Посылаю на ISG CoA, isg почему-то дает NACK.
Вот дебаг:
Nov 10 15:31:34.763: COA: 172.30.1.130 request queued
Nov 10 15:31:34.763: RADIUS: authenticator AE C3 69 F7 B7 B0 73 7E - 4E 9C 79 BE C8 19 B5 71
Nov 10 15:31:34.763: RADIUS: Vendor, Cisco [26] 22
Nov 10 15:31:34.763: RADIUS: ssg-account-info [250] 16 "S192.168.10.94"
Nov 10 15:31:34.763: RADIUS: User-Name [1] 6 "niki"
Nov 10 15:31:34.763: RADIUS: Vendor, Cisco [26] 13
Nov 10 15:31:34.763: RADIUS: ssg-command-code [252] 7
Nov 10 15:31:34.763: RADIUS: 01 6E 69 6B 69 [Account-Log-On niki]
Nov 10 15:31:34.763: ++++++ CoA Attribute List ++++++
Nov 10 15:31:34.763: 20A00F90 0 00000009 ssg-account-info(430) 14 S192.168.10.94
Nov 10 15:31:34.763: 20A022A8 0 00000009 username(396) 4 niki
Nov 10 15:31:34.763: 20A022B8 0 00000009 ssg-command-code(432) 5 01 6E 69 6B 69
Nov 10 15:31:34.763: AAA SRV(0000007D): process response req
Nov 10 15:31:34.763: RADIUS/ENCODE(0000007D):Orig. component type = IEDGE_IP_SIP
Nov 10 15:31:34.763: RADIUS/ENCODE(0000007D): Unsupported AAA attribute clid-mac-addr
Nov 10 15:31:34.763: RADIUS(0000007D): sending
Nov 10 15:31:34.763: RADIUS(0000007D): Send CoA Nack Response to 172.30.1.130:45924 id 3, len 82
Nov 10 15:31:34.763: RADIUS: authenticator BE 0A F1 6B 91 A0 8E 33 - 9A 04 7D D4 D3 14 AD C6
Nov 10 15:31:34.763: RADIUS: Vendor, Cisco [26] 15
Nov 10 15:31:34.763: RADIUS: ssg-command-code [252] 9
Nov 10 15:31:34.763: RADIUS: 10 32 3B 6E 69 6B 69 [Error-Code 2;niki]
Nov 10 15:31:34.763: RADIUS: Vendor, Cisco [26] 25
Nov 10 15:31:34.763: RADIUS: ssg-account-info [250] 19 "$MA001f.5bd1.b96c"
Error-Code 2 - это, на сколько я понимаю, AUTHENTICATE USER FAIL (судя по http://www.cisco.com/en/US/docs/ios/12_2sb...a/guide/isg...).
Вот control policy-map:
policy-map type control option82
class type control BYE event timed-policy-expiry
1 service disconnect
class type control always event session-start
21 service-policy type service name LOCALTRAFF_SERVICE
100 authorize aaa list option82 password cisco identifier mac-address
class type control always event session-restart
class type control always event account-logon
10 authenticate aaa list weblogin
20 service-policy type service unapply name INETTRAFF3_SERVICE
(INETTRAFF3_SERVICE - это некий гипотетический сервис, который эпплаится юзеру при логине)
вот настройки aaa:
aaa group server radius option82
server-private 172.30.1.1 auth-port 1812 acct-port 1813 key xxx
ip radius source-interface GigabitEthernet0/0
attribute nas-port format d
aaa group server radius weblogin
aaa authentication login default local
aaa authentication login option82 group option82
aaa authentication login weblogin group weblogin
aaa authorization network default group option82
aaa authorization network option82 group option82
aaa authorization network weblogin group weblogin
aaa authorization subscriber-service default local group option82
aaa authorization subscriber-service option82 group option82
aaa accounting update periodic 1
aaa accounting network option82 start-stop group option82
aaa nas port extended
aaa server radius dynamic-author
client 172.30.1.2 server-key xxx
client 172.30.1.130 server-key xxx
auth-type any
IOS c7301-advipservicesk9_li-mz.122-33.SRD.bin
В aaa server radius dynamic-author нужно указывать
ignore {session-key | server-key}
если соответствующих атрибутов нет в запросах. А в приведенном дебаге например 151 атрибута не видно.
А Вы вообще что хотите получить? Сценарий какой? А то может там нельзя account-logon делать или можно по другому.
Edited by Bambuk
Я хочу, что бы выполнилось
и всё :)
Когда приходит пакет account-logon (с портала, например)
Т.е. например, такая логика
[session start]
мы проверяем по option82, что абонент пришел с правильной части сети
(authorize ...)
применяем ему сервисы L4REDIRECT и PBHK
кастомер ввел на портале верные креденшиалы, и портал посылает на cisco account logon пакет
[account-logon]
авторизуемся у радиуса
работаем
вообщем-то как-то так :)
Да, я понимаю что можно реализовать нечто подобное 0xB Service Activate/ 0xC Deactivate пакетами - но это как-то некрасиво
C PBHK пробовал? ssg-account-info [250] 16 "S192.168.10.94" не может уникально идентифицировать сессию, т.к. может быть много сессий с этим IP в разных vrf. Нужно PBHK.
Попробую завтра, но опять же - session query нормально выдается по такому идентификатору..
Смущает Nov 10 15:31:34.763: RADIUS: 10 32 3B 6E 69 6B 69 [Error-Code 2;niki]
Судя по сайту cisco (хотя там не всё понятно в этом плане), error code 2 - это ошибка авторизации.
А какой бы еще дебаг посмотреть на эту тему?
#!!! Account status query
/bin/echo "User-Name=\"test\",cisco-avpair=\"subscriber:command=account-profile-status-query\",Cisco-Account-Info=\"S10.10.0.1\"" | /usr/local/bin/radclient -x 10.10.10.10:1700 coa cisco555
#!!! Service status query
/bin/echo "User-Name=\"test\",cisco-avpair=\"subscriber:command=service-status-query\",cisco-avpair+=\"subscriber:service-name=Basic_Internet_Service\",Cisco-Account-Info=\"S10.10.0.1\"" | /usr/local/bin/radclient -x 10.10.10.10:1700 coa cisco555
#!!! LOg off
/bin/echo "User-Name=\"f_annychka\",cisco-avpair=\"subscriber:command=account-logoff\",Cisco-Account-Info=\"S10.10.0.1\"" | /usr/local/bin/radclient -x 10.10.10.10:1700 coa cisco555
а дальше по аналогии
/bin/echo "User-Name=\"f_annychka\",cisco-avpair=\"subscriber:command=account-logon\",Cisco-Account-Info=\"S10.10.0.1\",Idle-Timeout=200" | /usr/local/bin/radclient -x 10.10.10.10:1700 coa cisco555
может у тебя нет сервисов и по этому не активизирует
включи еще debug radius
Пользователи должны авторизоваться в твоем случае на aaa group server radius weblogin
Туда запросы шлются? Если нет, то наверно нужно еще и пароль в CoA account-login запрос включать.
Это не тебе было адресовано, а топикстартеру.
Чтоб не плохело можно сделать debug condition username ... и только от нужного логина будет дебаг.
Так дело в том, что не шлются. Даже не пытаются, судя по debug radius. С user-password пробовал - та же самая картина.
Видать нужно другой иос попробовать, SB какой-нибудь, и если не поможет - smartnet покупать, и запрос в TAC писать.
в смысле "нет сервисов"? там есть policy-map, в котором написано, что должно произойти при получении account-logon'а.. там делается authorize, и уже при authorize собственно из радиуса в профиле пользователя получается в частности спискок сервисов, которе нужно активировать (ну и потом сами сервисы тоже из радиуса по необходимости).
Поставил 12(2)31 SB13 IOS, дебаг стал интерестнее:
Nov 14 10:27:19.538: RADIUS: COA received from id 3 172.30.1.130:36233, CoA Request, len 61
Nov 14 10:27:19.538: COA: 172.30.1.130 request queued
Nov 14 10:27:19.538: RADIUS: authenticator 6C 27 9A D4 4A FC 71 A8 - D0 72 1D 0F C0 70 85 DD
Nov 14 10:27:19.538: RADIUS: Vendor, Cisco [26] 22
Nov 14 10:27:19.538: RADIUS: ssg-account-info [250] 16 "S192.168.10.88"
Nov 14 10:27:19.538: RADIUS: User-Name [1] 6 "niki"
Nov 14 10:27:19.538: RADIUS: Vendor, Cisco [26] 13
Nov 14 10:27:19.538: RADIUS: ssg-command-code [252] 7
Nov 14 10:27:19.538: RADIUS: 01 6E 69 6B 69 [Account-Log-On niki]
Nov 14 10:27:19.538: ++++++ CoA Attribute List ++++++
Nov 14 10:27:19.538: 6427C44C 0 00000009 ssg-account-info(418) 14 S192.168.10.88
Nov 14 10:27:19.538: 6427C6BC 0 00000009 username(386) 4 niki
Nov 14 10:27:19.538: 6427C6CC 0 00000009 ssg-command-code(420) 5 01 6E 69 6B 69
Nov 14 10:27:19.538: RADIUS/ENCODE(0000000B):Orig. component type = IEDGE_IP_SIP
Nov 14 10:27:19.538: RADIUS(0000000B): sending
Nov 14 10:27:19.538: RADIUS(0000000B): Send CoA Nack Response to 172.30.1.130:36233 id 3, len 114
Nov 14 10:27:19.538: RADIUS: authenticator 25 E1 26 7F 47 11 2F F9 - C7 46 72 12 10 7A 9C 24
Nov 14 10:27:19.538: RADIUS: Vendor, Cisco [26] 15
Nov 14 10:27:19.538: RADIUS: ssg-command-code [252] 9
Nov 14 10:27:19.538: RADIUS: 10 32 3B 6E 69 6B 69 [Error-Code 2;niki]
Nov 14 10:27:19.538: RADIUS: Vendor, Cisco [26] 25
Nov 14 10:27:19.538: RADIUS: ssg-account-info [250] 19 "$MA0016.44c7.8336"
Nov 14 10:27:19.538: RADIUS: Reply-Message [18] 26
Nov 14 10:27:19.538: RADIUS: 4D 65 6D 6F 72 79 20 6F 72 20 69 6E 74 65 72 6E [Memory or intern]
Nov 14 10:27:19.538: RADIUS: 61 6C 20 65 72 72 6F 72 [ al error]
Nov 14 10:27:19.538: RADIUS: Dynamic-Author-Error[101] 6 Unsupported Service [405]
Ключевые слова - Memory or internal error и Unsupported Service
На всякий случай, посылаю coa вот такой программкой:
#include <stdio.h>
int main(int argc, char *argv[])
int c = 0x1;
printf("Cisco-Command-Code = %cniki\n",c);
printf("User-Name = niki\n");
printf("User-Password = xilinx\n");
printf("Cisco-Account-Info = S192.168.10.88\n");
return 0;
И собственно:
$ ./a.out|radclient 172.30.1.2:1700 coa xilinx
Received response ID 151, code 45, length = 114
Cisco-Command-Code = "\0202;niki"
Cisco-Account-Info = "$MA0016.44c7.8336"
Cisco-Account-Info = "S192.168.10.88"
Reply-Message = "Memory or internal error"
Error-Cause = Unsupported-Service
Да, и на всякий случай:
c7301.isg#sh ip subscriber ip 192.168.10.88
IP subscriber: 0016.44c7.8336, type connected, status up
display uid: 1, aaa uid: 11
session initiator: dhcp discovery
access address: 192.168.10.88
service address: 192.168.10.88
conditional debug flag: 0x0
control plane state: connected, start time: 00:18:17
data plane state: connected, start time: 00:18:14
arp entry: 192.168.10.88, GigabitEthernet0/1.1
forwarding statistics:
packets total: received 136, sent 141
bytes total: received 14580, sent 31735
packets dropped: 0, bytes dropped: 0
c7301.isg#sh sss session uid 1
Unique Session ID: 1
Identifier: 0016.44c7.8336
SIP subscriber access type(s): IP
Current SIP options: Req Fwding/Req Fwded
Session Up-time: 00:20:41, Last Changed: 00:20:39
Policy information:
Authentication status: authen
Active services associated with session:
name "INETTRAFF3_SERVICE"
name "LOCALTRAFF_SERVICE", applied before account logon
Rules, actions and conditions executed:
subscriber rule-map option82
condition always event session-start
100 authorize aaa list option82 identifier mac-address
Session inbound features:
Feature: IP Idle Timeout
Timeout value is 600
Idle time is 00:00:27
Feature: Session accounting
Method List: option82
Packets = 137, Bytes = 11819
Traffic classes:
Traffic class session ID: 2
ACL Name: LOCALTRAFF_ACL_IN, Packets = 3, Bytes = 175
Traffic class session ID: 3
ACL Name: INETTRAFF_ACL_IN, Packets = 134, Bytes = 11644
Default traffic is dropped
Unmatched Packets = 0, Re-classified packets (redirected) = 0
Session outbound features:
Packets = 144, Bytes = 29785
Traffic classes:
ACL Name: LOCALTRAFF_ACL_OUT, Packets = 3, Bytes = 903
ACL Name: INETTRAFF_ACL_OUT, Packets = 141, Bytes = 28882
Non-datapath features:
Feature: Session Timeout
Timeout value is 86400 seconds
Time remaining is 23:39:18
Configuration sources associated with this session:
Service: INETTRAFF3_SERVICE, Active Time = 00:20:41
AAA Service ID = 3858759681
Service: LOCALTRAFF_SERVICE, Active Time = 00:20:41
AAA Service ID = 3321888768
Interface: GigabitEthernet0/1.1, Active Time = 00:20:41
  • 3 years later...
У меня на оборот посылаю запрос CoA Account-logon
08:38:12: RADIUS: COA received from id 66 192.168.186.128:53736, CoA Request, len 106
08:38:12: COA: 192.168.186.128 request queued
08:38:12: RADIUS: authenticator D1 4A B0 48 65 59 89 EA - 8A 4B 8A CF EC 74 C6 C6
08:38:12: RADIUS: User-Name [1] 7 "poe02"
08:38:12: RADIUS: User-Password [2] 18 *
08:38:12: RADIUS: Vendor, Cisco [26] 40
08:38:12: RADIUS: Cisco AVpair [1] 34 "subscriber:command=account-logon"
08:38:12: RADIUS: Vendor, Cisco [26] 21
08:38:12: RADIUS: ssg-account-info [250] 15 "S172.10.10.19"
Кошка его проглатывает, но тут же выдаёт ответ CoA-ACK
08:38:12: RADIUS(00000024): Send CoA Ack Response to 192.168.186.128:53736 id 66, len 82
08:38:12: RADIUS: authenticator AE 91 93 D5 68 5A 40 24 - 6B 0E 89 10 1B 40 0F 38
08:38:12: RADIUS: Vendor, Cisco [26] 14
08:38:12: RADIUS: ssg-command-code [252] 8
08:38:12: RADIUS: 01 70 6F 65 30 32 [Account-Log-On poe02]
08:38:12: RADIUS: Vendor, Cisco [26] 27
08:38:12: RADIUS: ssg-account-info [250] 21 "$IVirtual-Access1.1"
Карта для события account-logon почему-то не срабатывает
Правило
policy-map type control MY_PPPoE_RULE
10 authenticate aaa list PPPoE
20 authorize aaa list PPPoE password cisco identifier nas-port
30 service-policy type service name UNAUTHOR
40 service-policy type service aaa list SERVICE-LOCAL name L4REDIRECT
50 set-timer SET-TIMER 5
class type control always event timed-policy-expiry
10 service disconnect
10 authenticate aaa list WEB_LOGON
20 service-policy type service unapply name L4REDIRECT
Странно
Edited by Dgoni_sp
Так же думаю, может пользователь должен находится в состоянии noauth ?
Просто у меня он в auth
Router-GW-7206VXR#sh subsc ses user poe02 det
Unique Session ID: 21
Identifier: poe02
SIP subscriber access type(s): PPPoE/PPP
Session Up-time: 00:00:24, Last Changed: 00:00:24
Interface: Virtual-Access1.1
Policy information:
Context 65D05F54: Handle 17000042
AAA_id 00000023: Flow_handle 0
Downloaded User profile, excluding services:
username "0/0/0"
reply-message "Authentication succeeded"
Downloaded User profile, including services:
username "0/0/0"
service-type 2 [Framed]
Framed-Protocol 1 [PPP]
Framed-MTU 1492 (0x5D4)
link-compression 5 [no-vj]
netmask 255.255.255.255
addr-pool "CLIENT-PPPoE"
traffic-class "input access-group 101"
l4redirect "redirect to group PORTAL"
Config history for session (recent to oldest):
Access-type: PPP Client: SM
Policy event: Got More Keys (Service)
Profile name: L4REDIRECT, 3 references
username "L4REDIRECT"
password <hidden>
Profile name: UNAUTHOR, 3 references
reply-message "AUTHORIZATION"
Profile name: apply-config-only, 2 references
username "0/0/0"
name "L4REDIRECT"
name "UNAUTHOR"
subscriber rule-map MY_PPPoE_RULE
20 authorize aaa list PPPoE identifier nas-port
Feature: Layer 4 Redirect
Rule table is empty
Traffic classes:
Traffic class session ID: 22
ACL Name: 101, Packets = 30, Bytes = 3624
Unmatched Packets (dropped) = 0, Re-classified packets (redirected) = 30
Feature: Compression
Header compression: no-vj
Feature: IP Config
Peer IP Address: 0.0.0.0 (F/F)
Address Pool: CLIENT-PPPoE (F)
Unnumbered Intf: [None]
Service: L4REDIRECT, Active Time = 00:00:24
Service: UNAUTHOR, Active Time = 00:00:24
Interface: Virtual-Template1, Active Time = 00:00:24
Router-GW-7206VXR#
Router-GW-7206VXR#
Router-GW-7206VXR#
Router-GW-7206VXR#sh users
Line User Host(s) Idle Location
* 0 con 0 idle 00:00:00
Interface User Mode Idle Peer Address
Vi1.1 poe02 PPPoE - 172.10.10.18
Router-GW-7206VXR#
Если делать CoA запрос на получении информации о сессии, получается следующее
Запрос
08:36:10: RADIUS: COA received from id 32 192.168.186.128:49994, CoA Request, len 103
08:36:10: COA: 192.168.186.128 request queued
08:36:10: RADIUS: authenticator E2 08 8D A6 86 E9 7A 23 - 50 E6 01 FF D5 5A 54 38
08:36:10: RADIUS: User-Name [1] 7 "poe02"
08:36:10: RADIUS: Vendor, Cisco [26] 55
08:36:10: RADIUS: Cisco AVpair [1] 49 "subscriber:command=account-profile-status-query"
08:36:10: RADIUS: Vendor, Cisco [26] 21
08:36:10: RADIUS: ssg-account-info [250] 15 "S172.10.10.19"
Ответ
08:36:10: RADIUS(00000024): Send CoA Ack Response to 192.168.186.128:49994 id 32, len 298
08:36:10: RADIUS: authenticator F8 D9 B2 EA 5D 74 C0 91 - C2 4C 2D 5E A0 B4 AB 91
08:36:10: RADIUS: Vendor, Cisco [26] 47
08:36:10: RADIUS: ssg-account-info [250] 41 "N1L4REDIRECT;113;poe02;100;54;8708;5138"
08:36:10: RADIUS: Vendor, Cisco [26] 45
08:36:10: RADIUS: ssg-account-info [250] 39 "N1UNAUTHOR;113;poe02;100;54;8708;5138"
08:36:10: RADIUS: Vendor, Cisco [26] 27
08:36:10: RADIUS: ssg-account-info [250] 21 "$IVirtual-Access1.1"
08:36:10: RADIUS: Vendor, Cisco [26] 10
08:36:10: RADIUS: ssg-command-code [252] 4
08:36:10: RADIUS: 04 31 [Account-Ping 1]
08:36:10: RADIUS: User-Name [1] 7 "0/0/0"
08:36:10: RADIUS: Reply-Message [18] 26
08:36:10: RADIUS: 41 75 74 68 65 6E 74 69 63 61 74 69 6F 6E 20 73 [Authentication s]
08:36:10: RADIUS: 75 63 63 65 65 64 65 64 [ ucceeded]
08:36:10: RADIUS: Vendor, Cisco [26] 22
08:36:10: RADIUS: Cisco AVpair [1] 16 "sg-version=1.0"
08:36:10: RADIUS: Vendor, Cisco [26] 30
08:36:10: RADIUS: cisco-nas-port [2] 24 "nas-port:0.0.0.0:0/0/0"
08:36:10: RADIUS: NAS-Port [5] 6 0
08:36:10: RADIUS: NAS-Port-Id [87] 24 "nas-port:0.0.0.0:0/0/0"
08:36:10: RADIUS: Framed-IP-Address [8] 6 172.10.10.19
В ответе есть параметр Account-Ping значение которого равно 1, хотя по докам 0. Наверное из-за того что 0 - это noauth, а 1 - auth.
Но это настолько категорично ?
  • 8 years later...
Добрый день! Похожая проблема.
Sending CoA-Request of id 67 to 10.0.9.99 port 1777
    User-Name = "100.110.0.1"
    Cisco-Account-Info = "S100.110.0.1"
    Cisco-AVPair = "subscriber:command=account-logoff"
rad_recv: CoA-NAK packet from host 10.0.9.99 port 1777, id=67, length=99
    Cisco-Command-Code = "\0202;100.110.0.1"
    Reply-Message = "No valid Session"
Feb 19 12:13:23: RADIUS: COA  received from id 67 10.0.9.1:43076, CoA Request, len 94
Feb 19 12:13:23: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Feb 19 12:13:23: RADIUS(00000000): sending
Feb 19 12:13:23: RADIUS(00000000): Send CoA Nack Response to 10.0.9.1:43076 id 67, len 99
Feb 19 12:13:23: RADIUS:  authenticator 06 73 27 4F 52 2F 95 A7 - 63 B0 92 21 50 54 5A B2
Feb 19 12:13:23: RADIUS:  User-Name           [1]   13  "100.110.0.1"
Feb 19 12:13:23: RADIUS:  Vendor, Cisco       [26]  20
Feb 19 12:13:23: RADIUS:   ssg-account-info   [250] 14  "S100.110.0.1"
Feb 19 12:13:23: RADIUS:  Vendor, Cisco       [26]  22
TCS0.IZK.ToB#
Feb 19 12:13:23: RADIUS:   ssg-command-code   [252] 16
Feb 19 12:13:23: RADIUS:   10 32 3B 31 30 30 2E 31 31 30 2E 30 2E 31     [Error-Code 2;100.110.0.1]
Feb 19 12:13:23: RADIUS:  Reply-Message       [18]  18
Feb 19 12:13:23: RADIUS:   4E 6F 20 76 61 6C 69 64 20 53 65 73 73 69 6F 6E  [ No valid Session]
Feb 19 12:13:23: RADIUS:  Dynamic-Author-Error[101] 6   Unsupported Service       [405]
#!/bin/bash
nas_id=10.0.9.99
nas_port=1777
nas_secret=ХХХХХХ
sess_id="$1"
/bin/echo "User-Name="$1", Cisco-Account-Info=S"$1", cisco-avpair=\"subscriber:command=account-logoff\"" | /usr/bin/radclient -x "$nas_id":"$nas_port" coa "$nas_secret"
Подскажите куда копать?
На ASR1001:
class type control always event account-logoff 1 service disconnect delay 5
В 19.02.2020 в 11:15, gadrus42 сказал:
TCS0.IZK.ToB#
#!/bin/bash
nas_id=10.0.9.99
nas_port=1777
nas_secret=ХХХХХХ
sess_id="$1"
На ASR1001:
Дык а сессия точно такая есть?
