ситуация, есть клиенты с WinVista и роутерами Asus и Длинк. Каждые 1.5 минуты у
них рвется впн соединение, с WinXP и остальной половиной маршрутизаторов все
работает.
в какую сторону копать?
ОС Debian ETCH
pptpd-1.3.0
pppd-2.4.4
В логе асус пишет:
--------------------asus
logfile---------------------------------------------------------------
Dec 15 21:29:48 pppd[60]: Starting link
Dec 15 21:29:48 pppd[60]: Serial connection established.
Dec 15 21:29:48 pppd[60]: Connect: ppp0 <--> /dev/pts/0
Dec 15 21:29:55 pppd[60]: CHAP authentication succeeded
Dec 15 21:29:55 pppd[60]: Received bad configure-ack:
Dec 15 21:29:55 PPTP: connect to ISP
Dec 15 21:30:25 pppd[60]: CCP: timeout sending Config-Requests
Dec 15 21:31:05 pppd[60]: No response to 6 echo-requests
Dec 15 21:31:05 pppd[60]: Serial link appears to be disconnected.
Dec 15 21:31:05 PPTP: Disconnected
Dec 15 21:31:11 pppd[60]: Connection terminated.
Dec 15 21:31:11 pppd[60]: Connect time 1.3 minutes.
Dec 15 21:31:11 pppd[60]: Sent 172373 bytes, received 1123445 bytes.
Dec 15 21:31:11 pptp[106]: short read (-1): Input/output error
Dec 15 21:31:11 pptp[106]: pppd may have shutdown, see pppd log
На сервере:
---------------------------------log--------------------------------------------
Dec 15 21:53:53 gw1-nat pppd[6995]: Accounting START failed for uvpn1183
Dec 15 21:53:53 gw1-nat pppd[6995]: rcvd [LCP TermReq id=0x84 "Peer not
responding"]
Dec 15 21:53:53 gw1-nat pppd[6995]: LCP terminated by peer (Peer not
responding)
Dec 15 21:53:53 gw1-nat pppd[6995]: pptpd-logwtmp.so ip-down ppp403
Dec 15 21:53:53 gw1-nat pppd[6995]: Connect time 1.5 minutes.
Dec 15 21:53:53 gw1-nat pppd[6995]: Sent 46506 bytes, received 6471 bytes.
Dec 15 21:53:53 gw1-nat pppd[7378]: sent [LCP ConfReq id=0x2 <mru 1462>
<asyncmap 0x0> <auth chap MD5> <magic 0xa4a0466c> <pcomp> <accomp>]
Dec 15 21:53:53 gw1-nat pppd[7378]: rcvd [LCP ConfReq id=0x71 <mru 1400>
<asyncmap 0x0> <magic 0x469bb771> <pcomp> <accomp>]
Dec 15 21:53:53 gw1-nat pppd[7378]: sent [LCP ConfAck id=0x71 <mru 1400>
Dec 15 21:53:53 gw1-nat pppd[6995]: sent [LCP TermAck id=0x84]
Dec 15 21:53:53 gw1-nat pppd[6995]: rcvd [LCP TermReq id=0x85 "Peer not
responding"]
Dec 15 21:53:53 gw1-nat pppd[6995]: sent [LCP TermAck id=0x85]
Dec 15 21:53:53 gw1-nat pppd[6995]: Modem hangup
Dec 15 21:53:53 gw1-nat pppd[6995]: Connection terminated.
Dec 15 21:53:54 gw1-nat pptpd[7032]: CTRL: Reaping child PPP[7033]
Dec 15 21:53:55 gw1-nat pppd[7418]: rcvd [LCP ConfRej id=0x1 <asyncmap 0x0>
<pcomp>]
Dec 15 21:53:55 gw1-nat pppd[7418]: sent [LCP ConfReq id=0x2 <mru 1462> <auth
chap MD5> <magic 0x48230e55> <accomp>]
Dec 15 21:53:55 gw1-nat pppd[7418]: rcvd [LCP ConfReq id=0x90 <mru 1460> <magic
0x2a2e6f15>]
Dec 15 21:53:55 gw1-nat pppd[7418]: sent [LCP ConfAck id=0x90 <mru 1460> <magic
0x2a2e6f15>]
Dec 15 21:53:55 gw1-nat pppd[7418]: rcvd [proto=0x806] 00 01 08 00 06 04 00 01
00 1b 24 8d 17 f5 0a 58 37 f9 00 00 00 00 00 00 0a 58 58 01 00 00 00 00 ...
Dec 15 21:53:55 gw1-nat pppd[7418]: Discarded non-LCP packet when LCP not open
Dec 15 21:53:55 gw1-nat pppd[7418]: rcvd [LCP ConfAck id=0x2 <mru 1462> <auth
Dec 15 21:53:55 gw1-nat pppd[7418]: sent [LCP EchoReq id=0x0 magic=0x48230e55]
Dec 15 21:53:55 gw1-nat pppd[7418]: sent [CHAP Challenge id=0x6b
<ebe06770317c724d9a44dacb39a0bb2e954ac5>, name = "pptpd"]
Dec 15 21:53:55 gw1-nat pppd[7418]: rcvd [LCP EchoRep id=0x0 magic=0x2a2e6f15]
Dec 15 21:53:55 gw1-nat pppd[7418]: rcvd [CHAP Response id=0x6b
<a73f03fa8b90a10d4764a95f4aedcf89>, name = "uvpn293"]
Dec 15 21:53:55 gw1-nat pppd[7010]: rc_send_server: no reply from RADIUS server
localhost:1813
Dec 15 21:53:55 gw1-nat pppd[7010]: Accounting START failed for uvpn200
Dec 15 21:53:55 gw1-nat pppd[7010]: rcvd [LCP TermReq id=0x73 "Peer not
responding"]
Dec 15 21:53:55 gw1-nat pppd[7010]: LCP terminated by peer (Peer not
responding)
Dec 15 21:53:55 gw1-nat pppd[7010]: pptpd-logwtmp.so ip-down ppp241
Dec 15 21:53:55 gw1-nat pppd[7010]: Connect time 1.5 minutes.
Dec 15 21:53:55 gw1-nat pppd[7010]: Sent 21200989 bytes, received 1668799
bytes.
Dec 15 21:53:55 gw1-nat pppd[7010]: sent [LCP TermAck id=0x73]
Dec 15 21:53:55 gw1-nat pppd[7010]: rcvd [LCP TermReq id=0x74 "Peer not
responding"]
Dec 15 21:53:55 gw1-nat pppd[7010]: sent [LCP TermAck id=0x74]
Dec 15 21:53:55 gw1-nat pppd[7010]: Modem hangup
Dec 15 21:53:55 gw1-nat pppd[7010]: Connection terminated.
-----options-pptpd----
#pptpd config file
name pptpd
debug
refuse-eap
refuse-pap
require-chap
require-mschap
require-mschap-v2
nomppe
idle 0
lcp-echo-failure 5
lcp-echo-interval 10
ms-dns 10.88.88.1
ms-dns 10.88.88.53
proxyarp
nodefaultroute
lock
nobsdcomp
novj
novjccomp
nodeflate
mtu 1462
mru 1462
plugin radius.so
если сделать tcpdump на одного из клиентов, то видим
22:04:37.649299 IP 10.88.51.229 > 10.88.88.8: GREv1, call 25088, ack 15,
no-payload, length 12
22:04:37.649918 IP 10.88.51.229 > 10.88.88.8: GREv1, call 25088, seq 17, length
53: IP 192.168.51.229 > 224.0.0.22: igmp v3 report, 1 group record(s)
22:04:37.701708 IP 10.88.88.8 > 10.88.51.229: GREv1, call 4846, ack 17,
22:05:02.561224 IP 10.88.51.229 > 10.88.88.8: GREv1, call 25088, seq 18, length
22: LCP, Echo-Request (0x09), id 1, length 10
22:05:02.613890 IP 10.88.88.8 > 10.88.51.229: GREv1, call 4846, ack 18,
далее обрыв
Denis Samsonov
Хм.. очень странно (
ну у меня была ситуация, когда траффик "тунеля" пробовал уйти в тунель, т.е. завернуться сам в себя (именно с Вистой) (я думаю, Вы поняли что я имел ввиду)
Других проблем вроде не было...
Denis Samsonov
Такая ситуация бывает когда они в разных сетях находятся, а тут тупо в одно сети....
На LCP Echo request модемы не отвечают. Смотри снифер нужно анализировать пакет за пакетом.
