Прошу помощи с восстановлением точки. :(
Прошивал две точки, первая прошилась идеально и работает идеально, а вот при прошивке второй возникли трудности из-за обрыва...
Восстанавливал через com командами:
load -r -h 192.168.1.55 -b 0x80400000 kernel1.bin
fis write -f 0xBE050000 -b 0x80400000 -l 0x00090000
load -r -h 192.168.1.55 -b 0x80001000 rootfs.bin
fis write -f 0xBE0E0000 -b 0x80001000 -l 0x006C0000
Лог после перезагрузки:
~+Ethernet eth0: MAC address 00:1c:f0:09:59:60
IP: 192.168.1.30/255.255.255.0, Gateway: 0.0.0.0
Default server: 192.168.1.100, DNS server IP: 0.0.0.0
RedBoot bootstrap and debug environment [ROM]
Non-certified release, version v2_0 - built 16:27:39, Jul 5 2006
Copyright © 2000, 2001, 2002, Red Hat, Inc.
Copyright © 2005, Devicescape Software, Inc.
Copyright © 2006, LVL7 Systems, Inc.
RAM: 0x80000400-0x82000000, 0x80000400-0x81fe1000 available
FLASH: 0xbe000000 - 0xbe7d0000, 125 blocks of 0x00010000 bytes each.
ART_FLAG = 0
== Executing boot script in 2.000 seconds - enter ^C to abort
RedBoot> fis load -b 0x80400000 kernel
RedBoot> exec -b 0x80500000
Now booting linux kernel:
Base address 0x80500000ДCPU revision is: 00018009
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, linesize 16 bytes.
Linux version 2.4.27-devicescape.3 (lvl7build@lc-rdub-07) ( /tools/devicescape/c
olusa14/toolchains/mipsf-linux/bin/../libexec/gcc/mips-linux/3.4.1/collect2 --eh
-frame-hdr -EB -dynamic-linker /lib/ld.so.1 -L/tools/devicescape/colusa14/toolch
ains/mipsf-linux/mips-linux-uclibc/lib -L/tools/devicescape/colusa14/toolchains/
mipsf-linux/mips-linux-uclibc/lib -L/tools/devicescape/colusa14/toolchains/mipsf
-linux/bin/../lib/gcc/mips-linux/3.4.1 -L/tools/devicescape/colusa14/toolchains/
mipsf-linux/bin/../lib/gcc -L/tools/devicescape/colusa14/toolchains/mipsf-linux/
bin/../lib/gcc/mips-linux/3.4.1/../../../../mips-linux/lib --dynamic-linker /lib
/ld-uClibc.so.0 -rpath-link /tools/devicescape/colusa14/toolchains/mipsf-linux/m
ips-linux-uclibc/lib /tools/devicescape/colusa14/toolchains/mipsf-linux/mips-lin
ux-uclibc/lib/crti.o /tools/devicescape/colusa14/toolchains/mipsf-linux/mips-lin
ux-uclibc/lib/crtbegin.o /tools/devicescape/colusa14/toolchains/mipsf-linux/mips
-linux-uclibc/lib/crt1.o -lgcc -lgcc_eh -lc -lgcc -lgcc_eh /tooDetermined physic
al RAM map:
memory: 02000000 @ 00000000 (usable)
NOFS reserved @ 0x80176800
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: console=ttyS0,9600 root=/dev/mtdblock3 rw
Using 110.000 MHz high precision timer.
Calibrating delay loop... 219.54 BogoMIPS
Memory: 30908k/32768k available (1160k kernel code, 1860k reserved, 84k data, 60
k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Checking for 'wait' instruction... available.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
JFFS2 version 2.1. © 2001 Red Hat, Inc., designed by Axis Communications AB.
Serial driver version 5.05c (2001-07-08) with no serial options enabled
ttyS00 at 0xbc000003 (irq = 37) is a 16550A
Software Watchdog Timer: 0.05, timer margin: 60 sec
physmap flash device: 800000 at be000000
CFI: Found no Physically mapped flash device at location zero
Search for id:(40 1a) interleave(1) type(1)
Search for id:(40 60) interleave(1) type(2)
JEDEC: Found no Physically mapped flash device at location zero
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Ebtables v2.0 registered
NET4: Ethernet Bridge 008 for NET4.0
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Other stuff added by David S. Miller <davem@redhat.com>
VFS: Cannot open root device "mtdblock3" or 1f:03
Please append a correct "root=" boot option
Kernel panic: VFS: Unable to mount root fs on 1f:03
<0>Rebooting in 2 seconds..
и лог удачно прошитой точки:
ь+Ethernet eth0: MAC address 00:1c:f0:09:59:40
ART_FLAG = 0
Base address 0x80500000 Entry 0x80400000
*МDCPU revision is: 00018009
al RAM map:
NOFS reserved @ 0x8017b8e0
zone(1): 0 pages.
zone(2): 0 pages.
Memory: 30888k/32768k available (1180k kernel code, 1880k reserved, 84k data, 64
k init, 0k highmem)
Starting kswapd
Amd/Fujitsu Extended Query Table v1.3 at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling fast programming due to code brokenness.
physmap: Using RedBoot partition definition
Creating 6 MTD partitions on "Physically mapped flash":
0x00000000-0x00050000 : "RedBoot"
0x00050000-0x000e0000 : "kernel"
0x000e0000-0x007a0000 : "rootfs"
0x007a0000-0x007b0000 : "unallocated"
0x007b0000-0x007b1000 : "RedBoot config"
0x007c0000-0x007d0000 : "FIS directory"
AP MAC: 00:1c:f0:09:59:40 - Config Changed: 0
VFS: Mounted root (jffs2 filesystem).
Freeing unused kernel memory: 64k freed
init started: BusyBox v1.00 (2Algorithmics/MIPS FPU Emulator v1.5
008.02.22-00:10+0000) multi-call binary
init started: BusyBox v1.00 (2008.02.22-00:10+0000) multi-call binary
Starting pid 11, console /dev/console: '/etc/init.d/rc'
Mounting filesystems...
DWL8500AP detected
Inserting Captive Portal code: wlext_cp.oUsing /lib/modules/2.4.27-deviceap cp d
ata allocated
scape.3/kernel/dvap cp data allocated
rivers/net/wireless/wlext_cp.o
Inserting IP tunnel code: wlext_iptunnel.oUsing /lib/modules/2.4ap tunnel alloca
ted
.27-devicescape.vap tunnel allocated
3/kernel/drivers/net/wireless/wlext_iptunnel.o
Using /lib/modules/2.4.27-devicescape.3/kernel/drivers/misc/button.o
Inserting Wireless Datapath driver: 80211.oUsing /lib/modules/2.4.27-devicescape
.3/kernel/drivers/net/wireless/80211.o
Using /lib/modules/2.4.27-devicescape.3/kernel/drivers/net/wireless/rate_control
.o
_ath.o
insmod: rate_control_engim.o: no module by that name found
Inserting Atheros Radio driver: oahu-ar5312.oUsing /lib/modules/2.4.27-devicesca
pe.3/kernel/drivers/net/wireless/oahu-ar5312.o
ar5211.c : Atheros AR5211 driver v0.0-jan18
soc = 87
Attach AR5212 0x1113 0x81d43044
wlan0.11: MAC rev 5.7 too old for Michael MIC hwaccel with WMM
ar5211 hwaddr: 00:03:7F:BE:F0:77
ar5211 wlan0.11: Device at 0xb8000000, IRQ 2
soc = 87
Attach AR5212 0x1113 0x81d03044
wlan1.11: MAC rev 5.7 too old for Michael MIC hwaccel with WMM
ar5211 hwaddr: 00:03:7F:BE:F0:79
ar5211 wlan1.11: Device at 0xb8500000, IRQ 5
Noise floor failed detected 0 higher than thresh -54
Inserting rate_control_ath.oUsing /lib/modules/2.4.27-devicescape.3/kernel/drive
rs/net/wireless/rate_control_ath.o
insmod: A module named rate_control_ath already exists
Loading insert1q moduleUsing /lib/modules/2.4.27-devicescape.3/kernel/kernel/net
/ebt_insert1q.o
Loading strip1q moduleUsing /lib/modules/2.4.27-devicescape.3/kernel/kernel/net/
ebt_strip1q.o
Starting dmandman: Daemonizing...
dman: Daemonized.
No Hardware Watchdog Timer reset detected.
dman: Starting mapd ....
dman: Initialization complete.
DLINK-WLAN-AP login: AP User Config Country Code: 1 - Config Changed: 0
AP Countr
y Code: US - Config Changed: 0
AP Se
rial number: H00127665 - Config Changed: 0
dman: hostapd-all sent standalone mode
response.
Народ help me..... Почему не создаются разделы на убитой точке как в живой?
убитая
живая
и кто их не создает - RedBoot или Linux? Как создать? :)
До заливки файлов в точку разделы создавались, контрольная сумма файлов на обоих точках совпадают. (проверял fis list -c)
В самой прошивке скачаной с http://ftp.dlink.ru/pub/Switch/DWS-3000%20...b1%5d.1.0.9.tar куча файлов:
kernel1.bin 567 868
kernel2.bin 576 044
rootfs.bin 4 610 378
kernel1.md5 36
kernel2.md5 36
rootfs.md5 36
model 5
board 8
version 9
Заливались только kernel1.bin и rootfs.bin, может надо еще заливать куда-то kernel2.bin
Помогите что делать, куда рыть и что ломать.... :) еще живая одна точка....
Итог такой:
rootfs.bin оказался архивом, распаковал и залил load -r -h 192.168.1.55 -b 0x80001000 rootfs.jffs2 и залил kernel2.bin.... и все поехало :))
  • 4 weeks later...
хотелось бы узнать подробнее про управление и перепрошивку точки 8500ар через rs232. на плате нашел вывод, сделал null-modem кабель rx-gnd-tx. через терминал на скорости 115200 точка не откликается - только некоторые последовательности кидает и все. ставлю cygwin. потом накачу redboot. где найти мануал касательно прошивки точки доступа?
http://www.lammertbies.nl/comm/info/RS-232...modem.html#loop - вот такой вот кабель
  • 6 years later...
DenXkc а чем распаковали rootfs.bin? Столкнулся с той же проблемой как и в первом посте
7zip обычно их разгрызает вполне ок
огромное спасибо за помощь!
  • 6 months later...
Будущим поколениям!
инструкции подходят для DWL-8500 и DWL-3500
load -r -h 10.90.90.100 -b 0x80400000 kernel1.bin
load -r -h 10.90.90.100 -b 0x80400000 kernel2.bin
load -r -h 10.90.90.100 -b 0x80001000 rootfs.jffs2
fconfig(по дефолту за исключением скрипта)
