Имеем:
FreeBSD unico-lego.vgg.ru 6.4-PRERELEASE
В ядре:
# IPFW OPTIONS
options         IPFIREWALL
options         IPFIREWALL_VERBOSE
options         IPFIREWALL_FORWARD
options         IPSTEALTH
options         IPFIREWALL_VERBOSE_LIMIT=1000
options         IPDIVERT
options         DUMMYNET
options         IPFIREWALL_DEFAULT_TO_ACCEPT
options         DEVICE_POLLING
options         HZ=1000
options         INCLUDE_CONFIG_FILE
Собираю тестовую схему подключения абонентов - задача оттестировать безлимитные тарифы:
[PROV] <-> [uif (fxp1)] [FreeBSD][cif (fxp0)] <-> [CLI]
В sysctl:
net.inet.ip.forwarding=1
net.inet.ip.dummynet.io_fast=1
net.inet.ip.dummynet.hash_size=16384
net.inet.ip.fw.one_pass=0
net.inet.ip.dummynet.expire=0
В IPFW только правила, указанные ниже и ничего кроме них:
#!/bin/sh
# 1. Global variables
# 1.1 Interfaces
# 1.1.1 Uplink interface
uif="fxp1"
unet="194.128.23.252/30"
uip="194.128.23.253"
# 1.1.2 Client Interface
cif="fxp0"
cnet="172.16.2.252/30"
cip="172.16.2.253"
# 1.1.3 Contol Interface
mif="vr0"
mnet="192.168.23.0/24"
mip="192.168.23.71"
# 1.2 IPFW executable
fwcmd='/sbin/ipfw -q'
# 2. Functions (empty by now)
# 3. Default ruleset
# 3.1 Flushing all rules
echo "Flushing all rules."
${fwcmd} -f flush
${fwcmd} -f pipe flush
# 3.2 Shaper
# 3.2.1 Template :: Unlim 64Kbit/s
${fwcmd} pipe 101 config bw 64Kbit/s
${fwcmd} pipe 102 config bw 64Kbit/s
${fwcmd} queue 101 config pipe 101 mask dst-ip 0xfffffffc queue 7KBytes
${fwcmd} queue 102 config pipe 102 mask src-ip 0xfffffffc queue 7KBytes
# 3.2.2 Rules :: Shape IT
${fwcmd} add 101 queue 101 ip from any to ${cnet} out via ${cif}
${fwcmd} add 102 queue 102 ip from ${cnet} to any out via ${uif}
При такой конфигурации возникает, значительная задержка. Вот пример:
ping -s 1472 -i 0.2 -S 172.16.2.254 194.128.23.254
PING 194.128.23.254 (194.128.23.254) from 172.16.2.254: 1472 data bytes
1480 bytes from 194.128.23.254: icmp_seq=0 ttl=63 time=375.703 ms
1480 bytes from 194.128.23.254: icmp_seq=1 ttl=63 time=374.245 ms
1480 bytes from 194.128.23.254: icmp_seq=2 ttl=63 time=376.296 ms
1480 bytes from 194.128.23.254: icmp_seq=3 ttl=63 time=374.236 ms
Хотелось бы разобраться почему, ведь очередь я не перегружаю и, в таком случае, при net.inet.ip.dummynet.io_fast=1 - задержка эмулироваться не должна?
Или я принципиально неверно строю схему шейпинга?
P.S> Таблица использовать планируется, но пока хочется разобраться с текущей проблемой.
Edited by Dm1try
  • 6 months later...
тут приводили расчеты по перегрузу очереди. Считается оно чуть-ли не в битах за тик.
хм, интересно, а ссылка есть или ключ по которому искать?
Очевидно, что эмуляция низкой скорости 64 kbit/s поверх быстрой среды 100 mbit/s с пакетами по 1472 байта достижима только с помощью больших задержек. Уменьшаются ли задержки при уменьшении размера пакета?
queue 7KBytes -- это вообще зачем? Размер очереди лучше указывать в слотах, а не в байтах.
Edited by photon
как например расчитать размер очереди для 70мбитного pipe при hz=1000 и при hz=4000?
Можно оставить и дефолтные 50 слотов, т.к. разница между 70 и 100 мбитами невелика. Главное не ставить слишком малый размер очереди, чтобы пакеты не терялись.
а где в коде либо в коментариях разроботчиков системы dummynet можно про это почитать более развернуто?
собственно спрашиваю потому что случается так что на пайпах шириной в 5-70 и более мбит вижу до 15% дропов при недогруженном канале
смотрю при помощи
ipfw pipe <n> show;sleep 1;ipfw pipe <n> show
это глюк отображения или чего либо ещё? как это выяснить в какую сторону двигатся?
ЗЫ подобное наблюдаю на freebsd 6.x
Edited by t0ly
спасибо за ссылку, но тут ссылка на расчёт задержки, как задержка корелирует с размером очереди необходимой для настройки в pipe?
Я Вам отвечал вот на это.
