Имеется циска 3620. На борту карточка на 1 FastEthernet + 2Е1. По 1 Е1 принимаем инет от магистрала и через НАТ на этой же циске отдаем пользователям.
IOS - c3620-ik8o3s-mz.122-13.bin
cisco 3620 (R4700) processor (revision 0x81) with 49152K/16384K bytes of memory.
Processor board ID 24807390
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Фрагмент конфига, скасающийся НАТа (собственно больше на этой циске задач и нет, сейчас на ней размер макс.таблицы трасляций - 25000 строк):
ip cef
controller E1 1/0
framing NO-CRC4
channel-group 0 timeslots 1-31
description To Rostelecom
controller E1 1/1
shutdown
interface FastEthernet1/0
description To Local
ip address 10.1.2.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip mroute-cache
speed 10
half-duplex
hold-queue 4096 in
hold-queue 4096 out
interface Serial1/0:0
ip address 94.хх.хх.94 255.255.255.252
ip access-group 110 out
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no fair-queue
hold-queue 4096 in
hold-queue 4096 out
ip nat translation timeout 1800
ip nat translation tcp-timeout 1800
ip nat translation udp-timeout 150
ip nat translation max-entries 25000
ip nat pool to_rt2 94.хх.хх.94 94.хх.хх.94 netmask 255.255.255.252
ip nat inside source list 100 pool to_rt2 overload
ip classless
ip route 0.0.0.0 0.0.0.0 94.хх.хх.93 100
ip route 10.1.3.0 255.255.255.0 10.1.2.1
no ip http server
access-list 100 permit ip 10.1.3.0 0.0.0.255 any
access-list 100 deny ip any any
access-list 110 deny ip 10.1.3.0 0.0.0.255 any
access-list 110 permit ip any any
Особо интересуют вот эти параметры:
Сколько юзеров за НАТом потянет такая циска? Какова оптимальный размер таблицы НАТа на ней? Оптимальные параметры таймаутов?
Вы задаёте эфимерный вопрос =) Будет работать пока память есть... сколько ж Вы хотите запихнуть пользователей в e1?
Привет Андрей. вижу ты так и мучаешься с этим вопром :).
Ну смотри, вот что есть на cisco.com
Q. How many concurrent NAT sessions are supported in Cisco IOS NAT?
A.
The NAT session limit is bounded by the amount of available DRAM in the router.
Each NAT translation consumes about 312 bytes in DRAM.
As a result, 10,000 translations (more than would generally be handled on a single router) would consume about 3 MB.
Therefore, typical routing hardware has more than enough memory to support thousands of NAT translations.
(http://www.cisco.com/en/US/tech/tk648/tk361/technologies_q_and_a_item09186a00800e523b.shtml)
говоря по русски - в раутерах нет ограничений на таблицу nat транляций (они есть в cat6500). Всё заканчивается гораздо раньше из-за нехватки либо CPU либо RAM.
Если хочешь потюнить NAT то почитай вот:
http://www.cisco.com/en/US/docs/ios/12_3t/...e/gt_natrl.html
в ограничениях на nat entries можно вставлять ACL ;)
Плюс, порядок обработки пакетов при работе с NAT:
http://www.cisco.com/en/US/tech/tk648/tk36...080133ddd.shtml
Плюс, рыская в своё время на cisco.com на предмет этого же вопроса, я встречал картинку с описанием в котором фигурировала вот такая информация:
NAT would handle the routing to the host similar to PBR.
Но это. сам понимаешь, очень смахивает на "вилами по воде"
Edited by boombastic
Это как раз понятно.
Когда память кончится, будет уже поздно. Потому и стоит
Пошейпленных до 64К или 128К - до 40-50 одновременных. Вполне по божески.
Это прочел в 1ю очередь, но ответов на свои вопросы не нашел.
Это уже ближе к истине. Почитаю.
вывод, меняй IOS
p.s. JFYI: Поддержка 12.3 Mainline закончилась 15.03.2008.
Я бы на твоём месте обновил до 12.3.26 и "жил" пока 3620 не помрёт окончательно
