000000000 +0400 @@ -16,6 +16,7 @@ DVB_MOD_DIR = DVB_DIR=$(DVB_DIR) endif +DEFINES += -D__KERNEL_STRICT_NAMES DEFINES += -DRELEASE_VERSION=\"$(VERSION)\" INCLUDES += -Idvbloopback/module -I/lib/modules/$(shell uname -r)/build/include LBDIR = dvbloopback/src diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/sc/PLUGINS/src/sc-src/cam.c opensasc-ng.new/open-sasc-ng/sc/PLUGINS/src/sc-src/cam.c --- opensasc-ng.orig/open-sasc-ng/sc/PLUGINS/src/sc-src/cam.c 2009-04-28 00:08:17.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/sc/PLUGINS/src/sc-src/cam.c 2009-04-27 19:31:54.000000000 +0400 @@ -2264,7 +2264,7 @@ // -- cDeCSA ------------------------------------------------------------------- #define MAX_CSA_PIDS 8192 -#define MAX_CSA_IDX 16 +#define MAX_CSA_IDX 32 //#define DEBUG_CSA diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/cardclient/newcamd.c opensasc-ng.new/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/cardclient/newcamd.c --- opensasc-ng.orig/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/cardclient/newcamd.c 2009-04-28 00:08:17.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/cardclient/newcamd.c 2009-04-27 15:50:58.000000000 +0400 @@ -32,7 +32,7 @@ #include <openssl/des.h> -#define CWS_NETMSGSIZE 240 +#define CWS_NETMSGSIZE 480 // -- cTripleDes --------------------------------------------------------------- diff -E -b -u -r --exclude-from diffexclude opensasc-ng.orig/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/sc-irdeto/sc-irdeto.c opensasc-ng.new/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/sc-irdeto/sc-irdeto.c --- opensasc-ng.orig/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/sc-irdeto/sc-irdeto.c 2009-04-28 00:08:17.000000000 +0400 +++ opensasc-ng.new/open-sasc-ng/sc/PLUGINS/src/sc-src/systems/sc-irdeto/sc-irdeto.c 2009-04-27 19:32:20.000000000 +0400 @@ -37,7 +37,7 @@ #define SC_NAME "Irdeto" #define SC_ID MAKE_SC_ID('I','r','d','t') -#define L_SC 8 +#define L_SC 16 #define L_SC_ALL LALL(L_SC_LASTDEF) static const struct LogModule lm_sc = { после этого обязательно запускать отедльный sasc-ng для каждой пары адаптеров и отдельный getstream для каждого адаптера. (иначе буферов у них не хватит) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 27 апреля, 2009 · Жалоба купил ST 4200 PCI S2 (даже пультик есть:)) но еще не пробовал вещать отпишись по результатам. говорят что только VLC сможет, getstream не тянет HD... Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
vladd Опубликовано 28 апреля, 2009 · Жалоба Итак, после небольших плясок вокруг кода:Исходные данные: CORE QUAD 3HHz, 4RAM 5 * skystar 2.8 Не подскажешь, где взял материнку под квад с 5 pci-слотами, и ее модель? Все магазины уже обзвонил - даже 3 слота уже большая проблема. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 28 апреля, 2009 · Жалоба Не подскажешь, где взял материнку под квад с 5 pci-слотами, и ее модель? Все магазины уже обзвонил - даже 3 слота уже большая проблема. http://www.supermicro.com/products/motherb...Q35/C2SBC-Q.cfm Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andriuxa Опубликовано 28 апреля, 2009 · Жалоба Подскажите, пожалуйста, по моей поблеме. В ПК у меня волей судьбы стоит 3 dvb-карты. Все настроены, сигнал лочится, а вот в сеть не идет. Установил getstream и получил такие проблемы: Запускается getstream нормально, а вот при подключении через winamp получаю это: 2009-04-28 17:56:19.850 stream_http: connection from 10.10.10.99 for /radio/60gr 2009-04-28 17:56:20.821 stream_http: dropping connection to 10.10.10.99 for /radio/60gr 2009-04-28 17:56:29.890 stream_http: connection from 10.10.10.99 for /radio/60gr 2009-04-28 17:56:30.713 stream_http: dropping connection to 10.10.10.99 for /radio/60gr Конфиг прилагаю: http { port 8001; }; adapter 0 { packet-buffer 50; stat-interval 120; dvb-s { #lnb-sharing yes; lnb { lof1 9750000; lof2 10750000; slof 11700000; }; transponder { frequency 11671000; polarisation v; symbol-rate 18200000; }; }; stream { name "Full"; input { full; }; output-http { url /radio/60gr; }; # output-udp { # remote-address 10.10.10.99; # remote-port 1234; # sap { # scope global; # ttl 5; # playgroup "Free"; # }; }; }; Помогите, пожалуйста. Заранее благодарен. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Hacker-CB Опубликовано 28 апреля, 2009 · Жалоба после packet-buffer 50; stat-interval 120; допиши budget-mode 0; Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
zulu_radist Опубликовано 29 апреля, 2009 · Жалоба попробуй послушай поток VLC плеером, у меня winamp-ом тоже не работает)) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
