Ivan Rostovikov Posted October 9, 2008 Posted October 9, 2008 Сумма по столбцу не дает 65. Как выяснить причину ? #show processes cpu CPU utilization for five seconds: 65%/57%; one minute: 66%; five minutes: 68% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 1 1656 1935 855 0.00% 0.00% 0.00% 0 Chunk Manager 2 44588 66217 673 0.08% 0.09% 0.08% 0 Load Meter 3 24208 4487 5395 0.00% 0.07% 0.35% 514 SSH Process 4 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN 5 1208624 66431 18193 0.49% 0.18% 0.17% 0 Check heaps 6 452 370 1221 0.00% 0.00% 0.00% 0 Pool Manager 7 0 2 0 0.00% 0.00% 0.00% 0 Timers 9 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler 10 0 1 0 0.00% 0.00% 0.00% 0 Crash writer 11 5544 11034 502 0.00% 0.00% 0.00% 0 Environmental mo 12 17052 57326 297 0.00% 0.00% 0.00% 0 ARP Input 13 58464 345743 169 0.00% 0.00% 0.00% 0 ARP Background 14 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer 15 0 2 0 0.00% 0.00% 0.00% 0 AAA high-capacit 16 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT 17 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager 18 0 3 0 0.00% 0.00% 0.00% 0 DDR Timers 19 4 2 2000 0.00% 0.00% 0.00% 0 Entity MIB API 20 8 29 275 0.00% 0.00% 0.00% 0 EEM ED Syslog 21 2892 77295 37 0.00% 0.00% 0.00% 0 HC Counter Timer 22 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun 23 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers 24 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa 25 0 2 0 0.00% 0.00% 0.00% 0 SMART 26 1128 331102 3 0.00% 0.00% 0.00% 0 GraphIt 27 0 2 0 0.00% 0.00% 0.00% 0 Dialer event 28 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect 29 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client 31 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest 32 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd 33 17076 133174 128 0.00% 0.01% 0.00% 0 Net Background 34 4 3 1333 0.00% 0.00% 0.00% 0 IDB Work 35 0 24 0 0.00% 0.00% 0.00% 0 Logger 36 2000 330918 6 0.00% 0.00% 0.00% 0 TTY Background 37 119592 331115 361 0.08% 0.10% 0.08% 0 Per-Second Jobs 38 200 22068 9 0.00% 0.00% 0.00% 0 c2800 Periodic 39 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process 40 0 1 0 0.00% 0.00% 0.00% 0 Token Daemon 41 0 1 0 0.00% 0.00% 0.00% 0 dev_device_inser 42 0 1 0 0.00% 0.00% 0.00% 0 dev_device_remov 43 0 1 0 0.00% 0.00% 0.00% 0 sal_dpc_process 44 0 1 0 0.00% 0.00% 0.00% 0 ARL Table Manage 45 0 2 0 0.00% 0.00% 0.00% 0 ESWPPM 46 0 2 0 0.00% 0.00% 0.00% 0 Eswilp Storm Con 47 0 2 0 0.00% 0.00% 0.00% 0 ESWILPPM 48 0 2 0 0.00% 0.00% 0.00% 0 Eswilp Storm Con 49 4364 1324378 3 0.00% 0.00% 0.00% 0 Netclock Backgro 50 0 2 0 0.00% 0.00% 0.00% 0 SM Monitor 51 0 2 0 0.00% 0.00% 0.00% 0 Bryce I2C CMD Qu 52 248 4 62000 0.00% 0.00% 0.00% 0 USB Startup 53 432 55168 7 0.00% 0.00% 0.00% 0 mxt5100 54 4 2 2000 0.00% 0.00% 0.00% 0 VNM DSPRM MAIN 55 0 1 0 0.00% 0.00% 0.00% 0 DSPFARM DSP READ 56 248 58 4275 0.00% 0.00% 0.00% 0 FLEX DNLD MAIN 57 0 1 0 0.00% 0.00% 0.00% 0 HDV background 58 756 330929 2 0.00% 0.00% 0.00% 0 Ether-Switch RBC 59 0 1 0 0.00% 0.00% 0.00% 0 IGMP Snooping Pr 60 0 1 0 0.00% 0.00% 0.00% 0 IGMP Snooping Re 61 4 2 2000 0.00% 0.00% 0.00% 0 Call Management 62 0 1 0 0.00% 0.00% 0.00% 0 AAL2CPS TIMER_CU 63 0 1 0 0.00% 0.00% 0.00% 0 CES Line Conditi 64 0 4 0 0.00% 0.00% 0.00% 0 HWIC FE Link Mon 65 6332 1324379 4 0.00% 0.01% 0.00% 0 e1t1 Framer back 66 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces 67 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework 68 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework 69 0 2 0 0.00% 0.00% 0.00% 0 DTP Protocol 70 844 330938 2 0.00% 0.00% 0.00% 0 PI MATM Aging Pr 71 224 33102 6 0.00% 0.00% 0.00% 0 EtherChnl 72 0 2 0 0.00% 0.00% 0.00% 0 Ethernet CFM 73 908 323274 2 0.00% 0.00% 0.00% 0 Ethernet Timer C 74 1060 330947 3 0.00% 0.00% 0.00% 0 linktest 75 0 2 0 0.00% 0.00% 0.00% 0 Dot11 Mgmt & Ass 76 0 2 0 0.00% 0.00% 0.00% 0 Dot11 aaa proces 77 180 5518 32 0.00% 0.00% 0.00% 0 pmkid 78 0 2 0 0.00% 0.00% 0.00% 0 Dot11 auth Dot1x 79 0 1 0 0.00% 0.00% 0.00% 0 Dot11 Mac Auth 80 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R 81 0 20 0 0.00% 0.00% 0.00% 0 AAA Server 82 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc 83 29012 10276876 2 0.08% 0.08% 0.08% 0 ACCT Periodic Pr 84 4080 38627 105 0.00% 0.00% 0.00% 0 CDP Protocol 85 0 2 0 0.00% 0.00% 0.00% 0 Ethernet OAM Pro 86 1480 2899 510 0.00% 0.00% 0.00% 0 IP ARP Adjacency 87 28796 10276887 2 0.08% 0.09% 0.08% 0 IP ARP Retry Age 88 10815400 12614569 857 4.07% 5.34% 5.95% 0 IP Input 89 164 5521 29 0.00% 0.00% 0.00% 0 ICMP event handl 90 0 9 0 0.00% 0.00% 0.00% 0 TurboACL 91 0 2 0 0.00% 0.00% 0.00% 0 TurboACL chunk 92 8 554 14 0.00% 0.00% 0.00% 0 MOP Protocols 93 0 3 0 0.00% 0.00% 0.00% 0 PPP Hooks 95 0 1 0 0.00% 0.00% 0.00% 0 SSS Manager 96 728 44137 16 0.00% 0.00% 0.00% 0 SSS Test Client 97 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana 98 5816 1293461 4 0.00% 0.01% 0.00% 0 SSS Feature Time 99 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana 100 0 14 0 0.00% 0.00% 0.00% 0 SSM connection m 101 0 1 0 0.00% 0.00% 0.00% 0 AC Switch 102 0 2 0 0.00% 0.00% 0.00% 0 Ethernet LMI 103 44792 43266 1035 0.00% 0.00% 0.00% 0 IP Background 104 6340 13742 461 0.00% 0.00% 0.00% 0 IP RIB Update 105 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route 106 0 2 0 0.00% 0.00% 0.00% 0 PPP IPCP 107 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 108 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 109 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant 110 0 1 0 0.00% 0.00% 0.00% 0 Asy FS Helper 111 1692 330875 5 0.00% 0.00% 0.00% 0 Socket Timers 112 2172 32169 67 0.00% 0.00% 0.00% 0 TCP Timer 113 24 12 2000 0.00% 0.00% 0.00% 0 TCP Protocols 114 0 1 0 0.00% 0.00% 0.00% 0 COPS 115 2405844 495163 4858 0.08% 0.01% 0.04% 0 CEF process 116 0 2 0 0.00% 0.00% 0.00% 0 L2MM 117 0 1 0 0.00% 0.00% 0.00% 0 MRD 118 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN 119 0 1 0 0.00% 0.00% 0.00% 0 L2X Data Daemon 120 14024 661766 21 0.00% 0.02% 0.00% 0 DHCPD Receive 121 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute 122 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_state_eve 123 0 2 0 0.00% 0.00% 0.00% 0 RLM groups Proce 124 0 2 0 0.00% 0.00% 0.00% 0 SNMP Timers 125 0 2 0 0.00% 0.00% 0.00% 0 SCTP Main Proces 126 0 1 0 0.00% 0.00% 0.00% 0 IUA Main Process 127 2016 330956 6 0.08% 0.00% 0.00% 0 RUDPV1 Main Proc 128 0 1 0 0.00% 0.00% 0.00% 0 bsm_timers 129 816 330965 2 0.00% 0.00% 0.00% 0 bsm_xmt_proc 130 0 1 0 0.00% 0.00% 0.00% 0 CES Client SVC R 131 0 2 0 0.00% 0.00% 0.00% 0 Dialer Forwarder 132 4468 5519 809 0.00% 0.00% 0.00% 0 IP Cache Ager 133 102160 5519 18510 0.00% 0.00% 0.00% 0 Adj Manager 134 0 3 0 0.00% 0.00% 0.00% 0 Flow Exporter Ti 135 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input 136 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER 137 4 1105 3 0.00% 0.00% 0.00% 0 HTTP CORE 138 0 1 0 0.00% 0.00% 0.00% 0 RARP Input 139 0 13 0 0.00% 0.00% 0.00% 0 Transport Port A 140 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall 141 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background 142 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind 143 0 2 0 0.00% 0.00% 0.00% 0 PPP SSS 144 0 1 0 0.00% 0.00% 0.00% 0 MQC Flow Event B 145 18824 3300479 5 0.00% 0.04% 0.05% 0 RBSCP Background 146 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage 147 44 13248 3 0.00% 0.00% 0.00% 0 CRM_CALL_UPDATE_ 148 112 2 56000 0.00% 0.00% 0.00% 0 CCVPM_HDSPRM 149 6724 184298 36 0.00% 0.00% 0.00% 0 FLEX DSPRM MAIN 150 924 122544 7 0.08% 0.00% 0.00% 0 FLEX DSP KEEPALI 151 0 4 0 0.00% 0.00% 0.00% 0 HDA DSPRM MAIN 153 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve 154 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA 155 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr 156 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke 157 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA 158 100 587 170 0.00% 0.00% 0.00% 0 LOCAL AAA 159 0 2 0 0.00% 0.00% 0.00% 0 TPLUS 160 0 2 0 0.00% 0.00% 0.00% 0 VSP_MGR 161 0 3 0 0.00% 0.00% 0.00% 0 Crypto WUI 162 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_HTSP 163 0 2 0 0.00% 0.00% 0.00% 0 VPM_MWI_BACKGROU 164 0 1 0 0.00% 0.00% 0.00% 0 CCVPM_R2 165 0 1 0 0.00% 0.00% 0.00% 0 EPHONE MWI Refre 166 0 368 0 0.00% 0.00% 0.00% 0 FB/KS Log HouseK 167 0 2 0 0.00% 0.00% 0.00% 0 EPHONE MWI BG Pr 168 0 1 0 0.00% 0.00% 0.00% 0 Skinny HW confer 169 772 11037 69 0.00% 0.00% 0.00% 0 VOICE REG BG Pro 170 0 1 0 0.00% 0.00% 0.00% 0 Presence Process 171 0 1 0 0.00% 0.00% 0.00% 0 CCSWVOICE 173 0 1 0 0.00% 0.00% 0.00% 0 http client proc 175 4 1 4000 0.00% 0.00% 0.00% 0 QOS_MODULE_MAIN 176 0 1 0 0.00% 0.00% 0.00% 0 RPMS_PROC_MAIN 177 0 1 0 0.00% 0.00% 0.00% 0 VoIP AAA 178 44 8 5500 0.00% 0.00% 0.00% 0 crypto engine pr 179 0 4 0 0.00% 0.00% 0.00% 0 Crypto CA 180 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL 181 0 1 0 0.00% 0.00% 0.00% 0 Crypto SSL 182 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc 183 0 1 0 0.00% 0.00% 0.00% 0 PM Callback 184 6016 1655749 3 0.00% 0.01% 0.00% 0 Atheros LED Ctro 185 0 2 0 0.00% 0.00% 0.00% 0 Control-plane ho 186 0 1 0 0.00% 0.00% 0.00% 0 DATA Transfer Pr 187 0 1 0 0.00% 0.00% 0.00% 0 DATA Collector 188 0 2 0 0.00% 0.00% 0.00% 0 AAA SEND STOP EV 189 4 2 2000 0.00% 0.00% 0.00% 0 EEM ED Resource 190 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Track 191 296 33108 8 0.00% 0.00% 0.00% 0 RMON Recycle Pro 192 0 2 0 0.00% 0.00% 0.00% 0 RMON Deferred Se 193 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps 194 4 2 2000 0.00% 0.00% 0.00% 0 VLAN Manager 195 12 2760 4 0.00% 0.00% 0.00% 0 DHCPD Timer 196 1576 330894 4 0.00% 0.00% 0.00% 0 trunk conditioni 197 0 1 0 0.00% 0.00% 0.00% 0 trunk conditioni 198 4 18 222 0.00% 0.00% 0.00% 0 EEM Server 199 0 2 0 0.00% 0.00% 0.00% 0 EEM ED CLI 200 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Counter 201 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Interface 202 4 2 2000 0.00% 0.00% 0.00% 0 EEM ED IOSWD 203 0 2 0 0.00% 0.00% 0.00% 0 EEM ED None 204 0 2 0 0.00% 0.00% 0.00% 0 EEM ED OIR 205 4 2 2000 0.00% 0.00% 0.00% 0 EEM ED SNMP 206 40 5536 7 0.00% 0.00% 0.00% 0 EEM ED Timer 207 4 2 2000 0.00% 0.00% 0.00% 0 EEM Policy Direc 208 16 15 1066 0.00% 0.00% 0.00% 0 Syslog 209 0 1 0 0.00% 0.00% 0.00% 0 VPDN Test 210 364 13650 26 0.00% 0.00% 0.00% 0 IP SLA MPLSLM Pr 211 0 2 0 0.00% 0.00% 0.00% 0 Net Input 212 1516 66240 22 0.00% 0.00% 0.00% 0 Compute load avg 213 178052 5587 31868 0.00% 0.01% 0.00% 0 Per-minute Jobs 214 0 1 0 0.00% 0.00% 0.00% 0 tHUB 215 524 11483 45 0.00% 0.00% 0.00% 0 CEF Scanner 216 142996 10005 14292 0.00% 0.00% 0.00% 0 crypto sw pk pro 218 24 185 129 0.00% 0.00% 0.00% 0 SSH Event handle 219 2000 66214 30 0.00% 0.00% 0.00% 0 Track 220 71196 10325046 6 0.16% 0.19% 0.18% 0 PPP manager 221 44440 10325049 4 0.08% 0.10% 0.08% 0 PPP Events 222 1056 331102 3 0.00% 0.00% 0.00% 0 Multilink PPP 223 2101912 1012224 2076 0.81% 0.76% 0.78% 0 IP NAT Ager 224 0 1 0 0.00% 0.00% 0.00% 0 IP NAT WLAN 225 9316 163253 57 0.00% 0.00% 0.00% 0 IP VFR proc 227 0 1 0 0.00% 0.00% 0.00% 0 TCP Listener 228 1000 11051 90 0.00% 0.00% 0.00% 0 IP SLAs Event Pr 229 8576 17668 485 0.00% 0.00% 0.00% 0 IP SNMP 230 1700 8834 192 0.00% 0.00% 0.00% 0 PDU DISPATCHER 231 8108 8834 917 0.00% 0.00% 0.00% 0 SNMP ENGINE 232 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6 233 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro 234 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps 235 2435716 26973462 90 0.57% 0.49% 0.49% 0 NAT MIB Helper 236 2792 333169 8 0.00% 0.00% 0.00% 0 NTP 238 256 5523 46 0.00% 0.00% 0.00% 0 DHCPD Database 239 8 4 2000 0.00% 0.00% 0.00% 0 RIP Router 240 31896 742526 42 0.00% 0.00% 0.00% 0 BGP Router 241 31684 220015 144 0.08% 0.02% 0.00% 0 RIP Send 242 20740 406585 51 0.08% 0.04% 0.05% 0 RIP Timers 243 12728 32470 391 0.00% 0.00% 0.00% 0 BGP I/O 244 319704 22062 14491 0.00% 0.04% 0.05% 0 BGP Scanner 245 0 1 0 0.00% 0.00% 0.00% 0 BGP Event Вставить ник Quote
UglyAdmin Posted October 9, 2008 Posted October 9, 2008 CPU utilization for five seconds: 65%/57%;Первая цифра - общая загрузка, сторая - загрузка по прерываниям.Сумма по таблице будет равна их разности... Ответ на вопрос такой: CPU на 57% загружен трафиком, на остальное - разными второстепенными задачами... Вставить ник Quote
Andrei Posted October 9, 2008 Posted October 9, 2008 Первая цифра - общая загрузка, сторая - загрузка по прерываниям.Сумма по таблице будет равна их разности... +1и удобнее смотреть: sh proc cpu s наиболее прожорливые процессы будут вверху таблицы. Вставить ник Quote
