Вот с нат таблицы данные
802 UDP 192.168.0.154:3620 10.35.101.202:21452 81.25.32.9:53 85
803 UDP 192.168.0.211:4945 10.35.101.202:21453 81.25.32.9:53 85
804 UDP 192.168.0.154:3622 10.35.101.202:21454 81.25.32.9:53 85
805 UDP 192.168.0.211:4947 10.35.101.202:21455 81.25.32.9:53 85
806 UDP 192.168.0.211:4951 10.35.101.202:21459 81.25.32.9:53 85
807 UDP 192.168.0.154:3628 10.35.101.202:21460 81.25.32.9:53 85
808 UDP 192.168.0.211:4953 10.35.101.202:21461 81.25.32.9:53 85
809 UDP 192.168.0.154:3630 10.35.101.202:21462 81.25.32.9:53 85
810 UDP 192.168.0.211:4955 10.35.101.202:21463 81.25.32.9:53 85
811 UDP 192.168.0.154:3632 10.35.101.202:21464 81.25.32.9:53 85
812 UDP 192.168.0.211:4957 10.35.101.202:21465 81.25.32.9:53 85
813 UDP 192.168.0.154:3634 10.35.101.202:21466 81.25.32.9:53 85
814 UDP 192.168.0.211:4959 10.35.101.202:21467 81.25.32.9:53 85
815 UDP 192.168.0.154:3636 10.35.101.202:21468 81.25.32.9:53 85
816 UDP 192.168.0.211:4961 10.35.101.202:21469 81.25.32.9:53 85
817 UDP 192.168.0.211:4963 10.35.101.202:21470 81.25.32.9:53 84
818 UDP 192.168.0.154:3638 10.35.101.202:21471 81.25.32.9:53 84
819 UDP 192.168.0.211:4965 10.35.101.202:21472 81.25.32.9:53 84
820 UDP 192.168.0.154:3640 10.35.101.202:21473 81.25.32.9:53 84
821 UDP 192.168.0.154:3642 10.35.101.202:21474 81.25.32.9:53 84
822 UDP 192.168.0.154:3644 10.35.101.202:21475 81.25.32.9:53 84
823 UDP 192.168.0.154:3646 10.35.101.202:21479 81.25.32.9:53 81
824 UDP 192.168.0.211:4973 10.35.101.202:21480 81.25.32.9:53 81
825 UDP 192.168.0.154:3648 10.35.101.202:21481 81.25.32.9:53 81
826 UDP 192.168.0.211:4975 10.35.101.202:21482 81.25.32.9:53 81
827 UDP 192.168.0.154:3650 10.35.101.202:21483 81.25.32.9:53 81
828 UDP 192.168.0.211:4977 10.35.101.202:21484 81.25.32.9:53 81
829 UDP 192.168.0.154:3652 10.35.101.202:21485 81.25.32.9:53 81
830 UDP 192.168.0.211:4979 10.35.101.202:21486 81.25.32.9:53 81
831 UDP 192.168.0.154:3654 10.35.101.202:21487 81.25.32.9:53 81
832 UDP 192.168.0.211:4981 10.35.101.202:21488 81.25.32.9:53 81
833 UDP 192.168.0.154:3656 10.35.101.202:21489 81.25.32.9:53 81
834 UDP 192.168.0.211:4983 10.35.101.202:21490 81.25.32.9:53 82
835 UDP 192.168.0.154:3658 10.35.101.202:21491 81.25.32.9:53 82
836 UDP 192.168.0.211:4985 10.35.101.202:21492 81.25.32.9:53 82
837 UDP 192.168.0.154:3660 10.35.101.202:21493 81.25.32.9:53 82
838 UDP 192.168.0.211:4987 10.35.101.202:21494 81.25.32.9:53 82
839 UDP 192.168.0.154:3662 10.35.101.202:21495 81.25.32.9:53 82
840 UDP 192.168.0.211:4997 10.35.101.202:21505 81.25.32.9:53 82
841 UDP 192.168.0.211:4999 10.35.101.202:21506 81.25.32.9:53 82
842 UDP 192.168.0.154:3674 10.35.101.202:21507 81.25.32.9:53 82
843 UDP 192.168.0.211:1026 10.35.101.202:21508 81.25.32.9:53 82
844 UDP 192.168.0.154:3676 10.35.101.202:21509 81.25.32.9:53 82
845 UDP 192.168.0.211:1028 10.35.101.202:21510 81.25.32.9:53 82
846 UDP 192.168.0.154:3678 10.35.101.202:21511 81.25.32.9:53 82
847 UDP 192.168.0.211:1030 10.35.101.202:21512 81.25.32.9:53 82
848 UDP 192.168.0.154:3680 10.35.101.202:21513 81.25.32.9:53 82
849 UDP 192.168.0.154:3682 10.35.101.202:21514 81.25.32.9:53 82
850 UDP 192.168.0.154:3684 10.35.101.202:21515 81.25.32.9:53 82
851 UDP 192.168.0.211:1040 10.35.101.202:21524 81.25.32.9:53 79
852 UDP 192.168.0.154:3694 10.35.101.202:21525 81.25.32.9:53 79
853 UDP 192.168.0.211:1042 10.35.101.202:21526 81.25.32.9:53 79
854 UDP 192.168.0.154:3696 10.35.101.202:21527 81.25.32.9:53 79
855 UDP 192.168.0.211:1044 10.35.101.202:21528 81.25.32.9:53 79
856 UDP 192.168.0.154:3698 10.35.101.202:21529 81.25.32.9:53 79
857 UDP 192.168.0.211:1046 10.35.101.202:21530 81.25.32.9:53 79
858 UDP 192.168.0.211:1048 10.35.101.202:21531 81.25.32.9:53 79
859 UDP 192.168.0.154:3700 10.35.101.202:21532 81.25.32.9:53 79
860 UDP 192.168.0.211:1050 10.35.101.202:21533 81.25.32.9:53 78
861 UDP 192.168.0.154:3702 10.35.101.202:21534 81.25.32.9:53 78
862 UDP 192.168.0.211:1052 10.35.101.202:21535 81.25.32.9:53 78
863 UDP 192.168.0.154:3704 10.35.101.202:21536 81.25.32.9:53 78
864 UDP 192.168.0.154:3708 10.35.101.202:21540 81.25.32.9:53 78
865 UDP 192.168.0.211:1058 10.35.101.202:21541 81.25.32.9:53 78
866 UDP 192.168.0.154:3710 10.35.101.202:21542 81.25.32.9:53 78
867 UDP 192.168.0.211:1060 10.35.101.202:21543 81.25.32.9:53 78
868 UDP 192.168.0.154:3712 10.35.101.202:21544 81.25.32.9:53 78
869 UDP 192.168.0.211:1062 10.35.101.202:21545 81.25.32.9:53 78
870 UDP 192.168.0.154:3714 10.35.101.202:21546 81.25.32.9:53 78
871 UDP 192.168.0.211:1064 10.35.101.202:21547 81.25.32.9:53 78
872 UDP 192.168.0.154:3716 10.35.101.202:21548 81.25.32.9:53 78
873 UDP 192.168.0.211:1066 10.35.101.202:21549 81.25.32.9:53 78
874 UDP 192.168.0.154:3718 10.35.101.202:21550 81.25.32.9:53 78
875 UDP 192.168.0.211:1068 10.35.101.202:21551 81.25.32.9:53 78
876 UDP 192.168.0.154:3720 10.35.101.202:21552 81.25.32.9:53 78
877 UDP 192.168.0.211:1070 10.35.101.202:21553 81.25.32.9:53 78
878 UDP 192.168.0.154:3722 10.35.101.202:21554 81.25.32.9:53 78
879 UDP 192.168.0.211:1072 10.35.101.202:21556 81.25.32.9:53 75
880 UDP 192.168.0.211:1084 10.35.101.202:21568 81.25.32.9:53 75
881 UDP 192.168.0.154:3738 10.35.101.202:21569 81.25.32.9:53 75
882 UDP 192.168.0.211:1086 10.35.101.202:21570 81.25.32.9:53 75
883 UDP 192.168.0.211:1088 10.35.101.202:21571 81.25.32.9:53 75
884 UDP 192.168.0.154:3740 10.35.101.202:21572 81.25.32.9:53 75
885 UDP 192.168.0.211:1090 10.35.101.202:21573 81.25.32.9:53 75
886 UDP 192.168.0.154:3742 10.35.101.202:21574 81.25.32.9:53 75
887 UDP 192.168.0.211:1092 10.35.101.202:21575 81.25.32.9:53 75
888 UDP 192.168.0.154:3744 10.35.101.202:21576 81.25.32.9:53 75
889 UDP 192.168.0.154:3748 10.35.101.202:21580 81.25.32.9:53 75
890 UDP 192.168.0.211:1098 10.35.101.202:21581 81.25.32.9:53 75
891 UDP 192.168.0.154:3750 10.35.101.202:21582 81.25.32.9:53 75
892 UDP 192.168.0.211:1100 10.35.101.202:21583 81.25.32.9:53 75
893 UDP 192.168.0.154:3752 10.35.101.202:21584 81.25.32.9:53 75
894 UDP 192.168.0.211:1102 10.35.101.202:21585 81.25.32.9:53 75
895 UDP 192.168.0.154:3754 10.35.101.202:21586 81.25.32.9:53 75
896 UDP 192.168.0.211:1104 10.35.101.202:21587 81.25.32.9:53 75
897 UDP 192.168.0.154:3756 10.35.101.202:21588 81.25.32.9:53 75
898 UDP 192.168.0.211:1106 10.35.101.202:21589 81.25.32.9:53 74
899 UDP 192.168.0.154:3758 10.35.101.202:21590 81.25.32.9:53 74
900 UDP 192.168.0.211:1108 10.35.101.202:21591 81.25.32.9:53 75
901 UDP 192.168.0.154:3760 10.35.101.202:21592 81.25.32.9:53 75
902 UDP 192.168.0.211:1110 10.35.101.202:21593 81.25.32.9:53 75
903 UDP 192.168.0.154:3762 10.35.101.202:21594 81.25.32.9:53 75
904 UDP 192.168.0.154:3764 10.35.101.202:21595 81.25.32.9:53 75
905 UDP 192.168.0.7:1027 10.35.101.202:21596 81.25.32.34:53 62
906 UDP 192.168.0.211:1128 10.35.101.202:21612 81.25.32.9:53 72
907 UDP 192.168.0.154:3780 10.35.101.202:21613 81.25.32.9:53 72
908 UDP 192.168.0.211:1130 10.35.101.202:21614 81.25.32.9:53 72
909 UDP 192.168.0.154:3782 10.35.101.202:21615 81.25.32.9:53 72
910 UDP 192.168.0.211:1132 10.35.101.202:21616 81.25.32.9:53 72
911 UDP 192.168.0.154:3788 10.35.101.202:21621 81.25.32.9:53 72
912 UDP 192.168.0.211:1138 10.35.101.202:21622 81.25.32.9:53 72
913 UDP 192.168.0.154:3790 10.35.101.202:21623 81.25.32.9:53 72
914 UDP 192.168.0.154:3794 10.35.101.202:21627 81.25.32.9:53 72
915 UDP 192.168.0.211:1144 10.35.101.202:21628 81.25.32.9:53 72
916 UDP 192.168.0.154:3796 10.35.101.202:21629 81.25.32.9:53 72
917 UDP 192.168.0.211:1146 10.35.101.202:21630 81.25.32.9:53 72
918 UDP 192.168.0.154:3798 10.35.101.202:21631 81.25.32.9:53 72
919 UDP 192.168.0.211:1148 10.35.101.202:21632 81.25.32.9:53 72
920 UDP 192.168.0.154:3800 10.35.101.202:21633 81.25.32.9:53 72
921 UDP 192.168.0.211:1150 10.35.101.202:21634 81.25.32.9:53 72
922 UDP 192.168.0.154:3802 10.35.101.202:21635 81.25.32.9:53 72
923 UDP 192.168.0.154:3804 10.35.101.202:21636 81.25.32.9:53 72
924 UDP 192.168.0.11:2111 10.35.101.202:21637 81.25.32.9:53 69
925 UDP 192.168.0.211:1160 10.35.101.202:21645 81.25.32.9:53 68
926 UDP 192.168.0.154:3812 10.35.101.202:21646 81.25.32.9:53 68
927 UDP 192.168.0.211:1162 10.35.101.202:21647 81.25.32.9:53 68
928 UDP 192.168.0.211:1172 10.35.101.202:21657 81.25.32.9:53 68
929 UDP 192.168.0.211:1174 10.35.101.202:21659 81.25.32.9:53 68
930 UDP 192.168.0.154:3824 10.35.101.202:21660 81.25.32.9:53 68
931 UDP 192.168.0.211:1176 10.35.101.202:21661 81.25.32.9:53 68
932 UDP 192.168.0.154:3826 10.35.101.202:21662 81.25.32.9:53 68
933 UDP 192.168.0.211:1178 10.35.101.202:21663 81.25.32.9:53 68
934 UDP 192.168.0.154:3828 10.35.101.202:21664 81.25.32.9:53 68
935 UDP 192.168.0.211:1180 10.35.101.202:21665 81.25.32.9:53 68
936 UDP 192.168.0.154:3830 10.35.101.202:21666 81.25.32.9:53 68
937 UDP 192.168.0.154:3844 10.35.101.202:21678 81.25.32.9:53 68
938 UDP 192.168.0.154:3872 10.35.101.202:21709 81.25.32.9:53 64
939 UDP 192.168.0.211:1226 10.35.101.202:21710 81.25.32.9:53 64
940 UDP 192.168.0.154:3874 10.35.101.202:21711 81.25.32.9:53 64
941 UDP 192.168.0.211:1228 10.35.101.202:21712 81.25.32.9:53 64
942 UDP 192.168.0.154:3876 10.35.101.202:21713 81.25.32.9:53 64
943 UDP 192.168.0.211:1230 10.35.101.202:21714 81.25.32.9:53 64
944 UDP 192.168.0.154:3878 10.35.101.202:21715 81.25.32.9:53 64
945 UDP 192.168.0.154:3880 10.35.101.202:21716 81.25.32.9:53 64
946 UDP 192.168.0.154:3882 10.35.101.202:21717 81.25.32.9:53 64
947 UDP 192.168.0.154:3884 10.35.101.202:21718 81.25.32.9:53 64
948 UDP 192.168.0.211:1232 10.35.101.202:21719 81.25.32.9:53 61
949 UDP 192.168.0.211:1234 10.35.101.202:21720 81.25.32.9:53 61
950 UDP 192.168.0.154:3886 10.35.101.202:21721 81.25.32.9:53 60
951 UDP 192.168.0.211:1236 10.35.101.202:21722 81.25.32.9:53 60
952 UDP 192.168.0.154:3888 10.35.101.202:21723 81.25.32.9:53 60
953 UDP 192.168.0.211:1238 10.35.101.202:21724 81.25.32.9:53 60
954 UDP 192.168.0.154:3890 10.35.101.202:21725 81.25.32.9:53 60
955 UDP 192.168.0.154:3924 10.35.101.202:21758 81.25.32.9:53 59
956 UDP 192.168.0.211:1272 10.35.101.202:21759 81.25.32.9:53 56
957 UDP 192.168.0.211:1274 10.35.101.202:21760 81.25.32.9:53 56
958 UDP 192.168.0.211:1280 10.35.101.202:21765 81.25.32.9:53 56
959 UDP 192.168.0.211:1292 10.35.101.202:21776 81.25.32.9:53 56
960 UDP 192.168.0.154:3940 10.35.101.202:21777 81.25.32.9:53 56
961 UDP 192.168.0.211:1294 10.35.101.202:21778 81.25.32.9:53 56
962 UDP 192.168.0.154:3942 10.35.101.202:21779 81.25.32.9:53 56
963 UDP 192.168.0.211:1296 10.35.101.202:21780 81.25.32.9:53 56
964 UDP 192.168.0.154:3944 10.35.101.202:21781 81.25.32.9:53 56
965 UDP 192.168.0.211:1298 10.35.101.202:21782 81.25.32.9:53 56
966 UDP 192.168.0.154:3946 10.35.101.202:21783 81.25.32.9:53 56
967 UDP 192.168.0.211:1300 10.35.101.202:21784 81.25.32.9:53 56
968 UDP 192.168.0.154:3948 10.35.101.202:21785 81.25.32.9:53 56
969 UDP 192.168.0.154:3966 10.35.101.202:21803 81.25.32.9:53 52
970 UDP 192.168.0.211:1320 10.35.101.202:21804 81.25.32.9:53 52
971 UDP 192.168.0.154:3968 10.35.101.202:21805 81.25.32.9:53 52
972 UDP 192.168.0.211:1322 10.35.101.202:21806 81.25.32.9:53 52
973 UDP 192.168.0.211:1340 10.35.101.202:21824 81.25.32.9:53 52
974 UDP 192.168.0.211:1342 10.35.101.202:21826 81.25.32.9:53 52
975 UDP 192.168.0.211:1360 10.35.101.202:21845 81.25.32.9:53 48
976 UDP 192.168.0.211:1668 10.35.101.202:22004 81.25.32.9:53 19
977 UDP 192.168.0.211:1670 10.35.101.202:22005 81.25.32.9:53 19
978 UDP 192.168.0.154:4033 10.35.101.202:22006 81.25.32.9:53 18
979 UDP 192.168.0.211:1710 10.35.101.202:22026 81.25.32.9:53 15
980 UDP 192.168.0.211:1718 10.35.101.202:22031 81.25.32.9:53 12
981 UDP 192.168.0.211:1720 10.35.101.202:22032 81.25.32.9:53 12
982 UDP 192.168.0.211:1722 10.35.101.202:22033 81.25.32.9:53 12
983 UDP 192.168.0.211:1724 10.35.101.202:22034 81.25.32.9:53 12
984 UDP 192.168.0.211:1726 10.35.101.202:22035 81.25.32.9:53 12
985 UDP 192.168.0.211:1728 10.35.101.202:22036 81.25.32.9:53 12
986 UDP 192.168.0.211:1730 10.35.101.202:22037 81.25.32.9:53 12
987 UDP 192.168.0.211:1732 10.35.101.202:22038 81.25.32.9:53 12
988 UDP 192.168.0.211:1734 10.35.101.202:22039 81.25.32.9:53 11
989 UDP 192.168.0.211:1736 10.35.101.202:22040 81.25.32.9:53 11
990 UDP 192.168.0.211:1738 10.35.101.202:22041 81.25.32.9:53 12
991 UDP 192.168.0.211:1740 10.35.101.202:22042 81.25.32.9:53 12
992 UDP 192.168.0.211:1742 10.35.101.202:22043 81.25.32.9:53 12
993 UDP 192.168.0.211:1744 10.35.101.202:22044 81.25.32.9:53 12
994 UDP 192.168.0.211:1746 10.35.101.202:22045 81.25.32.9:53 12
995 UDP 192.168.0.211:1748 10.35.101.202:22046 81.25.32.9:53 12
996 UDP 192.168.0.211:1828 10.35.101.202:22087 81.25.32.9:53 5
997 UDP 192.168.0.211:1830 10.35.101.202:22088 81.25.32.9:53 5
998 UDP 192.168.0.211:1834 10.35.101.202:22090 81.25.32.9:53 2
999 UDP 192.168.0.211:1836 10.35.101.202:22091 81.25.32.9:53 2
1000 UDP 192.168.0.211:1838 10.35.101.202:22092 81.25.32.9:53 2
1001 TCP 192.168.0.7:2236 10.35.101.202:17090 81.25.32.67:1723 41
1002 GRE 192.168.0.154 10.35.101.202 0.0.0.0 2
1003 UDP 192.168.0.211:1840 10.35.101.202:22093 81.25.32.9:53 2
1004 UDP 192.168.0.211:1842 10.35.101.202:22094 81.25.32.9:53 1
1005 UDP 192.168.0.211:1844 10.35.101.202:22095 81.25.32.9:53 1
1006 UDP 192.168.0.211:1846 10.35.101.202:22096 81.25.32.9:53 1
1007 UDP 192.168.0.211:1848 10.35.101.202:22097 81.25.32.9:53 1
1008 UDP 192.168.0.211:1850 10.35.101.202:22098 81.25.32.9:53 1
1009 UDP 192.168.0.211:1852 10.35.101.202:22099 81.25.32.9:53 1
1010 UDP 192.168.0.211:1854 10.35.101.202:22100 81.25.32.9:53 1
1011 UDP 192.168.0.211:1856 10.35.101.202:22101 81.25.32.9:53 1
1012 UDP 192.168.0.211:1858 10.35.101.202:22102 81.25.32.9:53 1
1013 UDP 192.168.0.211:1860 10.35.101.202:22103 81.25.32.9:53 1
Компьютеры с адресами 211 и 154 обсолютно чистые, системы стоят буквально сутки, на 211 новый комп
На обоих стоят антивирус кашмара 8.0.4**, и что-то вечно стучит на модем и виснет модем или обрывает VPNки...
На подобных машинках где есть 8 кашмарский тоже флудят
Сканировал ещё нортоном, авастом всё голо
В чем может быть проблема?
Edited by BAHbKA
http://technet.microsoft.com/en-us/sysinte...s/bb897437.aspx вот тулза
а вообще это вирусы с оч большой вероятностью. сча он просто мочит днс серваки вашего провайдера чтобы собрать нужные ему айпишники, а скоро начнёт спамить или флудить.
