Добрый день!
Стоит 7206-G2, терминирует пользователей PPPoE, вот sh ver (набивка стандартная, доп. модулей не установлено)
Cisco IOS Software, 7200 Software (C7200P-A3JK91S-M), Version 12.2(31)SB13, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 12:27 by pwade
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
c7206-g2 uptime is 4 days, 1 hour, 4 minutes
System returned to ROM by reload at 15:17:18 UTC Thu Apr 6 2000
System restarted at 09:57:12 MSK Sat Nov 29 2008
System image file is "disk2:c7200p-a3jk91s-mz.122-31.SB13.bin"
Last reload reason: Reload Command
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 20400649
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.1
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2102
Проблема в высокой, по моему мнению, загрузке.
Конфигурация такая: Gi0/1 смотрит на интернет (через промежуточный шлюз), gi0/2 через два сабинтерфейса смотрит на пиринг, gi0/3 смотрит через кучку вланов
на широкополосников, терминирует pppoe.
Выдержки из конфига:
bba-group pppoe global
virtual-template 1
sessions max limit 30000
sessions per-mac limit 500
sessions per-vlan limit 10000
sessions auto cleanup
bba-group pppoe HOMENET
virtual-template 1
interface Loopback2
ip address x.x.x.x 255.255.255.255
interface GigabitEthernet0/1
description xxx
ip address xxx 255.255.255.248
ip access-group OUT-WORLD out
no ip proxy-arp
ip nat outside
ip ospf authentication-key 7 xxx
ip ospf dead-interval minimal hello-multiplier 4
media-type rj45
speed auto
duplex auto
no negotiation auto
arp timeout 600
no cdp enable
no mop enabled
interface GigabitEthernet0/2
description xxx
no ip address
no ip proxy-arp
media-type rj45
speed 100
duplex full
no negotiation auto
arp timeout 600
no cdp enable
no mop enabled
interface GigabitEthernet0/2.113
description -P peering1
encapsulation dot1Q 113
ip address xxx 255.255.255.252
no ip redirects
no ip proxy-arp
ip nat outside
no cdp enable
interface GigabitEthernet0/2.116
description -P peering2
encapsulation dot1Q 116
no ip redirects
no ip proxy-arp
ip nat outside
no cdp enable
interface GigabitEthernet0/3
description xxx
no ip address
no ip proxy-arp
media-type rj45
speed 1000
duplex full
no negotiation auto
arp timeout 600
no cdp enable
no mop enabled
interface GigabitEthernet0/3.201
encapsulation dot1Q 201
pppoe enable group HOMENET
interface GigabitEthernet0/3.202
encapsulation dot1Q 202
interface GigabitEthernet0/3.203
encapsulation dot1Q 203
interface Virtual-Template1
mtu 1492
ip unnumbered Loopback2
ip access-group 130 in
ip access-group CPE_PROTECT_OUT out
ip verify unicast source reachable-via rx allow-self-ping
no ip redirects
no ip proxy-arp
ip mtu 1492
ip nat inside
ip flow egress
no logging event link-status
timeout absolute 1440 0
ppp quality reject
ppp authentication chap pap HOMENET
ppp authorization HOMENET
ppp accounting HOMENET
ppp ipcp dns xx.xx.xx.xx yy.yy.yy.yy
router ospf 1
router-id xx.xx.xx.xx
log-adjacency-changes
summary-address x.x.x.x 255.255.255.0
summary-address x.x.x.x 255.255.254.0
redistribute connected subnets
redistribute static subnets
redistribute bgp xxx subnets
network xx.xx.x.x 0.0.0.7 area 0
router bgp xxxxx
no synchronization
bgp router-id xxxxx
bgp log-neighbor-changes
network x.x.x.x mask 255.255.248.0
network x.x.x.x mask 255.255.254.0
network x.x.x.x mask 255.255.255.0
neighbor x.x.x.x. remote-as 12345
neighbor x.x.x.x. description peering1
neighbor z.z.z.z remote-as 54321
neighbor z.z.z.z description peering2
no auto-summary
ip flow-export source Loopback2
ip flow-export version 5
ip flow-export destination x.x.x.x 9997
ip flow-export destination x.x.x.y 9996
ip flow-top-talkers
top 200
sort-by packets
ip access-list extended CPE_PROTECT_OUT
deny tcp any any eq smtp
remark - Windows Stuff
deny tcp any any eq 445
deny tcp any any range 135 139
deny udp any any range 135 netbios-ss
deny udp any any eq 1025
deny udp any any eq 1026
deny udp any any eq 1434
permit ip any any
ip access-list extended OUT-WORLD
permit tcp host x.x.x.x any eq smtp
permit tcp any host z.z.z.z eq smtp
deny tcp xx.xx.0.0 0.0.7.255 any eq smtp
permit ip any any
access-list 130 remark -- permit DNS and BILLING
access-list 130 permit udp any host x.x.x.x. eq domain
access-list 130 permit tcp any host x.x.x.x eq www
access-list 130 permit tcp any host x.x.x.x eq 443
access-list 130 dynamic BLOCKED deny ip any any
access-list 130 permit ip any any
На каждого клиента в соответствии с тарифным планом выдаются полиси вида
ip:sub-qos-policy-in=PPPoE-INET512K-LOCAL20MB-IN
ip:sub-qos-policy-out=PPPoE-INET512K-LOCAL20MB-OUT
class-map match-any LOCAL-OUT
match access-group name local-out
class-map match-any LOCAL-IN
match access-group name local-in
policy-map PPPoE-INET512K-OUT
class LOCAL-OUT
police cir 512000
exceed-action drop
policy-map PPPoE-INET512K-LOCAL20MB-OUT
class class-default
police cir 20480000
exceed-action drop
service-policy PPPoE-INET512K-OUT
policy-map PPPoE-INET512K-IN
class LOCAL-IN
police cir 512000
exceed-action drop
policy-map PPPoE-INET512K-LOCAL20MB-IN
class class-default
police cir 20480000
service-policy PPPoE-INET512K-IN
ip access-list extended local-in
remark - траффис из локальных сетей и пиринга -
deny ip any xx.xx.xx.xx 0.0.7.255
remark - traffic from ICQ -
deny tcp any 205.188.0.0 0.0.255.255 eq 5190
deny tcp any 64.12.0.0 0.0.255.255 eq 5190
permit ip any any
ip access-list extended local-out
remark - traffic -
deny ip 10.0.0.0 0.255.255.255 any
deny ip xx.xx.xx.x 0.0.7.255 any
deny ip 172.16.0.0 0.15.255.255 any
deny tcp 205.188.0.0 0.0.255.255 eq 5190 any
deny tcp 64.12.0.0 0.0.255.255 eq 5190 any
permit ip any any
ну и собственно графики:
загрузка интерфейсов
http://www.exoplay.ru/~nikl/7206/с7206-gi0-1.png
http://www.exoplay.ru/~nikl/7206/с7206-gi0-2.png
http://www.exoplay.ru/~nikl/7206/с7206-gi0-3.png
загрузка интерфейсов в пакетах
http://www.exoplay.ru/~nikl/7206/с7206-gi0-1-packets.png
http://www.exoplay.ru/~nikl/7206/с7206-gi0-2-packets.png
http://www.exoplay.ru/~nikl/7206/с7206-gi0-3-packets.png
Количество пользователей онлайн
Загрузка процессора
Edited by fozz
что значит убрать ospf и bgp ? роуты прописать статикой, а пиринг вынести с роутера?
bgp там очень мало, sh ip bgp sum
c7206-g2#sh ip bgp sum
BGP router identifier x.x.x.x, local AS number NNNNN
BGP table version is 87, main routing table version 87
25 network entries using 3025 bytes of memory
30 path entries using 1560 bytes of memory
13/11 BGP path/bestpath attribute entries using 1820 bytes of memory
10 BGP AS-PATH entries using 240 bytes of memory
3 BGP community entries using 72 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 6717 total bytes of memory
BGP activity 28/3 prefixes, 46/16 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
x.x.x.x 4 12345 5922 5907 87 0 0 4d02h 5
x.x.x.x 4 54321 7113 5907 87 0 0 4d02h 21
c7206-g2#show processes cpu sorted
CPU utilization for five seconds: 32%/31%; one minute: 32%; five minutes: 31%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
136 4064 89065064 0 0.15% 0.13% 0.13% 0 HQF Shaper Backg
70 2352284 18446048 127 0.15% 0.17% 0.16% 0 IP Input
42 36756 6282 5851 0.15% 0.01% 0.00% 0 Per-minute Jobs
209 572 5577 102 0.07% 0.06% 0.06% 2 SSH Process
184 115924 72506 1598 0.07% 0.04% 0.05% 0 Compute load avg
192 31800 11484112 2 0.07% 0.06% 0.07% 0 PPP Events
133 105960 557049 190 0.07% 0.05% 0.05% 0 CEF: IPv4 proces
47 30872 103396 298 0.07% 0.01% 0.00% 0 HC Counter Timer
37 66452 158211 420 0.07% 0.05% 0.05% 0 Net Background
41 688992 359372 1917 0.07% 0.16% 0.15% 0 Per-Second Jobs
10 0 2 0 0.00% 0.00% 0.00% 0 ATM VC Auto Crea
9 0 2 0 0.00% 0.00% 0.00% 0 ATM AutoVC Perio
11 296 71527 4 0.00% 0.00% 0.00% 0 ALARM_TRIGGER_SC
12 0 62 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
15 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
13 664 12451 53 0.00% 0.00% 0.00% 0 AAA high-capacit
8 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
18 0 5965 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
19 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
7 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
14 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
22 200 357569 0 0.00% 0.00% 0.00% 0 IPC Deferred Por
16 65644 6452229 10 0.00% 0.00% 0.00% 0 EnvMon
24 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Serv
25 0 35788 0 0.00% 0.00% 0.00% 0 Compute SRP rate
17 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
4 179688 36399 4936 0.00% 0.03% 0.00% 0 Check heaps
28 8 350 22 0.00% 0.00% 0.00% 0 EEM ED Syslog
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
30 120 9341 12 0.00% 0.00% 0.00% 0 DDR Timers
31 0 3 0 0.00% 0.00% 0.00% 0 Entity MIB API
32 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
33 0 1 0 0.00% 0.00% 0.00% 0 RFS server proce
20 472 357569 1 0.00% 0.00% 0.00% 0 IPC Periodic Tim
21 0 1 0 0.00% 0.00% 0.00% 0 IPC Managed Time
36 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
23 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
38 0 2 0 0.00% 0.00% 0.00% 0 IDB Work
39 0 534 0 0.00% 0.00% 0.00% 0 Logger
40 556 357552 1 0.00% 0.00% 0.00% 0 TTY Background
26 64068 398982 160 0.00% 0.01% 0.00% 0 ARP Input
3 2696 66514 40 0.00% 0.00% 0.00% 0 IP SNMP
43 780 5 156000 0.00% 0.00% 0.00% 0 PrstVbl
44 700 18610 37 0.00% 0.00% 0.00% 0 IF-MGR control p
45 8 18657 0 0.00% 0.00% 0.00% 0 IF-MGR event pro
2 40 71573 0 0.00% 0.00% 0.00% 0 Load Meter
5 28720 545728 52 0.00% 0.00% 0.00% 0 Pool Manager
27 60 373286 0 0.00% 0.00% 0.00% 0 ARP Background
49 0 2 0 0.00% 0.00% 0.00% 0 CES Timer
50 0 2 0 0.00% 0.00% 0.00% 0 Hawkeye Backgrou
51 0 1 0 0.00% 0.00% 0.00% 0 FPD Management P
52 0 1 0 0.00% 0.00% 0.00% 0 FPD Action Proce
29 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
1 2360 42526 55 0.00% 0.00% 0.00% 0 Chunk Manager
55 112 108 1037 0.00% 0.00% 0.00% 0 Collection proce
56 0 2 0 0.00% 0.00% 0.00% 0 VNM DSPRM MAIN
57 0 1 0 0.00% 0.00% 0.00% 0 CES Line Conditi
58 0 2 0 0.00% 0.00% 0.00% 0 Flash MIB Update
59 0 1 0 0.00% 0.00% 0.00% 0 Flash Card Oir
60 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
61 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
62 4 1366 2 0.00% 0.00% 0.00% 0 TurboACL
63 0 2 0 0.00% 0.00% 0.00% 0 TurboACL chunk
64 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
65 2264 14552 155 0.00% 0.00% 0.00% 0 AAA Server
66 4680 107493 43 0.00% 0.00% 0.00% 0 AAA ACCT Proc
34 264 357556 0 0.00% 0.00% 0.00% 0 GraphIt
35 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
69 12 92 130 0.00% 0.00% 0.00% 0 IP ARP Adjacency
46 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
71 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
72 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
73 720 11167170 0 0.00% 0.00% 0.00% 0 IPAM Manager
74 0 2 0 0.00% 0.00% 0.00% 0 IPAM Events
75 39304 11515230 3 0.00% 0.01% 0.00% 0 RADIUS
76 0 2 0 0.00% 0.00% 0.00% 0 PPP SIP
77 4 90 44 0.00% 0.00% 0.00% 0 PPP Bind
78 3484 18333 190 0.00% 0.00% 0.00% 0 PPP IP Route
79 31252 88618 352 0.00% 0.00% 0.00% 0 SSS Manager
80 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
81 3296 37003 89 0.00% 0.00% 0.00% 0 SSS Feature Mana
82 180 1397812 0 0.00% 0.00% 0.00% 0 SSS Feature Time
83 0 1 0 0.00% 0.00% 0.00% 0 SG DPM
84 0 1 0 0.00% 0.00% 0.00% 0 Timer handler fo
85 0 1 0 0.00% 0.00% 0.00% 0 Prepaid response
86 0 1 0 0.00% 0.00% 0.00% 0 Timed Policy act
87 0 1 0 0.00% 0.00% 0.00% 0 AAA response han
88 44444 155907 285 0.00% 0.00% 0.00% 0 SSM connection m
89 0 602 0 0.00% 0.00% 0.00% 0 MOP Protocols
90 0 2 0 0.00% 0.00% 0.00% 0 Spanning Tree
91 0 2 0 0.00% 0.00% 0.00% 0 KRB5 AAA
48 0 1 0 0.00% 0.00% 0.00% 0 CSP Timer
93 0 3 0 0.00% 0.00% 0.00% 0 CEF switching ba
94 0 1 0 0.00% 0.00% 0.00% 0 AC Switch
95 0 1 0 0.00% 0.00% 0.00% 0 LSP Tunnel FRR
53 0 1 0 0.00% 0.00% 0.00% 0 SONET alarm time
97 0 1 0 0.00% 0.00% 0.00% 0 O-UNI Client Msg
98 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_state_eve
99 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage
100 0 1 0 0.00% 0.00% 0.00% 0 L2X Socket proce
101 0 2 0 0.00% 0.00% 0.00% 0 L2TP mgmt daemon
102 0 1 0 0.00% 0.00% 0.00% 0 TC SIP
103 0 2 0 0.00% 0.00% 0.00% 0 IP PORTBUNDLE
104 0 1 0 0.00% 0.00% 0.00% 0 SG CMD HANDLER
54 0 1 0 0.00% 0.00% 0.00% 0 POS APS Event Pr
106 700 11167148 0 0.00% 0.00% 0.00% 0 RADIUS Proxy
67 1296 11177016 0 0.00% 0.01% 0.00% 0 ACCT Periodic Pr
108 128 8959 14 0.00% 0.00% 0.00% 0 CEF background p
109 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
110 0 3 0 0.00% 0.00% 0.00% 0 SNMP Timers
111 1488 61789 24 0.00% 0.00% 0.00% 0 IP Background
112 4580 26867 170 0.00% 0.00% 0.00% 0 IP RIB Update
113 0 3 0 0.00% 0.00% 0.00% 0 Flow Exporter Ti
114 292 1106284 0 0.00% 0.00% 0.00% 0 TCP Timer
115 232 3485 66 0.00% 0.00% 0.00% 0 TCP Protocols
116 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
117 0 1194 0 0.00% 0.00% 0.00% 0 HTTP CORE
118 4 2 2000 0.00% 0.00% 0.00% 0 SCTP Main Proces
119 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
120 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
121 776 101799 7 0.00% 0.00% 0.00% 0 L2X Data Daemon
122 320 41640 7 0.00% 0.00% 0.00% 0 CDP Protocol
123 3940 2858319 1 0.00% 0.00% 0.00% 0 PPPoE Background
124 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Inp
125 0 2 0 0.00% 0.00% 0.00% 0 PPP Compress Res
126 856 3570808 0 0.00% 0.00% 0.00% 0 RBSCP Background
127 0 1 0 0.00% 0.00% 0.00% 0 COPS
128 0 2 0 0.00% 0.00% 0.00% 0 ATIP_UDP_TSK
129 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
130 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
131 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
132 0 2 0 0.00% 0.00% 0.00% 0 PPP NBF
68 4 1 4000 0.00% 0.00% 0.00% 0 AAA System Acct
134 980 32141 30 0.00% 0.00% 0.00% 0 ADJ background
135 0 2 0 0.00% 0.00% 0.00% 0 LFDp Input Proc
92 18856 117 161162 0.00% 0.00% 0.00% 0 crypto sw pk pro
137 28 8862 3 0.00% 0.00% 0.00% 0 HQF IDB Associat
138 0 2 0 0.00% 0.00% 0.00% 0 Dialer Forwarder
139 784 71552 10 0.00% 0.00% 0.00% 0 L2F management d
140 624 16781 37 0.00% 0.00% 0.00% 0 PPTP Mgmt
141 0 2 0 0.00% 0.00% 0.00% 0 IP Inband Sessio
142 4 2 2000 0.00% 0.00% 0.00% 0 gk process
143 40 3103 12 0.00% 0.00% 0.00% 0 LOCAL AAA
144 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
145 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
146 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
147 3892 22302 174 0.00% 0.00% 0.00% 0 IDMGR CORE
148 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
149 0 1 0 0.00% 0.00% 0.00% 0 TSP
150 0 1 0 0.00% 0.00% 0.00% 0 VOIP RTP Udp Inp
151 0 1 0 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN
152 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_HTSP
153 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_R2
154 0 1 0 0.00% 0.00% 0.00% 0 CCSWVOICE
155 0 2 0 0.00% 0.00% 0.00% 0 Proxy Session Ap
156 0 4 0 0.00% 0.00% 0.00% 0 Crypto CA
157 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
158 0 1 0 0.00% 0.00% 0.00% 0 Crypto SSL
159 8 35787 0 0.00% 0.00% 0.00% 0 RMON Recycle Pro
160 0 2 0 0.00% 0.00% 0.00% 0 RMON Deferred Se
161 0 1 0 0.00% 0.00% 0.00% 0 SYSMGT Events
162 1096 22911 47 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
163 0 1 0 0.00% 0.00% 0.00% 0 SONET Traps
164 2100 71936 29 0.00% 0.00% 0.00% 0 EEM Server
165 0 2 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
166 4 5968 0 0.00% 0.00% 0.00% 0 EEM ED Timer
167 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Counter
168 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Interface
169 0 3 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
170 0 1 0 0.00% 0.00% 0.00% 0 xcpa-driver
171 0 2 0 0.00% 0.00% 0.00% 0 EEM ED None
172 0 3 0 0.00% 0.00% 0.00% 0 EEM ED CLI
173 0 2 0 0.00% 0.00% 0.00% 0 EEM ED OIR
174 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Track
175 19932 220725 90 0.00% 0.00% 0.00% 0 PPPoE Discovery
176 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
177 0 1 0 0.00% 0.00% 0.00% 0 RMON Packets
178 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
179 8 15911 0 0.00% 0.00% 0.00% 0 IP SLA MPLSLM Pr
180 0 1 0 0.00% 0.00% 0.00% 0 VPDN Test
181 728 357105 2 0.00% 0.00% 0.00% 0 trunk conditioni
182 0 1 0 0.00% 0.00% 0.00% 0 trunk conditioni
183 4600 314266 14 0.00% 0.00% 0.00% 0 Net Input
96 0 1 0 0.00% 0.00% 0.00% 0 MPLS Auto-Tunnel
185 4 8445 0 0.00% 0.00% 0.00% 0 TCP Driver
186 0 209 0 0.00% 0.00% 0.00% 0 TCP Listener
187 0 2984 0 0.00% 0.00% 0.00% 0 CC-API_VCM
188 1460 3571168 0 0.00% 0.00% 0.00% 0 CCPROXY_CT
189 0 1 0 0.00% 0.00% 0.00% 0 CCPROXY_UDP
190 297860 19188 15523 0.00% 0.02% 0.04% 0 VTEMPLATE Backgr
191 2304 11182959 0 0.00% 0.02% 0.00% 0 PPP manager
105 0 87370 0 0.00% 0.00% 0.00% 0 IP SIP Process
193 24 357217 0 0.00% 0.00% 0.00% 0 Multilink PPP
194 0 1 0 0.00% 0.00% 0.00% 0 Multilink event
195 224 11907 18 0.00% 0.00% 0.00% 0 URPF stats
196 48124 3520450 13 0.00% 0.00% 0.00% 0 IP NAT Ager
197 0 1 0 0.00% 0.00% 0.00% 0 IP Flow Backgrou
198 652 33257 19 0.00% 0.00% 0.00% 0 PDU DISPATCHER
199 3700 33261 111 0.00% 0.00% 0.00% 0 SNMP ENGINE
200 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
201 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps
202 113420 4257684 26 0.00% 0.04% 0.04% 0 OSPF-1 Hello
203 36348 407154 89 0.00% 0.01% 0.00% 0 OSPF-1 Router
204 28 346478 0 0.00% 0.00% 0.00% 0 BGP Scheduler
205 2032 78863 25 0.00% 0.00% 0.00% 0 BGP Router
206 532 24945 21 0.00% 0.00% 0.00% 0 BGP I/O
207 824 23695 34 0.00% 0.00% 0.00% 0 BGP Scanner
208 0 1 0 0.00% 0.00% 0.00% 0 BGP Event
107 0 1 0 0.00% 0.00% 0.00% 0 IPv6 RIB Redistr
210 388 327719 1 0.00% 0.00% 0.00% 0 NTP
211 0 15 0 0.00% 0.00% 0.00% 0 VPDN failure man
212 4 190 21 0.00% 0.00% 0.00% 0 SSH Event handle
213 12 45 266 0.00% 0.00% 0.00% 0 IP Flow Top Talk
Из этого видно, что нагружен он трафиком.
Что вы хотите от тазика? 3 гигабита соответственно имеющимся портам?
Он и один не прожуёт с ACL'ями и service-polic'ями, а тут ещё и PPPoE...
Коля, замени иерархические полиси мапы вот на такие
policy-map 512K
class local-out
police 10000000 1875000 3750000 conform-action transmit exceed-action drop
class world-out
police 512000 96000 192000 conform-action transmit exceed-action drop.
В router ospf
по умолчанию поставь
passive-interface default
no passive-interface нужный_интерфейс
вынеси ospf аутенфикацию
зачем там суммаризация и редистрибьюты?
bgp и бордер вынеси вообще с этой железки на какой нибудь каталист 35xx, 37xx
на этой железке оставь только терминацию
на кой там у тебя нат стоит? убирай его в сад, у тебя же сети есть публичные.
на virtual-template зачем ip mtu 1492? убирай. Оставь mtu 1492 и поставь там ip tcp adjust-mss 1452
pps на ge0/3 какой то рванный, совпадает с загрузкой проца, проверь клиентов на вирусы, может зверёк в сети завёлся?
Эта железка в твоём случае должна тянуть 1000-1200 сабскрайберов, примерно 500mb/s и ~150-200 килопопугаев.
Каталист в наличии есть? Зачем тебе куча аплинков с фулвью? Мироедов шлите нах, они вас плохому научат )) не нужно вам столько ног, возьмите каталист в аренду вместе с каналом и получите нормальную связность с железом и поддержкой по таким вот вопросам. Николай, понты на куче ног - ни что, количество абонентов в 4 (четыре) раза больше на том же самом железе плюс быстрые ответы на твои вопросы - всё. :))
redistribute connected на тазике с pppoe очень ***вая идея. interface up/down будет дрочить вам ospf по всей сети. Пиринг на отдельную машину, igp исключительно для инфраструктуры.
от тазика хочу, что бы ситуация соответствовала хотя бы этому
http://forum.nag.ru/forum/index.php?s=&amp...st&p=311601
У товарищей ISG, ~1000 пользователей, трафик 600-700 мбит и загрузка 78.
У меня нет ISG (а так придется видимо и забить) пользователей в пике 300, трафика ~180 и загрузка под 80.
Для меня это странно.
У меня стоял на терминации юзерских виланов - мегабит 450 максимум при 1100 юзерах.
Правда, использовался шейпинг, он грузит больше чем полисинг.
Килопакетов было около 85-95, загрузка - под 95%.
7301 - это NPE-G1.
Под правильным IOS'ом (12.3T) всего процентов на 30-40 хуже, чем NPE-G2.
Полностью согласен.
Проверьте CEF =) Сколько пакетов проходит через CPU ?
В этой версии IOS'а не работает cef =(
конкретно в этой?
ВРоде да.
Используйте 124-4.XD9 до 2000 сессий pptp =)
Проверить работоспособность cef можно по кол-ву обработанных пакетов.
2UglyAdmin: А какой именно из 12.3T ставить на 7301 рекомендуете?
Это от задач зависит, поскольку набор фич там не такой полный, да и багов хватает.
У меня (на NPE-G1) работала 12.3(11)Т10, но приходилось ребутать раз в две недели - память утекала при заливке конфигов через SNMP.
