Спасибо огромное за DI-701.
10минут и мы уже мочим друг друга на CS сервере.
Тупая штука но работает.
Как получу зарплату заберу третий.
http://www.dlink.com/tech/faq/broadband/di701-faq.htm
В частности:
Question #1:   What is the DI-701?
The DI-701 functions as an IEEE 802.3 Ethernet-based Residential Gateway. It provides one 10/100 Dual Speed Ethernet port for connection to a home or small office network and one 10Mb Ethernet port for a DSL Modem, Cable Modem, or other Broadband access device. The D-Link DI-701 provides the safety and security of port blocking and a natural firewall as well as integrated NAT support that allows up to 32 users to share a single Internet Connection. Static address support, integrated client/server DHCP, and device name support will allow the D-Link Residential Gateway to connect to nearly any Broadband provider, and at the same time simplify local area network settings.
The DI-701 has one local 10/100 Dual Speed Ethernet port and one 10Mb Ethernet global port. The local port can be connected directly to a single computer to provide added security from hackers and others on the Internet or it can be connected to an Ethernet or Fast Ethernet hub or switch to provide Internet Sharing and Firewall protection to a local area network. The global port can be connected to any Cable, DSL, or Broadband modem with an Ethernet port.
Но уже морально устаревшее железка. Снята с производства и тд и тп.
