В придачу в к вот такому в логе
[2015-04-16 14:35:08]: debug: libnetlink: RTNETLINK answers: Invalid argument
[2015-04-16 14:35:08]: error: eth1: ipoe: nl_create: error talking to kernel
[2015-04-16 14:35:08]: error: eth1: ipoe: missing IPOE_ATTR_IFINDEX attribute
[2015-04-16 14:35:08]: error: eth1: ipoe: failed to create interface
[2015-04-16 14:35:08]: debug: eth1: terminate
[2015-04-16 14:35:08]:  info: eth1: ipoe: session finished
появилось в dmesg:
[  280.311561] ------------[ cut here ]------------
[  280.311566] WARNING: CPU: 2 PID: 4319 at net/core/dev.c:6022 register_netdevice+0x20c/0x360()
[  280.311567] netdevice: (unregistered net_device)
Buggy VLAN acceleration in driver!
[  280.311568] Modules linked in: cls_flow sch_htb ifb ipoe(O) 8021q igb e1000e
[  280.311574] CPU: 2 PID: 4319 Comm: accel-pppd Tainted: G        W  O 3.14.38-gentoo #2
[  280.311575] Hardware name: Intel Corporation S3420GP/S3420GP, BIOS S3420GP.86B.01.00.0042.042920102218 04/29/2010
[  280.311576]  00000000 00000000 f332ba6c c15baf14 f332baac f332ba9c c103f279 c175375c
[  280.311580]  f332bac8 000010df c174e922 00001786 c14b222c c14b222c c17de600 f3340800
[  280.311583]  ffffffea f332bab4 c103f2be 00000009 f332baac c175375c f332bac8 f332bae8
[  280.311586] Call Trace:
[  280.311589]  [<c15baf14>] dump_stack+0x41/0x52
[  280.311592]  [<c103f279>] warn_slowpath_common+0x79/0x90
[  280.311594]  [<c14b222c>] ? register_netdevice+0x20c/0x360
[  280.311596]  [<c14b222c>] ? register_netdevice+0x20c/0x360
[  280.311598]  [<c103f2be>] warn_slowpath_fmt+0x2e/0x30
[  280.311600]  [<c14b222c>] register_netdevice+0x20c/0x360
[  280.311602]  [<c15bf41b>] ? mutex_lock+0xb/0x23
[  280.311605]  [<f85811e9>] ipoe_nl_cmd_create+0x269/0x460 [ipoe]
[  280.311623]  [<c14d7439>] genl_rcv_msg+0x209/0x380
[  280.311626]  [<c14d7230>] ? __genl_register_family+0x5c0/0x5c0
[  280.311628]  [<c14d5aee>] netlink_rcv_skb+0x8e/0xa0
[  280.311630]  [<c14d5f2c>] genl_rcv+0x1c/0x30
[  280.311631]  [<c14d5244>] netlink_unicast+0xd4/0x1b0
[  280.311633]  [<c14d5586>] netlink_sendmsg+0x266/0x640
[  280.311635]  [<c10e1e5e>] ? mempool_alloc_slab+0xe/0x10
[  280.311637]  [<c10e1f49>] ? mempool_alloc+0x39/0x100
[  280.311640]  [<c149a3e9>] sock_sendmsg+0x69/0x90
[  280.311642]  [<c126fd03>] ? _copy_from_user+0x33/0x40
[  280.311644]  [<c126fd03>] ? _copy_from_user+0x33/0x40
[  280.311646]  [<c14a5daf>] ? verify_iovec+0x3f/0xc0
[  280.311649]  [<c149a70a>] ___sys_sendmsg.part.13+0x24a/0x260
[  280.311651]  [<c107699a>] ? __wake_up+0x3a/0x50
[  280.311653]  [<c14d490b>] ? netlink_insert+0x10b/0x1e0
[  280.311655]  [<c126fcbf>] ? _copy_to_user+0x1f/0x30
[  280.311657]  [<c1499a8f>] ? move_addr_to_user+0x8f/0xb0
[  280.311659]  [<c1498f8f>] ? sockfd_lookup_light+0xf/0x60
[  280.311661]  [<c1499cfd>] ? SYSC_getsockname+0x5d/0xb0
[  280.311664]  [<c111f3c2>] ? get_empty_filp+0x52/0x1a0
[  280.311666]  [<c126fd03>] ? _copy_from_user+0x33/0x40
[  280.311668]  [<c149b11f>] __sys_sendmsg+0x3f/0x70
[  280.311670]  [<c149bc86>] SYSC_socketcall+0x796/0x950
[  280.311673]  [<c10e604e>] ? free_hot_cold_page_list+0x3e/0x80
[  280.311675]  [<c110e55a>] ? free_pages_and_swap_cache+0x8a/0xa0
[  280.311677]  [<c10ff1a3>] ? tlb_flush_mmu.part.90+0x43/0x80
[  280.311679]  [<c10ff72d>] ? tlb_finish_mmu+0x3d/0x40
[  280.311682]  [<c11043b9>] ? remove_vma+0x39/0x40
[  280.311683]  [<c11043b9>] ? remove_vma+0x39/0x40
[  280.311686]  [<c1106226>] ? do_munmap+0x216/0x2c0
[  280.311688]  [<c149befe>] SyS_socketcall+0xe/0x10
[  280.311691]  [<c15c7a7a>] sysenter_do_call+0x12/0x12
[  280.311692] ---[ end trace a9f5912926cc4e28 ]---
Изменено пользователем amindomao
Поделиться сообщением
Ссылка на сообщение
Поделиться на других сайтах
драйвер то свежий ?
из гита ?
или 1.9.0 ?
Ссылка на сообщение
драйвер то свежий ?
из гита ?
или 1.9.0 ?
Из гита.
Если речь о драйвере igb, то пробовал и последний с сайта интела ( 5.2.9.4 ) и тот, который в комплекте с ядром.
Ссылка на сообщение
я про ipoe драйвер
Я пробовал собирать по ману, то есть просто стянул все:
git clone git://git.code.sf.net/p/accel-ppp/code accel-ppp-code
Ссылка на сообщение
Народ, а подскажите как на отдельном влане в ipoe выключить добавление opt82 в проходящие dhcp запросы?
ну или в принципе это включить.
Ссылка на сообщение
adeep - никак, все включено из каропки (если в пакете уже есть опт82 - она и останется, если нет - добавит аксель свою), чтобы выключить - нужно править код.
Ссылка на сообщение
в принципе включается/выключается опцией
[ipoe]
agent-remote-id=
но это глобально, по-интерфейсно нету
Ссылка на сообщение
Обнаружилась проблема(((
accel версии 1.9.0
опцию 82 разбирает луа скрипт
-- STR
function userStr(pkt)
    v,vlan=string.unpack(string.sub(pkt:agent_circuit_id(),'3'),'>H')
    v,port=string.unpack(string.sub(pkt:agent_circuit_id(),'-1'),'b')
    local userStr='str.'..vlan..'-'..port
--    print(username)
    return userStr
end
в конфиге:
interface=re:eth2\.21[5-7][0-9],mode=L2,shared=1,start=dhcpv4,proxy-arp=0,username=lua:userStr
После достижения более 400 сессий, если в запросе не прилетает опция 82, аццель перестает принимать новые соединения, вообще с любых вланов.
В логе:
[2015-04-17 23:59:02]: error: eth2.2156: ipoe: lua: /etc/accel-ppp.lua:52: bad argument #1 to 'sub' (string expected, got nil)
[2015-04-17 23:59:02]:  info: eth2.2156: ipoe: session finished
[2015-04-17 23:59:02]:  info: eth2.2003: ipoe: session finished
Ссылка на сообщение
[100%] Generating driver/ipoe.ko
/opt/accel-ppp-code/build/drivers/ipoe/driver/ipoe.c: In function 'ipoe_stats64':
/opt/accel-ppp-code/build/drivers/ipoe/driver/ipoe.c:1075:4: error: implicit declaration of function 'u64_stats_fetch_begin_irq' [-Werror=implicit-function-declaration]
start = u64_stats_fetch_begin_bh(&st->sync);
/opt/accel-ppp-code/build/drivers/ipoe/driver/ipoe.c:1078:3: error: implicit declaration of function 'u64_stats_fetch_retry_irq' [-Werror=implicit-function-declaration]
} while (u64_stats_fetch_retry_bh(&st->sync, start));
cc1: some warnings being treated as errors
исправил
Ссылка на сообщение
исправил commit 1c0a0c67d1b3331a638fd73317d7e1b8c4ab34bc
Ссылка на сообщение
думаю исправил commit 93f23fa747c40f2f7fc0d305d340d8d6a67d25f2
Ссылка на сообщение
Вопрос для xeb - а возможно ли сделать в секции IPOE еще одну опцию , не важно как ее обозвать.. суть в том чтобы при выдаче ИП через радиус , когда посылается Disconnect-request - не сбрасывалась сессия у accel-pppd , а ожидала прихода ДХЦП запроса RENEW\REBIND и посылала ему DHCP-NAK.
http://accel-ppp.org/forum/viewtopic.php?f=4&t=476&p=1517#p1517
Ссылка на сообщение
Без результата :(
Ссылка на сообщение
[ipoe]
agent-remote-id=
При этом он не будет затирать ту опцию что идет в пакете?
Ссылка на сообщение
Без результата :(
а если так commit 25da2e7fe4d11f909bc738bee31a14de26bfc21c
опцию в пакете он не затирает в любом случае
Ссылка на сообщение
amindomao (Сегодня, 00:09) писал:
Без результата :(
Strike!
Ссылка на сообщение
l3-connected схема с dhcp не реализована
Cхема L3-connected с DHCP так и не реализуема? (т. е. аналог RedBack Dynamic CLIPS через L3 сеть).
Ссылка на сообщение
не знаю что такое RedBack Dynamic CLIPS через L3 сеть
но l3-connected схема с dhcp уже реализована
Ссылка на сообщение
Т.е. dhcp прилетающий через релей теперь корректно отрабатывается?
Ссылка на сообщение
должно быть так, если я чего-то не сломал
т.к. этот режим менее востребован, то и протестирован он менее всего
Ссылка на сообщение
Подскажите, на на стоковом ядре CentOS accel все так же не собирается (проблема появилась на 6.5, если мне память не изменяет) или уже пофоксили?
Ссылка на сообщение
# uname -a
Linux 3.10.0-229.1.2.el7.x86_64
Не с первого раза, конечно, но собирается :)
Ссылка на сообщение
Создайте аккаунт или войдите в него для комментирования
Создать аккаунт
Зарегистрируйтесь для получения аккаунта. Это просто!
Зарегистрировать аккаунт
Уже зарегистрированы? Войдите здесь.
Войти сейчас
