Помогите с IMQ patch для kernel-2.6.27.9
Стягивал с http://www.linuximq.net/patchs/linux-2.6.25-imq5.diff
Стягивал с https://dev.openwrt.org/browser/trunk/targe...ilter_imq.patch
Патч применяется но при компиляции ядра пишет что:
drivers/net/imq.c: In function 'imq_nf_queue':
drivers/net/imq.c:222: error: 'struct net_device' has no member named 'queue_lock'
drivers/net/imq.c:223: error: 'struct net_device' has no member named 'qdisc'
drivers/net/imq.c:232: warning: passing argument 2 of 'test_and_set_bit' from incompatible pointer type
drivers/net/imq.c:234: error: 'struct net_device' has no member named 'queue_lock'
drivers/net/imq.c: In function 'qdisc_run_tasklet':
drivers/net/imq.c:252: error: 'struct net_device' has no member named 'queue_lock'
drivers/net/imq.c:253: warning: passing argument 1 of 'qdisc_run' from incompatible pointer type
drivers/net/imq.c:254: warning: passing argument 2 of 'clear_bit' from incompatible pointer type
drivers/net/imq.c:255: error: 'struct net_device' has no member named 'queue_lock'
make[2]: *** [drivers/net/imq.o] Error 1
make[1]: *** [drivers/net] Error 2
make: *** [drivers] Error 2
А у меня такая беда
patch -p1 <imq-2.6.27-hotfix.patch
can't find file to patch at input line 3
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|--- linux-2.6.27/drivers/net/imq.c.orig 2008-10-17 09:14:36.000000000 +0000
|+++ linux-2.6.27/drivers/net/imq.c 2008-10-20 09:06:40.000000000 +0000
File to patch: 150-netfilter_imq.patch
patching file 150-netfilter_imq.patch
Hunk #1 FAILED at 76.
Hunk #2 FAILED at 219.
Hunk #3 FAILED at 231.
Hunk #4 FAILED at 249.
4 out of 4 hunks FAILED -- saving rejects to file 150-netfilter_imq.patch.rej
А у меня такая беда
Есть впечатление, что ты не то патчишь. Хотфиксом надо патчить основной патч imq для ядра (не iptables). И только потом накладывать его на исходники твоего ядра.
Если поможет, проверь опцию -p. Возможно в товем случае (в зависмости от дерева каталогов) надо патчить с -p0
А у меня такая беда
У меня всё получилось.
Я сделал так:
cd linux-2.6.27
patch -p1 < linux-2.6.25-imq5.diff
patch -p1 < imq-2.6.27-hotfix.patch
Я сделал так:
cd linux-2.6.27
Но ядро уходит в core через некоторое время после
modprobe imq
ip link set imq0 up
ip link set imq1 up
Я сделал так:
cd linux-2.6.27
modprobe imq
ip link set imq0 up
ip link set imq1 up
Таже самая проблема :(
