Ключи поздно приходят, может нагрузка на карты большая?
6 каналов. Это разве много? По моему это смех =)
#TRIKOLOR
pidfile "/var/run/trikolor1.pid";
newcamd 1 { hostname "127.0.0.1"; port "10002"; username "xxx"; password "xxx"; cfgkey "0102030405060708091011121314"; packet-buffer 128; disable-emm 0; };
monitor { logfile "/var/log/getstream/trikolor1.log"; syslog "trikolor-1"; interval 1;};
#11727
adapter 7 { packet-buffer 1022; budget-mode 0; stat-interval 60; stuck-interval 1300; dvb-s2 { lnb-sharing 0; lnb { lof1 10750000; lof2 10750000; slof 10750000; }; transponder { frequency 11727000; polarisation l; symbol-rate 27500000; };
stream { name "21+"; input { pnr 2617; newcamd 1; ecm-group 0x02; }; output-udp { remote-address 239.255.1.95;    remote-port 1234;    ttl 32; }; };
stream { name "Telekanal Futbol"; input { pnr 2619; newcamd 1; ecm-group 0x02; }; output-udp { remote-address 239.255.1.97;    remote-port 1234;    ttl 32; }; };
stream { name "Moskva 24"; input { pnr 2620; newcamd 1; ecm-group 0x02; }; output-udp { remote-address 239.255.1.98;    remote-port 1234;    ttl 32; }; };
stream { name "OST TV"; input { pnr 2625; newcamd 1; ecm-group 0x02; }; output-udp { remote-address 239.255.1.102;    remote-port 1234;    ttl 32; }; };
stream { name "8 Kanal"; input { pnr 2626; newcamd 1; ecm-group 0x02; }; output-udp { remote-address 239.255.1.103;    remote-port 1234;    ttl 32; }; };
stream { name "Vremya"; input { pnr 2627; newcamd 1; ecm-group 0x02; }; output-udp { remote-address 239.255.1.104;    remote-port 1234;    ttl 32; }; };
Edited by micol
Share this post
Link to post
Share on other sites
Влючил отладку.
2012/07/30 16:57:07 1833 F772F280 c [YM][D] get_cw ecm handled rc=1 - sending
2012/07/30 16:57:07 1833 F772F280 c [YM] send_dcw rc=1
2012/07/30 16:57:07 1833 F772F280 c ncd_send_dcw: er->cpti=0, cl_msgid=4, 80
2012/07/30 16:57:07 1833 F772F280 c send 31 bytes to client
2012/07/30 16:57:07 1833 F772F280   00 1D 00 04 00 00 00 00 00 00 00 00 80 10 10 A1
2012/07/30 16:57:07 1833 F772F280   A8 B9 02 C5 C4 23 AC AB 19 F8 BC 79 19 51 E3
2012/07/30 16:57:07 1833 F772F280 c trikolor1 (4AE1&000002/0A3C/0000/0000/4D:D36A/A1-AB): cache1 (0 ms) by trikolor - Moskva 24
2012/07/30 16:57:07 1833 F772F280 c cw:
2012/07/30 16:57:07 1833 F772F280   A1 A8 B9 02 C5 C4 23 AC AB 19 F8 BC 79 19 51 E3
2012/07/30 16:57:07 1833 F772F280 c nmr(): len=0, errno=0
2012/07/30 16:57:07 1833 F772F280 c nmr: 1 return 0
2012/07/30 16:57:07 1833 F772F280 c tcp_conn_close(): fd=27, cl->typ == 'c'=1
2012/07/30 16:57:07 1833 F772F280 c received 0 bytes from client
2012/07/30 16:57:07 1833 F772F280 c Connection closed to client
2012/07/30 16:57:07 1833 F772F280 c trikolor1 disconnected  from 127.0.0.1
2012/07/30 16:57:07 1833 F772F280 c thread F772F280 ended!
Смущает received 0 bytes from client , после которого сразу закрывается TCP-сокет
Еще более смущает, что это только на триколоре %)
Edited by micol
Share this post
Link to post
Вот в этом и причина. Клиент отваливается, ключики в буфер оскам собирает, клиент коннектится, ключики приходят, но уже поздно.
Share this post
Link to post
Так зачем он отваливается. Вроде как есть keepalive? Где подкрутить?
Client max idle: 999999 s
Edited by micol
Share this post
Link to post
Ну сил моих больше нет. Че за петрушка это?
У меня то же самое было на триколоре. Появилось посоле того, как в гетстрим добавили реконнект к серверу ключей. После этого на триколоре гетстрим постоянно переподключался. Вернулся на 104 ревизию - данной проблемы больше нет. Сейчас радуга вещается на 114 версии, а триколор на 104.
Share this post
Link to post
Спасибо за совет, попробую соберу бинарник более старой ревизии...
Отпишусь по результатам
Share this post
Link to post
Поставил Phoenix (обычный) + Oscam version 1.00-unstable_svn-ymodv18-t33
запарка выходит уже второй день ...
Радуга никак не подымается ((, хоть об стенку бейся, главное не знаю куда копать ...
Или Oscam или феникс .... или что еще ...
До этого карта работала в ресивере lsdcs + mgcamd полет был нормалный
Edited by Jovanotti
Share this post
Link to post
Проблема решилась, некторое время постояло и заработало ....
Видимо апдейт прошел
Share this post
Link to post
а можете 104 ревизию кинуть куда-нибудь? в личку например
Share this post
Link to post
hg clone -r РЕВИЗИЯ url
Share this post
Link to post
Всем Привет.
Пытаюсь запустить S2 MPEG-4 Intelsat 15 85градус, на сервере с системой root@get-s2:/home/ttt# uname -a
Linux get-s2 2.6.32-21-generic #32-Ubuntu SMP Fri Apr 16 08:10:02 UTC 2010 i686 GNU/Linux, установлено 2 карточки TeVii S464 DVB-S/S2, с такими настройками:
adapter 0 {
budget-mode 0; packet-buffer 200; stat-interval 200; stuck-interval 2000;
dvb-s2 {
           lnb-sharing yes;
           lnb {
                   lof1 9750000;
                   lof2 10600000;
                   slof 11700000;
               transponder {
                   frequency 12526000;
                   polarisation v;
                   symbol-rate 13930000;
stream {name "OtkritiyMir"; input {pnr 1;}; output-udp {remote-address 239.3.3.23; remote-port 1234;
Не транслирует, сыпятся ошибки:
root@get-s2:/home/ttt# /home/ttt/getstream_a84-d/getstream -c /home/ttt/getstream_a84/conf/85-12526.conf -dd
Aug 21 14:13:33: start /home/ttt/getstream_a84-d/getstream: user:root[uid=0]
2012-08-21 14:13:33.640 fe: Adapter 0 Setting up frontend tuner
2012-08-21 14:13:33.643 dvr: Add Section callback for PID    0 (0x0000) type 1 (PAT)
2012-08-21 14:13:33.643 dvr: Add TS callback for PID    0 (0x0000) type 9 (Reassemble)
dmx_join_pid: pid=0
2012-08-21 14:13:33.643 dmx: Setting filter for pid 0 pestype 20
2012-08-21 14:13:33.643 dvr: Add TS callback for PID    1 (0x0001) type 10 (CAT)
dmx_join_pid: pid=1
2012-08-21 14:13:33.643 dmx: Setting filter for pid 1 pestype 20
2012-08-21 14:13:33.643 dvr: Add TS callback for PID    1 (0x0001) type 8 (Static)
Set cluster size: 140 for stream: OtkritiyMir
input thread = 3655
output thread = 3656
Aug 21 14:13:34: [stream:OtkritiyMir]Scan PAT table:
2012-08-21 14:13:34.240 dvr: Add TS callback for PID   16 (0x0010) type 8 (Static)
dmx_join_pid: pid=16
2012-08-21 14:13:34.240 dmx: Setting filter for pid 16 pestype 20
2012-08-21 14:13:34.240 dvr: Add TS callback for PID   17 (0x0011) type 8 (Static)
dmx_join_pid: pid=17
2012-08-21 14:13:34.240 dmx: Setting filter for pid 17 pestype 20
2012-08-21 14:13:34.240 dvr: Add TS callback for PID   18 (0x0012) type 8 (Static)
dmx_join_pid: pid=18
2012-08-21 14:13:34.240 dmx: Setting filter for pid 18 pestype 20
Aug 21 14:13:35: [stream:OtkritiyMir]Scan PAT table:
Aug 21 14:13:36: [stream:OtkritiyMir]Scan PAT table:
Aug 21 14:13:37: [stream:OtkritiyMir]Scan PAT table:
Aug 21 14:13:38: [stream:OtkritiyMir]Scan PAT table:
^CAug 21 14:13:38: received signal SIGINT from root[uid=0]
Также пробовал с lof1,lof2,slof, равные 10750000 - безуспешно.
При включении канала не S2, при конфиге:
adapter 0 {
dvb-s {
           lnb-sharing yes;
           lnb {
                   lof1 9750000;
                   lof2 10600000;
                   slof 11700000;
               transponder {
                   frequency 12640000;
                   polarisation v;
                   symbol-rate 30000000;
stream {name "Zvezda"; input {pnr 104;}; output-udp {remote-address 239.3.3.23; remote-port 1234;
Транслируется без проблем.
Подскажите, что я упустил при трансляции S2 MPEG-4?
Share this post
Link to post
попробуйте увеличить:
packet-buffer 1022; stat-interval 18000; stuck-interval 1300;
Как вариант еще указать конкретные пиды.
Share this post
Link to post
FYI
stat-interval - как часто печатать статистику в лог. Чисто декоративный параметр.
stuck-interval - как часто опрашивать/будить карты, актуально для некоторого железа, но вроде не для Tevii, можно наверное вообще в 0 поставить.
В общем packet-buffer единственное что может иметь смысл поменять, и budget-mode поставить в 1.
Но больше похоже что дело не в гетстрим. А скан работает для этого транспондера? Уровень сигнала какой? Если попробовать pnr 71, какой результат?
Вообще, Tevii S464 поддерживает 8PSK? UPD: Поддерживает, да.
Edited by Eleon
Share this post
Link to post
Добрый день.
Тестил с настройками Jovanotti, так же сыпали ошибки. Далее подстроили тарелку и поменял настройку lnb-sharing yes/lnb-sharing no. После этого все заработало. Так же получилось открыть канал Бисс, но на ПК работает, а на приставке elecard STB-820 - пишет "не правильный формат видео" Возможно ли каким то образом изменить данный формат трансляции? Первоначально-открытые каналы на STB работают хорошо.
Рабочий конфиг для Intelsat-15 85градус 12526 V + biss:
adapter 0 {
dvb-s2 {
           lnb-sharing no;
           lnb {
                   lof1 9750000;
                   lof2 10600000;
                   slof 11700000;
               transponder {
                   frequency 12526000;
                   polarisation v;
stream {name "OtkritiyMir"; input {pnr 1;}; output-udp {remote-address 239.3.3.23; remote-port 1234;};};
stream {name "sts"; input {pnr 5; biss "XXXXXXXXXXXXXXXX";}; output-udp {remote-address 239.3.3.24; remote-port 1234;};};
Благодарю Jovanotti, Eleon за помощь.
Share this post
Link to post
привет друзья собрал getstream на чистом Debian-е , карта SkyStar2 для теста пытаюсь запустить 12303 из 36 градуса один открытий канал
я савсем новичок вот конфиг
pidfile "/var/run/getstream12303.pid";
adapter 0 {
budget-mode 0;
packet-buffer 50;
stat-interval 120;
stuck-interval 200;
dvb-s {
lnb-sharing no;
lnb {
lof1 10750000;
lof2 10750000;
slof 10750000;
transponder {
frequency 12303000;
polarisation h;
stream {
name "TOP SHOP TV";
input { pnr 401;
output-udp { local-address 192.168.1.10; remote-address 239.255.3.1; remote-port 1234; ttl 7; };
а вот и лог
Aug 31 20:10:04: start /usr/bin/getstream: user:root[uid=0]
2012-08-31 20:10:04.298 fe: Adapter 0 Setting up frontend tuner
2012-08-31 20:10:04.312 fe: DVB-S tone = 0
2012-08-31 20:10:04.312 fe: DVB-S voltage = 1
2012-08-31 20:10:04.312 fe: DVB-S diseqc = 0
2012-08-31 20:10:04.312 fe: DVB-S freq = 12303000
2012-08-31 20:10:04.312 fe: DVB-S lof1 = 10750000
2012-08-31 20:10:04.312 fe: DVB-S lof2 = 10750000
2012-08-31 20:10:04.312 fe: DVB-S slof = 10750000
2012-08-31 20:10:04.312 fe: DVB-S feparams.frequency = 1553000
2012-08-31 20:10:04.312 fe: DVB-S feparams.inversion = 2
2012-08-31 20:10:04.312 fe: DVB-S feparams.u.qpsk.symbol_rate = 27500000
2012-08-31 20:10:04.312 dvr: Add Section callback for PID 0 (0x0000) type 1 (PAT)
2012-08-31 20:10:04.312 dvr: Add TS callback for PID 0 (0x0000) type 9 (Reassemble)
2012-08-31 20:10:04.312 dmx: Setting filter for pid 0 pestype 20
2012-08-31 20:10:04.312 dvr: Add TS callback for PID 1 (0x0001) type 10 (CAT)
2012-08-31 20:10:04.312 dmx: Setting filter for pid 1 pestype 20
2012-08-31 20:10:04.344 fe: Adapter 0 Status: 0x01 (HAS_SIGNAL)
2012-08-31 20:10:04.516 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
2012-08-31 20:10:04.720 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
Aug 31 20:10:04: [stream:TOP SHOP TV]Scan PAT table:
2012-08-31 20:10:04.920 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
2012-08-31 20:10:05.120 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
Aug 31 20:10:05: [stream:TOP SHOP TV]Scan PAT table:
2012-08-31 20:10:05.320 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
2012-08-31 20:10:05.524 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
2012-08-31 20:10:05.728 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
2012-08-31 20:10:05.928 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
2012-08-31 20:10:06.128 dvr: lockup of DVB card detected - trying to reanimate via bouncing filter
Aug 31 20:10:06: [stream:TOP SHOP TV]Scan PAT table:
чтобы смотреть поток в VLC надо ввести udb://239.255.3.1:1234 я правильно делаю ?
Edited by mozgik
Share this post
Link to post
чуть опечатались
udp://@239.255.3.1:1234
Share this post
Link to post
чуть опечатались
спасибо огромное буду пробовать, а конфиг у меня правильный ?
Share this post
Link to post
на вскидку все правильно
а насчет свитчей что выбрать ? обычные 24 портовые длинки или они работать не будут ?
Share this post
Link to post
свич без разницы, главное в свиче поддержка igmp v2 и возможность работать как IGMP Querier
Share this post
Link to post
у меня головка пере деланная в круговую в этом случаи кофиг правелныйы ?
dvb-s {
lnb-sharing no;
lnb {
lof1 10750000;
lof2 10750000;
slof 10750000;
Edited by mozgik
Share this post
Link to post
dvb-s {
lnb-sharing no;
lnb {
lof1 10750000;
lof2 10750000;
slof 10750000;
Если переделана из универсальной, то
lof1 9750000;
lof2 10600000;
slof 11700000;
Edited by Agent2006
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Sign in to follow this
