armagon Posted December 25, 2008 · Report post Да и еще вопрос, с каких это пор на каталистах только MSTP? Share this post Link to post Share on other sites
kostas Posted December 25, 2008 · Report post #sh ver Cisco Internetwork Operating System Software IOS (tm) c6sup1_rp Software (c6sup1_rp-PK2S-M), Version 12.1(27b)E, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2006 by cisco Systems, Inc. Compiled Fri 10-Feb-06 23:02 by hqluong Image text-base: 0x60020F90, data-base: 0x618C8000 ROM: System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE BOOTLDR: MSFC Software (C6MSFC-BOOT-M), Version 12.0(7)XE1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Core uptime is 6 days, 2 hours, 42 minutes Time since Core switched to active is 6 days, 2 hours, 41 minutes System returned to ROM by power-on (SP by power-on) System restarted at 10:59:10 MSK Fri Dec 19 2008 System image file is "sup-bootflash:c6sup11-pk2s-mz.121-27b.E.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco WS-C6506 (R5000) processor (revision 2.0) with 114688K/16384K bytes of memory. Processor board ID TBA05040254 R5000 CPU at 200Mhz, Implementation 35, Rev 2.1 Last reset from power-on X.25 software, Version 3.0.0. Bridging software. 7 Virtual Ethernet/IEEE 802.3 interface(s) 18 Gigabit Ethernet/IEEE 802.3 interface(s) 381K bytes of non-volatile configuration memory. 4096K bytes of packet SRAM memory. 16384K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102 STP не вижу. По умолчанию PVST. #spanning-tree mode ? mst Multiple spanning tree mode pvst Per-Vlan spanning tree mode rapid-pvst Per-Vlan rapid spanning tree mode Share this post Link to post Share on other sites
D^2 Posted December 25, 2008 · Report post * SWITCH1 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:90:1f Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: TRUE Number of Topology Changes: 5 Time Since Last Topology Change: 103s * SWITCH2 ## sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:9a:4b Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 5 Time Since Last Topology Change: 91s Router#sh spanning-tree VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0003.fdd3.7801 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0003.fdd3.7801 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/1 Desg FWD 4 128.65 P2p Gi2/2 Desg FWD 4 128.66 P2p Router#sh spanning-tree detail VLAN0001 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0003.fdd3.7801 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 8 last change occurred 00:02:43 ago from GigabitEthernet2/1 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 1, topology change 0, notification 0, aging 300 Port 65 (GigabitEthernet2/1) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.65. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.65, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 84, received 2 Port 66 (GigabitEthernet2/2) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.66. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.66, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 707, received 162 Router# кольцо замкнуто из 3-х коммутаторов. при размыкании линка от каталиста к Экстриму * SWITCH1 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:90:1f Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: TRUE Number of Topology Changes: 6 Time Since Last Topology Change: 12s * SWITCH2 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:9a:4b Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 23 Root Port: 24 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 6 Time Since Last Topology Change: 55s Router#sh spanning-tree VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0003.fdd3.7801 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0003.fdd3.7801 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/2 Desg FWD 4 128.66 P2p Router#sh span det VLAN0001 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0003.fdd3.7801 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 9 last change occurred 00:02:03 ago from GigabitEthernet2/1 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 1, topology change 0, notification 0, aging 300 Port 66 (GigabitEthernet2/2) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.66. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.66, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 850, received 163 Router# Share this post Link to post Share on other sites
armagon Posted December 25, 2008 · Report post Извиняюсь. На MST00 то же самое сделайтеСделал #sh spanning-tree mst ###### MST00 vlans mapped: none Bridge address 0004.de18.b400 priority 24576 (24576 sysid 0) Root this switch for CST and IST Configured hello time 2, forward delay 15, max age 20, max hops 20 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/3 Desg FWD 20000 128.67 P2p Bound(STP) Gi2/4 Desg FWD 20000 128.68 P2p Bound(STP) ###### MST01 vlans mapped: 1-4094 Bridge address 0004.de18.b400 priority 24577 (24576 sysid 1) Root this switch for MST01 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/3 Boun FWD 20000 128.67 P2p Bound(STP) Gi2/4 Boun FWD 20000 128.68 P2p Bound(STP) Но каталист подох практически сразу после открытия порта 2/4 - скорее всего комутаторы опять не увидели его рутом. А что в данном случае значит подох? Информацию ты ж с него снял как-то. Share this post Link to post Share on other sites
kostas Posted December 25, 2008 · Report post А что в данном случае значит подох? Информацию ты ж с него снял как-то.Просто начались тормоза жуткие, получилось снять один раз :) А вот интересный тест провел D^2 постом выше. Судя по логам кольцо действительно работает, при чем не в MST режиме. Жаль только он не привел настройки STP на каталисте, потому как они очень интересны в этом случае. Сейчас попробовал сделать подобное у себя - все комытаторы на всякий случай перенес в stp дерево s0, как на этом примере. Отключил режим MST на каталисте. Картинка на каталисте похожа, кольцо замыкать пока не стал, дабы не положить каталист. #sh spanning-tree VLAN0003 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0004.de18.b403 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0004.de18.b403 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/3 Desg FWD 4 128.67 P2p VLAN0004 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0004.de18.b404 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0004.de18.b404 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/3 Desg FWD 4 128.67 P2p #sh spanning-tree detail active VLAN0003 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0004.de18.b403 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 4 last change occurred 02:01:36 ago from GigabitEthernet2/5 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 1, topology change 0, notification 0, aging 300 Port 67 (GigabitEthernet2/3) of VLAN0003 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.67. Designated root has priority 8192, address 0004.de18.b403 Designated bridge has priority 8192, address 0004.de18.b403 Designated port id is 128.67, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 4549, received 0 VLAN0004 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0004.de18.b404 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 1 last change occurred 02:31:09 ago from GigabitEthernet2/2 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 1, topology change 0, notification 0, aging 300 Port 67 (GigabitEthernet2/3) of VLAN0004 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.67. Designated root has priority 8192, address 0004.de18.b404 Designated bridge has priority 8192, address 0004.de18.b404 Designated port id is 128.67, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 4560, received 0 Настройки STP на каталисте теперь выглядят так. Оба вилана в транке пущены в кольцо (в данном случае полукольцо). spanning-tree mode pvst no spanning-tree vlan 2 spanning-tree vlan 3-4 priority 8192 Теперь смотрим что же на комутаторах. Ближайший к каталисту SW1. Summit24e3:1 # sh stpd s0 Stpd: s0 Stp: ENABLED Number of Ports: 2 Rapid Root Failover: Disabled Ports: 25,26 Vlans: Default MacVlanDiscover Manage Office Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:a7:e4 Designated root: 80:00:00:01:30:11:8e:00 RootPathCost: 4 Root Port: 25 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 4 Time Since Last Topology Change: 3946s Опять это пресловутый 80:00:00:01:30:11:8e:00 второй комутатор. Опять он рут. Смотрим на него - SW2. # sh stpd s0 Stpd: s0 Stp: ENABLED Number of Ports: 2 Rapid Root Failover: Disabled Ports: 25,26 Vlans: Default MacVlanDiscover Manage Office Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:8e:00 Designated root: 80:00:00:01:30:11:8e:00 RootPathCost: 0 Root Port: ---- MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 4 Time Since Last Topology Change: 4510s Так и есть - рут. Ничего уже не понимаю :( Share this post Link to post Share on other sites
John_obn Posted December 25, 2008 · Report post 2 kostas: Вы пробовали отключать режим MSTP на SW*? Я так понял, у Вас сейчас каталист работает в режиме PVST, а остальные коммутаторы в MSTP. У меня работает немного другая схема, но суть та же: catalyst1---edge-core---catalyst2 \__________________/ Была схема, где подряд шли несколько edge-core. Настройки на каталистах - режим везде pvst, а на edge-core обычный stp (может даже rstp, завтра гляну). Попробуйте на SW* поставить режим stp. Share this post Link to post Share on other sites
Oleg_S Posted December 26, 2008 · Report post #sh ver Cisco Internetwork Operating System Software IOS (tm) c6sup1_rp Software (c6sup1_rp-PK2S-M), Version 12.1(27b)E, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2006 by cisco Systems, Inc. Compiled Fri 10-Feb-06 23:02 by hqluong Image text-base: 0x60020F90, data-base: 0x618C8000 ROM: System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE BOOTLDR: MSFC Software (C6MSFC-BOOT-M), Version 12.0(7)XE1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Core uptime is 6 days, 2 hours, 42 minutes Time since Core switched to active is 6 days, 2 hours, 41 minutes System returned to ROM by power-on (SP by power-on) System restarted at 10:59:10 MSK Fri Dec 19 2008 System image file is "sup-bootflash:c6sup11-pk2s-mz.121-27b.E.bin" kostas, судя по имиджу, у Вас IOS не поддерживает: IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance Это такая заморочка у Cisco, есть две фичи: IEEE 802.1s VLAN Multiple Spanning TreesThis feature is the original implementation of MST which is based on a pre-standards draft. MST allows you to build multiple spanning trees over trunks. You can group and associate VLANs to spanning tree instances. Each instance can have a topology independent of other spanning tree instances. This new architecture provides multiple forwarding paths for data traffic and enables load balancing. Network fault tolerance is improved because a failure in one instance (forwarding path) does not affect other instances (forwarding paths). и IEEE 802.1s - Multiple Spanning Tree (MST) Standard ComplianceMST extends the 802.1w Rapid Spanning Tree to multiple spanning trees, providing rapid convergence and load balancing. В вашем иосе есть только первая, второй нет, подробнее - http://www.cisco.com/go/fn Я не знаю какой у вас супервизор, FN выдает, что ваш имидж может работать как на sup1/mfsc1, так и на sup2/mfsc2 Если у Вас sup2, то вам надо - 12.2SXF иос, чтобы поддерживался MSTP Standard Compliance, если же sup1, то, судя по FN, поддержки нормального MSTP у вас не будет. PS. Сами с таким сталкивались, после того как не заработал MSTP между cat4500, edge-core 4612 и dlink 3526 Share this post Link to post Share on other sites
kostas Posted December 26, 2008 · Report post 2 kostas: Вы пробовали отключать режим MSTP на SW*? Я так понял, у Вас сейчас каталист работает в режиме PVST, а остальные коммутаторы в MSTP. У меня работает немного другая схема, но суть та же:catalyst1---edge-core---catalyst2 \__________________/ Была схема, где подряд шли несколько edge-core. Настройки на каталистах - режим везде pvst, а на edge-core обычный stp (может даже rstp, завтра гляну). Попробуйте на SW* поставить режим stp. В том то и дело, что на SW* только STP и поддерживается, там другого не дано :( Share this post Link to post Share on other sites
kostas Posted December 26, 2008 · Report post kostas, судя по имиджу, у Вас IOS не поддерживает:IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance Это такая заморочка у Cisco, есть две фичи: IEEE 802.1s VLAN Multiple Spanning TreesThis feature is the original implementation of MST which is based on a pre-standards draft. MST allows you to build multiple spanning trees over trunks. You can group and associate VLANs to spanning tree instances. Each instance can have a topology independent of other spanning tree instances. This new architecture provides multiple forwarding paths for data traffic and enables load balancing. Network fault tolerance is improved because a failure in one instance (forwarding path) does not affect other instances (forwarding paths). и IEEE 802.1s - Multiple Spanning Tree (MST) Standard ComplianceMST extends the 802.1w Rapid Spanning Tree to multiple spanning trees, providing rapid convergence and load balancing. В вашем иосе есть только первая, второй нет, подробнее - http://www.cisco.com/go/fn Я не знаю какой у вас супервизор, FN выдает, что ваш имидж может работать как на sup1/mfsc1, так и на sup2/mfsc2 Если у Вас sup2, то вам надо - 12.2SXF иос, чтобы поддерживался MSTP Standard Compliance, если же sup1, то, судя по FN, поддержки нормального MSTP у вас не будет. PS. Сами с таким сталкивались, после того как не заработал MSTP между cat4500, edge-core 4612 и dlink 3526 О как, интересно. Т.е. у циски есть два стандарта, которые называются одинаково, но трактуются по разному? :) Супервизор у меня sup1/mfsc1. Интересно, D^2 а у вас какой супервизор на лабе стоял и с каким IOS? Share this post Link to post Share on other sites
D^2 Posted December 26, 2008 · Report post sup2/msfc System image file is "sup-bootflash:c6sup22-pk2o3sv-mz.121-26.E9.bin" отличие настроек от дефолтных в 2-х строчках conf t span vl 1 span vl 1 root IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance как я понимаю для того, чтобы в каждой Instance RSTP крутился. В IEEE 802.1s VLAN Multiple Spanning Trees крутится STP. Share this post Link to post Share on other sites
kostas Posted December 26, 2008 · Report post Oleg_S, можно с вами как-то связаться? Не совсем улавливаю, в чем различия того о чем вы писали. Уже надежда начала пропадать в решении этой проблемы. В НАГе собирали лабу и все у них работает. Различие супервизора налицо (у них был sup2), но принципиальных различий там не признают. Дмитрий из НАГа к сожалению не прокомментировал Вашу версию, постараюсь завтра его еще раз обратить внимание на этот момент. Очень не хотелось бы тратить деньги на другой супервизор только ради проверки этой версии. Share this post Link to post Share on other sites
kostas Posted December 26, 2008 · Report post sup2/msfcSystem image file is "sup-bootflash:c6sup22-pk2o3sv-mz.121-26.E9.bin" отличие настроек от дефолтных в 2-х строчках conf t span vl 1 span vl 1 root IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance как я понимаю для того, чтобы в каждой Instance RSTP крутился. В IEEE 802.1s VLAN Multiple Spanning Trees крутится STP. Все так оно и есть, кроме супервизора. Share this post Link to post Share on other sites
armagon Posted December 26, 2008 · Report post sup2/msfcSystem image file is "sup-bootflash:c6sup22-pk2o3sv-mz.121-26.E9.bin" отличие настроек от дефолтных в 2-х строчках conf t span vl 1 span vl 1 root IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance как я понимаю для того, чтобы в каждой Instance RSTP крутился. В IEEE 802.1s VLAN Multiple Spanning Trees крутится STP. Все так оно и есть, кроме супервизора. Не надо ничего покупать, просто вместо pre-standard MST на каталисте используй PVST Share this post Link to post Share on other sites
kostas Posted December 26, 2008 (edited) · Report post Не надо ничего покупать, просто вместо pre-standard MST на каталисте используй PVSTМмм, как? PVST это разве не собственный стандарт циски с которым другое оборудование не живет? Но в любом случае сейчас конфиг каталиста выглядит так spanning-tree mode pvst spanning-tree vlan 3-4 priority 8192 #sh spa detail VLAN0003 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0004.de18.b403 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 6 last change occurred 02:45:32 ago from GigabitEthernet2/3 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 0, topology change 0, notification 0, aging 300 Port 67 (GigabitEthernet2/3) of VLAN0003 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.67. Designated root has priority 8192, address 0004.de18.b403 Designated bridge has priority 8192, address 0004.de18.b403 Designated port id is 128.67, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 4980, received 0 Как раз стоит PVST (по умолчанию), в общем-то так на стенде у НАГа и работало, а у меня нет. На комутаторах кольца ничего кроме стандартного STP не поддерживается. Чего-то я совсем уже запутался... Edited December 26, 2008 by kostas Share this post Link to post Share on other sites
Oleg_S Posted December 26, 2008 · Report post 2kostas: в двух словах Pre-Standard MST и 802.1s MST - не совместимы. То, что мы наблюдали: два одинаково сконфигурированных бриджа (cat4500 sup2 и edge-core 4612) не видят друг друга. Считали что они находятся в разных регионах. С помощью wireshark было установлено, что BPDU-шки от циско и от эджкора имеют разные чексумы, и свитчи работают согласно: MST BPDUs contain the MST configuration ID and the checksum. An MST bridge accepts an MST BPDU only if the MST BPDU configuration ID and the checksum match its own MST region configuration ID and checksum. If one value is different, the MST BPDU is considered to be an SST BPDU. © cisco Изучение Feature Navigator'а привело к тому, что выше я уже писал: у циско есть две реализации MST - prestandard и standard. Вам нужна поддержка standard 802.1s MST на вашем sup'е для совместимости с другим свитчами не-циско. http://www.ciscosystems.com/en/US/docs/swi.../guide/mst.html: The IEEE MST protocol has transitioned from a prestandard state to a released state. This chapter describes the standard-compliant MST implementation supported in Release 12.2(18)SXF and later releases. Chapter 20, "Configuring STP and Prestandard IEEE 802.1s MST," describes the prestandard MST implementation supported in releases earlier than Release 12.2(18)SXF. Из вышенаписанного следует, что вам нужен ios не ниже 12.2(18)SXF. Но, к сожалению, похоже, что для sup1 такого не бывает. Share this post Link to post Share on other sites
kostas Posted December 27, 2008 (edited) · Report post The IEEE MST protocol has transitioned from a prestandard state to a released state. This chapter describes the standard-compliant MST implementation supported in Release 12.2(18)SXF and later releases. Chapter 20, "Configuring STP and Prestandard IEEE 802.1s MST," describes the prestandard MST implementation supported in releases earlier than Release 12.2(18)SXF.Из вышенаписанного следует, что вам нужен ios не ниже 12.2(18)SXF. Но, к сожалению, похоже, что для sup1 такого не бывает. Ага, понял. Олег, спасибо огромное, было подозрение в несовместимости изначально, так оно похоже и есть. НАГ в понедельник подтвердит эти предположения, собрав лабу на sup1 и моей прошивкой. Если эффект будет тот же, чем я практически не сомневаюсь, то будем брать sup2... там и ip unnumbered есть, что в нашем случае будет хорошим плюсом. Edited December 27, 2008 by kostas Share this post Link to post Share on other sites
D^2 Posted December 29, 2008 (edited) · Report post кольцо не замкнуто 6506+sup1a Router#sh mod Mod Ports Card Type Model Serial No. --- ----- -------------------------------------- ------------------ ----------- 2 2 Cat 6k sup 1 Enhanced QoS (Active) WS-X6K-SUP1A-2GE SAD04210F7T Mod MAC addresses Hw Fw Sw Status --- ---------------------------------- ------ ------------ ------------ ------- 2 0030.96b1.3d44 to 0030.96b1.3d45 3.1 5.3(1) 12.1(27b)E Ok Mod Sub-Module Model Serial Hw Status --- --------------------------- --------------- --------------- ------- ------- 2 Policy Feature Card WS-F6K-PFC SAD04280US8 1.1 Ok 2 MSFC Cat6k daughterboard WS-F6K-MSFC SAD04030B8P 1.3 Ok Mod Online Diag Status --- ------------------- Router#sh span VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0003.fdd3.7801 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0003.fdd3.7801 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/1 Desg FWD 4 128.65 P2p Gi2/2 Desg FWD 4 128.66 P2p Router#sh span det VLAN0001 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0003.fdd3.7801 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 3 last change occurred 00:02:31 ago from GigabitEthernet2/2 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 1, topology change 0, notification 0, aging 300 Port 65 (GigabitEthernet2/1) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.65. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.65, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 207, received 2 Port 66 (GigabitEthernet2/2) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.66. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.66, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 206, received 2 Router# Switch 2 * Summit24e3:5 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:9a:4b Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 1 Time Since Last Topology Change: 133s Switch 3 * Summit24e3:5 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:90:1f Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: TRUE Number of Topology Changes: 0 Time Since Last Topology Change: 3s замыкаем кольцо 6506 Router#sh span VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0003.fdd3.7801 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0003.fdd3.7801 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/1 Desg FWD 4 128.65 P2p Gi2/2 Desg FWD 4 128.66 P2p Router#sh span det VLAN0001 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0003.fdd3.7801 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 4 last change occurred 00:08:56 ago from GigabitEthernet2/2 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 1, topology change 0, notification 0, aging 300 Port 65 (GigabitEthernet2/1) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.65. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.65, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 516, received 2 Port 66 (GigabitEthernet2/2) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.66. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.66, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 516, received 3 Router# Switch2 * Summit24e3:10 # sh def VLAN Interface[0-200] with name "Default" created by user Tagging: 802.1Q Tag 1 Priority: 802.1P Priority 0 IP: 1.1.1.2/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 26. (Number of active ports = 1) Flags: * = active, ! = disabled Untag: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24* 25 26* Protected by 0 count of EAPS Domains * Summit24e3:11 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:9a:4b Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 1 Time Since Last Topology Change: 671s Switch3 * Summit24e3:6 # sh def VLAN Interface[0-200] with name "Default" created by user Tagging: 802.1Q Tag 1 Priority: 802.1P Priority 0 IP: 1.1.1.3/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 26. (Number of active ports = 2) Flags: * = active, ! = disabled Untag: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24* 25 26* Protected by 0 count of EAPS Domains * Summit24e3:7 # sh stp Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:90:1f Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 2 Time Since Last Topology Change: 478s * Summit24e3:8 # размыкаем кольцо Router Router# sh span VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0003.fdd3.7801 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0003.fdd3.7801 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/1 Desg FWD 4 128.65 P2p Router#sh span det VLAN0001 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0003.fdd3.7801 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 6 last change occurred 00:02:23 ago from GigabitEthernet2/1 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 1, topology change 0, notification 0, aging 300 Port 65 (GigabitEthernet2/1) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.65. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.65, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 76, received 4 Router# Switch2 * Summit24e3:12 # sh def VLAN Interface[0-200] with name "Default" created by user Tagging: 802.1Q Tag 1 Priority: 802.1P Priority 0 IP: 1.1.1.2/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 26. (Number of active ports = 2) Flags: * = active, ! = disabled Untag: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24* 25 26* Protected by 0 count of EAPS Domains * Summit24e3:13 # sh stp Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:9a:4b Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 6 Time Since Last Topology Change: 39s * Summit24e3:14 # Switch3 * Summit24e3:27 # sh def VLAN Interface[0-200] with name "Default" created by user Tagging: 802.1Q Tag 1 Priority: 802.1P Priority 0 IP: 1.1.1.3/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 26. (Number of active ports = 1) Flags: * = active, ! = disabled Untag: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24* 25 26 Protected by 0 count of EAPS Domains * Summit24e3:28 # sh stp Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:90:1f Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 23 Root Port: 24 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: TRUE Number of Topology Changes: 4 Time Since Last Topology Change: 15s * Summit24e3:29 # Router#sh run Building configuration... Current configuration : 789 bytes ! version 12.1 service timestamps debug uptime service timestamps log uptime no service password-encryption service counters max age 10 ! hostname Router ! boot bootldr bootflash:c6msfc-boot-mz.121-27b.E.bin ! ip subnet-zero ! ! ! ip ssh time-out 120 ip ssh authentication-retries 3 mls flow ip destination mls flow ipx destination ! ! ! spanning-tree mode pvst spanning-tree vlan 1 priority 8192 ! redundancy mode rpr-plus main-cpu auto-sync running-config auto-sync standard ! ! ! interface GigabitEthernet2/1 switchport switchport mode access switchport nonegotiate ! interface GigabitEthernet2/2 switchport switchport mode access switchport nonegotiate ! interface Vlan1 ip address 1.1.1.1 255.0.0.0 ! ip classless no ip http server ! ! ! line con 0 line vty 0 4 ! ! end Router# * Summit24e3:14 # sh ver System Serial Number: 800096-04-0234R00703 CPU Serial Number: 700048-08 0233R-01936 CPLD Rev 02 Image : Extremeware Version 6.2e.1 (Build 15) by Release_Master_ABU Tue 08/13/ 2002 14:50:31 BootROM : 1.3 Router#sh ver Cisco Internetwork Operating System Software IOS (tm) c6sup1_rp Software (c6sup1_rp-PK2S-M), Version 12.1(27b)E, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2006 by cisco Systems, Inc. Compiled Fri 10-Feb-06 23:02 by hqluong Image text-base: 0x60020F90, data-base: 0x618C8000 ROM: System Bootstrap, Version 12.0(3)XE, RELEASE SOFTWARE BOOTLDR: MSFC Software (C6MSFC-BOOT-M), Version 12.1(27b)E, RELEASE SOFTWARE (fc2) Router uptime is 33 minutes Time since Router switched to active is 30 minutes System returned to ROM by power-on (SP by power-on) System image file is "sup-bootflash:c6sup11-pk2s-mz.121-27b.E.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco WS-C6506 (R5000) processor (revision 2.0) with 114688K/16384K bytes of memory. Processor board ID TBA04420431 R5000 CPU at 200Mhz, Implementation 35, Rev 2.1 Last reset from power-on X.25 software, Version 3.0.0. Bridging software. 1 Virtual Ethernet/IEEE 802.3 interface(s) 2 Gigabit Ethernet/IEEE 802.3 interface(s) 381K bytes of non-volatile configuration memory. 4096K bytes of packet SRAM memory. 16384K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102 Router# Edited December 29, 2008 by D^2 Share this post Link to post Share on other sites
kostas Posted December 29, 2008 · Report post D^2, спасибо огромное за тесты! Но вы меня ставите в тупик... :) Если вы еще не разобрали лабу, можно попросить интерфейсы gi2/1 и gi2/2 переключить в транк? interface GigabitEthernet2/1 switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan 1 switchport mode trunk Больше отличий я не вижу. Ну разве что прошивка на экстримах слегка другая, но она по крайней мере новее :) Summit24e3:3 # sh ver System Serial Number: Summit24e3 800096-01-04 0248R-01009 CLEI: QC: CP:02 CPU ID: 700048-00-08 0248R-00199 CP:02 Image : Extremeware Version 6.2e.1 (Build 20) by Release_Master_ABU Tue 05/27/2003 16:46:08 BootROM : 1.3 Ничего не понимаю, маразм какой-то... Share this post Link to post Share on other sites
D^2 Posted December 29, 2008 · Report post 6506 Router#sh run Building configuration... Current configuration : 953 bytes ! version 12.1 service timestamps debug uptime service timestamps log uptime no service password-encryption service counters max age 10 ! hostname Router ! boot bootldr bootflash:c6msfc-boot-mz.121-27b.E.bin ! ip subnet-zero ! ! ! ip ssh time-out 120 ip ssh authentication-retries 3 mls flow ip destination mls flow ipx destination ! ! ! spanning-tree mode pvst spanning-tree vlan 1 priority 8192 ! redundancy mode rpr-plus main-cpu auto-sync running-config auto-sync standard ! ! ! interface GigabitEthernet2/1 switchport switchport trunk encapsulation dot1q switchport trunk native vlan 999 switchport trunk allowed vlan 1 switchport mode trunk ! interface GigabitEthernet2/2 switchport switchport trunk encapsulation dot1q switchport trunk native vlan 999 switchport trunk allowed vlan 1 switchport mode trunk ! interface Vlan1 ip address 1.1.1.1 255.255.255.0 ! ip classless no ip http server ! ! ! line con 0 line vty 0 4 ! ! end Router#sh span VLAN0001 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0003.fdd3.7801 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0003.fdd3.7801 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/1 Desg FWD 4 128.65 P2p Gi2/2 Desg FWD 4 128.66 P2p Router# sh span det VLAN0001 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0003.fdd3.7801 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 3 last change occurred 00:02:36 ago from GigabitEthernet2/2 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 0, topology change 0, notification 0, aging 300 Port 65 (GigabitEthernet2/1) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.65. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.65, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 525, received 1 Port 66 (GigabitEthernet2/2) of VLAN0001 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.66. Designated root has priority 8192, address 0003.fdd3.7801 Designated bridge has priority 8192, address 0003.fdd3.7801 Designated port id is 128.66, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 661, received 6 Router# Switch2 * Summit24e3:13 # sh def VLAN Interface[0-200] with name "Default" created by user Tagging: 802.1Q Tag 1 Priority: 802.1P Priority 0 IP: 1.1.1.2/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 26. (Number of active ports = 1) Flags: * = active, ! = disabled Untag: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 25 Tagged: 24* 26* Protected by 0 count of EAPS Domains * Summit24e3:14 # sh stp Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:9a:4b Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: TRUE Number of Topology Changes: 2 Time Since Last Topology Change: 362s Switch3 * Summit24e3:46 # sh def VLAN Interface[0-200] with name "Default" created by user Tagging: 802.1Q Tag 1 Priority: 802.1P Priority 0 IP: 1.1.1.3/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 26. (Number of active ports = 2) Flags: * = active, ! = disabled Untag: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 25 Tagged: 24* 26* Protected by 0 count of EAPS Domains * Summit24e3:47 # sh stp Stpd: s0 Stp: ENABLED Number of Ports: 26 Rapid Root Failover: Disabled Ports: 1,2,3,4,5,6,7,8,9,10,11,12 13,14,15,16,17,18,19,20,21,22,23,24 25,26 Vlans: Default MacVlanDiscover Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:90:1f Designated root: 20:00:00:03:fd:d3:78:01 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 11 Time Since Last Topology Change: 63s Share this post Link to post Share on other sites
kostas Posted December 29, 2008 · Report post Застрелиться Share this post Link to post Share on other sites
Oleg_S Posted January 2, 2009 · Report post Застрелиться Не стоит пока. Не понятно из-за чего стреляться. В приведенном выше тесте на каталисте pvst, на экстримах, как я понимаю, stp. В таком виде должно все работать. Правда на каталисте заведен все один влан, для которого и построено дерево. Интересней будет проверить с несколькими вланами. На каталисте при этом будет свое дерево для каждого влана, а на экстримах общее дерево на все вланы. По идее (100% не ручаюсь, надо проверять), если руты для всех вланов держать на одном этом каталисте, то должно все работать, а вот если захочется рут для какого-то влана вынести на, например, другой каталист c pvst, то тогда хз что будет. Share this post Link to post Share on other sites
kostas Posted January 3, 2009 · Report post Не стоит пока. Не понятно из-за чего стреляться. В приведенном выше тесте на каталисте pvst, на экстримах, как я понимаю, stp.В таком виде должно все работать. Правда на каталисте заведен все один влан, для которого и построено дерево. Интересней будет проверить с несколькими вланами. На каталисте при этом будет свое дерево для каждого влана, а на экстримах общее дерево на все вланы. По идее (100% не ручаюсь, надо проверять), если руты для всех вланов держать на одном этом каталисте, то должно все работать, а вот если захочется рут для какого-то влана вынести на, например, другой каталист c pvst, то тогда хз что будет. Олег, я не совсем понял что мне нужно сделать для этого. У меня вроде так же стоит PVST на каталисте и STP на экстримах. Разница только в количестве виланов - у меня их несколько. Рут указан для всех виланов на каталист. Так что вроде конфигурация идентичная? Или я чего-то не улавливаю? Share this post Link to post Share on other sites
Oleg_S Posted January 3, 2009 · Report post Не стоит пока. Не понятно из-за чего стреляться. В приведенном выше тесте на каталисте pvst, на экстримах, как я понимаю, stp.В таком виде должно все работать. Правда на каталисте заведен все один влан, для которого и построено дерево. Интересней будет проверить с несколькими вланами. На каталисте при этом будет свое дерево для каждого влана, а на экстримах общее дерево на все вланы. По идее (100% не ручаюсь, надо проверять), если руты для всех вланов держать на одном этом каталисте, то должно все работать, а вот если захочется рут для какого-то влана вынести на, например, другой каталист c pvst, то тогда хз что будет. Олег, я не совсем понял что мне нужно сделать для этого. У меня вроде так же стоит PVST на каталисте и STP на экстримах. Разница только в количестве виланов - у меня их несколько. Рут указан для всех виланов на каталист. Так что вроде конфигурация идентичная? Или я чего-то не улавливаю? Ну так покажите вашу диагностику, посмотрим чем оно отличается от того, что D^2 привел. Share this post Link to post Share on other sites
kostas Posted January 4, 2009 · Report post Ну так покажите вашу диагностику, посмотрим чем оно отличается от того, что D^2 привел. Catalyst 6506 Подключение - к порту gi2/3 каталиста подключена герлянда экстримов (sw1,sw2,sw3) как на схеме в первом посте. Кольцо не замкнуто на каталисте - порт gi2/4 отключен на время тестов. #sh run Building configuration... Current configuration : 8734 bytes ! ! Last configuration change at 21:24:51 MSK Tue Dec 30 2008 by kostas ! NVRAM config last updated at 21:34:04 MSK Tue Dec 30 2008 by kostas ! version 12.1 service timestamps debug uptime service timestamps log uptime no service password-encryption service counters max age 10 ! hostname Core ! boot system sup-bootflash:c6sup11-pk2s-mz.121-27b.E.bin aaa new-model enable password master ! username root privilege 15 secret 5 $1$iRa.$5xQ1seR7,w0abLftSrA.0 clock timezone MSK 3 clock summer-time MSK recurring last Sun Mar 2:00 last Sun Oct 3:00 clock calendar-valid ip subnet-zero no ip rcmd domain-lookup ip rcmd rsh-enable ip rcmd remote-host netup 10.0.0.2 netup enable ip wccp web-cache redirect-list WCCP_REDIRECT_TEST ! ! ip domain-name link.local ip name-server x.x.x.x ip name-server x.x.x.x ip dhcp excluded-address 10.4.0.1 ip dhcp excluded-address 10.4.0.255 10.4.255.254 ! ip dhcp pool office network 10.4.0.0 255.255.0.0 default-router 10.4.0.1 dns-server 10.0.0.2 domain-name link-spb.ru lease infinite ! ip ssh time-out 60 ip ssh authentication-retries 3 ip ssh version 2 mls flow ip destination mls flow ipx destination mls qos ! ! ! spanning-tree mode pvst no spanning-tree vlan 2 spanning-tree vlan 3-4 priority 8192 ! redundancy mode rpr-plus main-cpu auto-sync running-config auto-sync standard ! ! class-map match-any ManageCLASS match access-group name PolicyManage ! ! policy-map TESTPOLICY class ManageCLASS bandwidth percent 3 set ip dscp 16 class class-default random-detect ! ! ! interface Loopback0 ip address 192.168.10.1 255.255.255.0 ip route-cache policy ip route-cache flow ! interface GigabitEthernet2/3 description Test STP switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan 3,4,1000 switchport mode trunk ! interface GigabitEthernet2/4 description Test STP shutdown switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan 3,4,1000 switchport mode trunk ! interface Vlan1 no ip address shutdown ! interface Vlan3 description Management ip address 10.3.0.1 255.255.255.0 ! interface Vlan4 description Office ip address 10.4.0.1 255.255.255.0 ip nat inside ! ! ip default-gateway <GW-IP> ip classless ip route 0.0.0.0 0.0.0.0 <GW-IP> tag 999 name Uplink ip flow-export version 5 ip flow-export destination 10.0.0.2 9996 no ip http server ! ! ip access-list standard FWD-2-SQUID ip access-list standard NAT-ACCESS permit 10.0.0.0 0.0.0.255 permit 10.4.0.0 0.0.0.255 permit 10.5.0.0 0.0.0.255 permit 10.6.0.0 0.0.0.255 permit 10.100.0.0 0.0.255.255 deny any ! ip access-list extended LOOP permit ip any 10.0.0.0 0.255.255.255 ip access-list extended PolicyManage permit tcp any any eq 22 permit tcp any eq 22 any permit tcp any any eq telnet permit tcp any eq telnet any deny ip any any ip access-list extended WCCP_REDIRECT permit tcp 10.0.0.0 0.255.255.255 any eq www permit tcp 10.0.0.0 0.255.255.255 any eq 8080 permit tcp 10.0.0.0 0.255.255.255 any eq 3128 deny ip any any ip access-list extended WCCP_REDIRECT_TEST deny tcp host 10.0.0.2 any eq www permit tcp host 10.0.0.5 any eq www deny ip any any ip access-list extended inet deny tcp any host x.x.x.x eq telnet permit ip any any access-list 100 permit tcp 0.0.0.0 255.0.0.0 any eq www access-list 100 permit tcp 0.0.0.0 255.0.0.0 host 10.0.0.2 eq domain access-list 100 permit udp 0.0.0.0 255.0.0.0 host 10.0.0.2 eq domain access-list 100 permit tcp 0.0.0.0 255.0.0.0 any eq ftp access-list 100 permit tcp 0.0.0.0 255.0.0.0 any eq ftp-data access-list 100 permit tcp 0.0.0.0 255.0.0.0 any eq smtp access-list 100 permit tcp 0.0.0.0 255.0.0.0 any eq pop3 access-list 100 deny ip any any access-list 101 permit tcp any any eq www access-list 101 permit tcp any host 10.0.0.2 eq domain access-list 101 permit udp any host 10.0.0.2 eq domain access-list 101 permit tcp any any eq ftp access-list 101 permit tcp any any eq ftp-data access-list 101 permit tcp any any eq smtp access-list 101 permit tcp any any eq pop3 access-list 101 deny ip any any access-list 105 dynamic test1 permit ip any any access-list 105 permit ip host 10.0.0.5 any access-list 106 dynamic test2 permit ip any any access-list 106 permit ip any host 10.0.0.5 route-map NETUP_MAP permit 10 match ip address LOOP set interface Loopback0 GigabitEthernet1/1 ! ! privilege exec level 8 access-template privilege exec level 8 clear access-template ! line con 0 line vty 0 4 ! ntp clock-period 17179684 ntp master 15 ntp update-calendar ntp server 194.149.67.130 ntp server 192.36.143.152 version 2 ! end #sh span VLAN0003 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0004.de18.b403 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0004.de18.b403 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/3 Desg FWD 4 128.67 P2p VLAN0004 Spanning tree enabled protocol ieee Root ID Priority 8192 Address 0004.de18.b404 This bridge is the root Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Bridge ID Priority 8192 Address 0004.de18.b404 Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec Aging Time 300 Interface Role Sts Cost Prio.Nbr Type ---------------- ---- --- --------- -------- -------------------------------- Gi2/3 Desg FWD 4 128.67 P2p #sh span deta VLAN0003 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0004.de18.b403 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 16 last change occurred 00:02:49 ago from GigabitEthernet2/3 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 0, topology change 0, notification 0, aging 300 Port 67 (GigabitEthernet2/3) of VLAN0003 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.67. Designated root has priority 8192, address 0004.de18.b403 Designated bridge has priority 8192, address 0004.de18.b403 Designated port id is 128.67, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 101, received 0 VLAN0004 is executing the ieee compatible Spanning Tree protocol Bridge Identifier has priority 8192, address 0004.de18.b404 Configured hello time 2, max age 20, forward delay 15 We are the root of the spanning tree Topology change flag not set, detected flag not set Number of topology changes 13 last change occurred 00:03:45 ago from GigabitEthernet2/3 Times: hold 1, topology change 35, notification 2 hello 2, max age 20, forward delay 15 Timers: hello 0, topology change 0, notification 0, aging 300 Port 67 (GigabitEthernet2/3) of VLAN0004 is forwarding Port path cost 4, Port priority 128, Port Identifier 128.67. Designated root has priority 8192, address 0004.de18.b404 Designated bridge has priority 8192, address 0004.de18.b404 Designated port id is 128.67, designated path cost 0 Timers: message age 0, forward delay 0, hold 0 Number of transitions to forwarding state: 1 Link type is point-to-point by default BPDU: sent 128, received 0 SW1 Summit24e3:2 # sh Manage VLAN Interface[2-202] with name "Manage" created by user Tagging: 802.1Q Tag 3 Priority: 802.1P Priority 0 IP: 10.3.0.7/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 2. (Number of active ports = 2) Flags: * = active, ! = disabled Tagged: 25* 26* Protected by 0 count of EAPS Domains Summit24e3:3 # sh Office VLAN Interface[3-204] with name "Office" created by user Tagging: 802.1Q Tag 4 Priority: 802.1P Priority 0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 2. (Number of active ports = 2) Flags: * = active, ! = disabled Tagged: 25* 26* Protected by 0 count of EAPS Domains Summit24e3:4 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 2 Rapid Root Failover: Disabled Ports: 25,26 Vlans: Default MacVlanDiscover Manage Office Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:a7:e4 Designated root: 80:00:00:01:30:11:8e:00 RootPathCost: 4 Root Port: 25 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 5 Time Since Last Topology Change: 411s SW2 Summit24e3:1 # sh Manage VLAN Interface[2-202] with name "Manage" created by user Tagging: 802.1Q Tag 3 Priority: 802.1P Priority 0 IP: 10.3.0.8/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 2. (Number of active ports = 2) Flags: * = active, ! = disabled Tagged: 25* 26* Protected by 0 count of EAPS Domains Summit24e3:2 # sh Office VLAN Interface[3-204] with name "Office" created by user Tagging: 802.1Q Tag 4 Priority: 802.1P Priority 0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 2. (Number of active ports = 2) Flags: * = active, ! = disabled Tagged: 25* 26* Protected by 0 count of EAPS Domains Summit24e3:5 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 2 Rapid Root Failover: Disabled Ports: 25,26 Vlans: Default MacVlanDiscover Manage Office Bridge Priority: 32768 BridgeID: 80:00:00:01:30:11:8e:00 Designated root: 80:00:00:01:30:11:8e:00 RootPathCost: 0 Root Port: ---- MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 3 Time Since Last Topology Change: 464s SW3 Summit24e3:1 # sh Manage VLAN Interface[2-205] with name "Manage" created by user Tagging: 802.1Q Tag 3 Priority: 802.1P Priority 0 IP: 10.3.0.9/255.255.255.0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 2. (Number of active ports = 1) Flags: * = active, ! = disabled Tagged: 25 26* Protected by 0 count of EAPS Domains Summit24e3:2 # sh Office VLAN Interface[3-209] with name "Office" created by user Tagging: 802.1Q Tag 4 Priority: 802.1P Priority 0 STPD: Domain "s0" is running spanning tree protocol Protocol: Match all unfiltered protocols. Loopback: Disable QosProfile:QP1 Ports: 2. (Number of active ports = 1) Flags: * = active, ! = disabled Tagged: 25 26* Protected by 0 count of EAPS Domains Summit24e3:3 # sh stpd Stpd: s0 Stp: ENABLED Number of Ports: 2 Rapid Root Failover: Disabled Ports: 25,26 Vlans: Default MacVlanDiscover Manage Office Bridge Priority: 32768 BridgeID: 80:00:00:01:30:12:4c:d3 Designated root: 80:00:00:01:30:11:8e:00 RootPathCost: 4 Root Port: 26 MaxAge: 20s HelloTime: 2s ForwardDelay: 15s CfgBrMaxAge: 20s CfgBrHelloTime: 2s CfgBrForwardDelay: 15s Topology Change Time: 35s Hold time: 1s Topology Change Detected: FALSE Topology Change: FALSE Number of Topology Changes: 7 Time Since Last Topology Change: 797158s Share this post Link to post Share on other sites
Oleg_S Posted January 5, 2009 · Report post kostas, попробуйте добавить первый влан в транк между каталистом и экстримами. Во-вторых, настройте порт-мирроринг на каталисте, и посмотрите wireshark'ом или tcpdump'ом что бегает между каталистом и экстримом. Share this post Link to post Share on other sites
