Сегодня повис один из IP интерфейсов на сабже. После ребута все поднялось , просто интересно у кого еще такое бывало?
После того как полез смотреть заметил следующую штуку:
show cam ip 1/3 60.49.0.0/16
Slot Index      IP_Address            MAC        Age    VLAN    Out Port
Warning: Shadow CAM data Entry (0x00004cc9: 63efffff 00000000 (tag 1)) is found at index 0x000027c9!
Warning: Shadow CAM data Entry (0x00004cc8: 4d34ffff 00000000 (tag 1)) is found at index 0x000027e4!
Warning: Shadow CAM data Entry (0x00004ca8: 3c31ffff 00000000 (tag 1)) is found at index 0x00003c56!
  1     35        60.49.0.0/16  001e.4a44.7040     2     422   ether 1/3
Warning: Shadow CAM data Entry (0x00004ca6: de7dffff 00000000 (tag 1)) is found at index 0x00003992!
Warning: Shadow CAM data Entry (0x00004c9c: 3c33ffff 00000000 (tag 1)) is found at index 0x00003a76!
Warning: Shadow CAM data Entry (0x00004c89: d9a4ffff 00000000 (tag 1)) is found at index 0x000038be!
Warning: Shadow CAM data Entry (0x00004c72: 4cafffff 00000000 (tag 1)) is found at index 0x00003c7b!
Warning: Shadow CAM data Entry (0x00003cad: 7c52ffff 00000000 (tag 1)) is found at index 0x0000228c!
Warning: Shadow CAM data Entry (0x00003c8f: c868efff 00000000 (tag 1)) is found at index 0x00000b26!
...............skip...........
На 1/3 висит 1 ve интерфейс (vl 422) , его видно тут , просто очень интересно что за "Shadow CAM data" с Warning'ами который не радует както.. :(
Железо/софт такое:
  SW: Version 08.0.01fT53 Copyright (c) 1996-2004 Foundry Networks, Inc.
      Compiled on Sep 01 2006 at 13:12:59 labeled as B2R08001f
      (3826271 bytes) from Primary B2R08001f.bin
  HW: BigIron 4000 Router, SYSIF version 21, Serial #: Non-exist
SL 1: J-BxGMR4 JetCore Management Module, SYSIF 2 (Mini GBIC), M4, ACTIVE
      Serial #:   CH17030905
4096 KB BRAM, JetCore ASIC IGC version 49, BIA version 89
32768 KB PRAM and 2M-Bit*1 CAM for IGC  0, version 0449
32768 KB PRAM and 2M-Bit*1 CAM for IGC  1, version 0449
Active management module:
  466 MHz Power PC processor 750 (version 8/8302) 66 MHz bus
  512 KB boot flash memory
16384 KB code flash memory
  256 KB SRAM
  512 MB DRAM
The system uptime is 12 hours 40 minutes 9 seconds
The system : started=warm start   reloaded=by "reload"
