inxs Posted September 4, 2008 Posted September 4, 2008 (edited) 2.6.23.14, q6600, 4G, 2x E1000 в транке, quagga, nat. Периодически вечерами ksoftirqd съедает полностью два ядра, при этом сам сервер начинает подтормаживать и задержка вырастает до 8-10мс. От количества пакетов практически не зависит, т.е. такая ерунда может начаться и при 95к и при 105к. Видимо кто-то флудит. netstat -s Ip: 16002647 total packets received 101635611 with invalid headers 4034600619 forwarded 38662 with unknown protocol 0 incoming packets discarded 74087958 incoming packets delivered 544071112 requests sent out 335 dropped because of missing route 6612377 fragments dropped after timeout 1376315865 reassemblies required 111618970 packets reassembled ok !! 1079311284 packet reassembles failed 49453240 fragments received ok 151210801 fragments created Icmp: 5995677 ICMP messages received 3010449 input ICMP message failed. ICMP input histogram: destination unreachable: 126198 timeout in transit: 966993 wrong parameters: 11 source quenches: 38 echo requests: 1899805 echo replies: 10669 timestamp request: 5 timestamp reply: 7 address mask request: 3 address mask replies: 47 3207479363 ICMP messages sent 0 ICMP messages failed ICMP output histogram: time exceeded: 101631372 echo replies: 1899805 timestamp replies: 5 Tcp: 1024711 active connections openings 1142609 passive connection openings 756598 failed connection attempts 94188 connection resets received 16 connections established 65877418 segments received 60260680 segments send out 73322 segments retransmited 877 bad segments received. 450374 resets sent Udp: 1695763 packets received 481918 packets to unknown port received. 4 packet receive errors 1697547 packets sent UdpLite: TcpExt: 744 resets received for embryonic SYN_RECV sockets 1176 packets pruned from receive queue because of socket buffer overrun 27 ICMP packets dropped because they were out-of-window 9 ICMP packets dropped because socket was locked 71441 TCP sockets finished time wait in fast timer 211 time wait sockets recycled by time stamp 199 packets rejects in established connections because of timestamp 2422014 delayed acks sent 642 delayed acks further delayed because of locked socket Quick ack mode was activated 45027 times 9219988 packets directly queued to recvmsg prequeue. 223822056 of bytes directly received from backlog 1669071583 of bytes directly received from prequeue 31217598 packet headers predicted 10223256 packets header predicted and directly queued to user 6400145 acknowledgments not containing data received 8152998 predicted acknowledgments 271 times recovered from packet loss due to SACK data Detected reordering 1 times using time stamp 16 congestion windows partially recovered using Hoe heuristic TCPDSACKUndo: 10 8668 congestion windows recovered after partial ack 2393 TCP data loss events 326 timeouts after reno fast retransmit 422 timeouts after SACK recovery 877 timeouts in loss state 4423 fast retransmits 32 forward retransmits 83 retransmits in slow start 52317 other TCP timeouts 11 sack retransmits failed 1 times receiver scheduled too late for direct processing 111297 packets collapsed in receive queue due to low socket buffer 31149 DSACKs sent for old packets 3620 DSACKs sent for out of order packets 13098 DSACKs received 65705 connections reset due to unexpected data 91929 connections reset due to early user close 458 connections aborted due to timeout IpExt: InTruncatedPkts: 69580 InMcastPkts: 38661 InBcastPkts: 120676 ethtool -S eth0 NIC statistics: rx_packets: 818691546870 tx_packets: 817733606761 rx_bytes: 562829984869843 tx_bytes: 562252162029210 rx_broadcast: 132861752 tx_broadcast: 4885056 rx_multicast: 12639724 tx_multicast: 14603368 rx_errors: 4 tx_errors: 0 tx_dropped: 0 multicast: 12639724 collisions: 0 rx_length_errors: 178 rx_over_errors: 0 rx_crc_errors: 4 rx_frame_errors: 0 !! rx_no_buffer_count: 1265916200 !! rx_missed_errors: 454590997 tx_aborted_errors: 0 tx_carrier_errors: 0 tx_fifo_errors: 0 tx_heartbeat_errors: 0 tx_window_errors: 0 tx_abort_late_coll: 0 tx_deferred_ok: 0 tx_single_coll_ok: 0 tx_multi_coll_ok: 0 tx_timeout_count: 0 !! tx_restart_queue: 6620253 rx_long_length_errors: 178 rx_short_length_errors: 0 rx_align_errors: 0 tx_tcp_seg_good: 0 tx_tcp_seg_failed: 0 rx_flow_control_xon: 0 rx_flow_control_xoff: 0 tx_flow_control_xon: 0 tx_flow_control_xoff: 0 rx_long_byte_count: 562829984869843 rx_csum_offload_good: 814763097746 rx_csum_offload_errors: 659897395 rx_header_split: 0 alloc_rx_buff_failed: 0 tx_smbus: 0 rx_smbus: 0 dropped_smbus: 0 немного смущают выделенные значения. Собственно, какие крутилки стоит покрутить, и сильно ли это поможет? Edited September 4, 2008 by inxs Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 rx_no_buffer_count : ethtool -g eth0 и начинаем плавненько увеличивать ethtool -G eth0 rx NNNN УЧТИТЕ - карта отвалится ненадолго (пока рестартанет negotiation), так что аккуратнее. В транке на сиське при передергивании порта STP долго тоже чухается... Шейперы, iptables, nat на роутере есть? Прерывания сетевух привязаны жестко к процессорам? (smp_affinity) Если можно закиньте куда-нить .config ядра посмотреть. Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 Шейперов нет, nat есть, iptables есть, smp_affinity не трогали. config.txt Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 CONFIG_IRQBALANCE=y - плохо После того как поправите - прерывания лучше раскидать по физическим процессорам. в dmesg пусто? CONFIG_PREEMPT_BKL лучше в n (некритично) CONFIG_SECCOMP в n (немного кушает ресурсов) Включить MSI прерывания CONFIG_NF_CT_ACCT если не нужно - отключить (некритично) Если много роутов - попробуйте CONFIG_IP_FIB_TRIE К вечеру и в нормальное время сделайте sysctl -a|grep conntr Покажете их... если флудят - обычно резко растет net.netfilter.nf_conntrack_count = 202170 Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 Да, в dmesg есть крики про conntrack nf_conntrack: table full, dropping packet Сейчас вот что: net.ipv4.netfilter.ip_conntrack_generic_timeout = 600 net.ipv4.netfilter.ip_conntrack_tcp_timeout_syn_sent = 120 net.ipv4.netfilter.ip_conntrack_tcp_timeout_syn_recv = 60 net.ipv4.netfilter.ip_conntrack_tcp_timeout_established = 432000 net.ipv4.netfilter.ip_conntrack_tcp_timeout_fin_wait = 120 net.ipv4.netfilter.ip_conntrack_tcp_timeout_close_wait = 60 net.ipv4.netfilter.ip_conntrack_tcp_timeout_last_ack = 30 net.ipv4.netfilter.ip_conntrack_tcp_timeout_time_wait = 120 net.ipv4.netfilter.ip_conntrack_tcp_timeout_close = 10 net.ipv4.netfilter.ip_conntrack_tcp_timeout_max_retrans = 300 net.ipv4.netfilter.ip_conntrack_tcp_loose = 1 net.ipv4.netfilter.ip_conntrack_tcp_be_liberal = 0 net.ipv4.netfilter.ip_conntrack_tcp_max_retrans = 3 net.ipv4.netfilter.ip_conntrack_udp_timeout = 30 net.ipv4.netfilter.ip_conntrack_udp_timeout_stream = 180 net.ipv4.netfilter.ip_conntrack_icmp_timeout = 30 net.ipv4.netfilter.ip_conntrack_max = 1548576 net.ipv4.netfilter.ip_conntrack_count = 1533818 net.ipv4.netfilter.ip_conntrack_buckets = 16384 net.ipv4.netfilter.ip_conntrack_checksum = 1 net.ipv4.netfilter.ip_conntrack_log_invalid = 0 net.netfilter.nf_conntrack_generic_timeout = 600 net.netfilter.nf_conntrack_max = 1548576 net.netfilter.nf_conntrack_count = 1533819 net.netfilter.nf_conntrack_buckets = 16384 net.netfilter.nf_conntrack_checksum = 1 net.netfilter.nf_conntrack_log_invalid = 0 net.netfilter.nf_conntrack_expect_max = 256 net.netfilter.nf_conntrack_tcp_timeout_syn_sent = 120 net.netfilter.nf_conntrack_tcp_timeout_syn_recv = 60 net.netfilter.nf_conntrack_tcp_timeout_established = 432000 net.netfilter.nf_conntrack_tcp_timeout_fin_wait = 120 net.netfilter.nf_conntrack_tcp_timeout_close_wait = 60 net.netfilter.nf_conntrack_tcp_timeout_last_ack = 30 net.netfilter.nf_conntrack_tcp_timeout_time_wait = 120 net.netfilter.nf_conntrack_tcp_timeout_close = 10 net.netfilter.nf_conntrack_tcp_timeout_max_retrans = 300 net.netfilter.nf_conntrack_tcp_loose = 1 net.netfilter.nf_conntrack_tcp_be_liberal = 0 net.netfilter.nf_conntrack_tcp_max_retrans = 3 net.netfilter.nf_conntrack_udp_timeout = 30 net.netfilter.nf_conntrack_udp_timeout_stream = 180 net.netfilter.nf_conntrack_icmp_timeout = 30 net.nf_conntrack_max = 1548576 Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 Поставьте утилитку conntrack. Затем conntrack -L >file Доеду до работы - напишу скриптик который отсортирует dst / src пары - если кто-то занимает слишком много значений. Или сами попробуйте наваять. Пока временно можно , если есть свободная память, задрать значение net.netfilter.nf_conntrack_max чуть повыше, но аккуратно. Скажем на 100000 (вообще желательно чтоб это значение было кратно 2^n, т.е. скажем net.netfilter.nf_conntrack_max=2097152). И посмотреть насколько быстро оно растет. Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 # conntrack -L Operation failed: sorry, you must be root or get CAP_NET_ADMIN capability to do this Гугля говорит что-то невнятное по этому поводу. А скриптик-то я и сам написать смогу.. Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 Собрано из сырцов на текущее ядро и текущие iptables (которые в системе) ? Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 ээ.. нет %) anyway, оно в отрытом виде в проке (/toc/net/ip_conntrack) лежит, счас поковыряю.. Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 если смотреть через /proc рискуете положить ваш border Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 (edited) Даже если интеллигентно cat'нуть с минимальным nice'ом? Среди первых же записей есть какие-то чудеса tcp 6 380800 ESTABLISHED src=88.223.20.163 dst=170.128.169.15 sport=443 dport=19741 packets=1 bytes=40 [UNREPLIED] src=170.128.169.15 dst=88.223.20.163 sport=19741 dport=443 packets=0 bytes=0 mark=0 use=1 tcp 6 380761 ESTABLISHED src=166.27.93.156 dst=170.128.169.15 sport=443 dport=41683 packets=1 bytes=40 [UNREPLIED] src=170.128.169.15 dst=166.27.93.156 sport=41683 dport=443 packets=0 bytes=0 mark=0 use=1 tcp 6 380676 ESTABLISHED src=14.25.173.228 dst=170.128.169.15 sport=443 dport=46639 packets=1 bytes=40 [UNREPLIED] src=170.128.169.15 dst=14.25.173.228 sport=46639 dport=443 packets=0 bytes=0 mark=0 use=1 tcp 6 380609 ESTABLISHED src=158.3.123.95 dst=170.128.169.15 sport=443 dport=11530 packets=1 bytes=40 [UNREPLIED] src=170.128.169.15 dst=158.3.123.95 sp ort=11530 dport=443 packets=0 bytes=0 mark=0 use=1 tcp 6 380267 ESTABLISHED src=196.154.124.72 dst=170.128.169.32 sport=80 dport=27217 packets=1 bytes=40 [UNREPLIED] src=170.128.169.32 dst=196.154.124.72 sport=27217 dport=80 packets=0 bytes=0 mark=0 use=1 tcp 6 380205 ESTABLISHED src=156.203.19.22 dst=170.128.169.32 sport=80 dport=52696 packets=1 bytes=40 [UNREPLIED] src=170.128.169.32 dst=156.203.19.22 s port=52696 dport=80 packets=0 bytes=0 mark=0 use=1 Это не мои адреса.. Edited September 4, 2008 by inxs Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 Даже если... там коряво сделан код для вывода в proc. Я ругался по этому поводу уже в kernel maillist, исправлять не хотят. Поставьте фильтры от спуфинга в iptables. Для начала хотя бы с LOG Похоже из вашей сети кто-то делает SYN flood с проспуфленными src адресами на 170.128.169.x. Ловите засранца... Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 Спасибо, будем искать. Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 Опять фигня началась.. :( net.ipv4.netfilter.ip_conntrack_generic_timeout = 600 net.ipv4.netfilter.ip_conntrack_tcp_timeout_syn_sent = 120 net.ipv4.netfilter.ip_conntrack_tcp_timeout_syn_recv = 60 net.ipv4.netfilter.ip_conntrack_tcp_timeout_established = 432000 net.ipv4.netfilter.ip_conntrack_tcp_timeout_fin_wait = 120 net.ipv4.netfilter.ip_conntrack_tcp_timeout_close_wait = 60 net.ipv4.netfilter.ip_conntrack_tcp_timeout_last_ack = 30 net.ipv4.netfilter.ip_conntrack_tcp_timeout_time_wait = 120 net.ipv4.netfilter.ip_conntrack_tcp_timeout_close = 10 net.ipv4.netfilter.ip_conntrack_tcp_timeout_max_retrans = 300 net.ipv4.netfilter.ip_conntrack_tcp_loose = 1 net.ipv4.netfilter.ip_conntrack_tcp_be_liberal = 0 net.ipv4.netfilter.ip_conntrack_tcp_max_retrans = 3 net.ipv4.netfilter.ip_conntrack_udp_timeout = 30 net.ipv4.netfilter.ip_conntrack_udp_timeout_stream = 180 net.ipv4.netfilter.ip_conntrack_icmp_timeout = 30 net.ipv4.netfilter.ip_conntrack_max = 1548576 net.ipv4.netfilter.ip_conntrack_count = 1529804 net.ipv4.netfilter.ip_conntrack_buckets = 16384 net.ipv4.netfilter.ip_conntrack_checksum = 1 net.ipv4.netfilter.ip_conntrack_log_invalid = 0 net.netfilter.nf_conntrack_generic_timeout = 600 net.netfilter.nf_conntrack_max = 1548576 net.netfilter.nf_conntrack_count = 1529805 net.netfilter.nf_conntrack_buckets = 16384 net.netfilter.nf_conntrack_checksum = 1 net.netfilter.nf_conntrack_log_invalid = 0 net.netfilter.nf_conntrack_expect_max = 256 net.netfilter.nf_conntrack_tcp_timeout_syn_sent = 120 net.netfilter.nf_conntrack_tcp_timeout_syn_recv = 60 net.netfilter.nf_conntrack_tcp_timeout_established = 432000 net.netfilter.nf_conntrack_tcp_timeout_fin_wait = 120 net.netfilter.nf_conntrack_tcp_timeout_close_wait = 60 net.netfilter.nf_conntrack_tcp_timeout_last_ack = 30 net.netfilter.nf_conntrack_tcp_timeout_time_wait = 120 net.netfilter.nf_conntrack_tcp_timeout_close = 10 net.netfilter.nf_conntrack_tcp_timeout_max_retrans = 300 net.netfilter.nf_conntrack_tcp_loose = 1 net.netfilter.nf_conntrack_tcp_be_liberal = 0 net.netfilter.nf_conntrack_tcp_max_retrans = 3 net.netfilter.nf_conntrack_udp_timeout = 30 net.netfilter.nf_conntrack_udp_timeout_stream = 180 net.netfilter.nf_conntrack_icmp_timeout = 30 net.nf_conntrack_max = 1548576 rp_filter на доступе, кстати, не помог. Видимо, придётся ещё костылей навешивать. Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 В iptables повесить правила на те ip которые не ваши и отследить откуда идет. Если не очень много адресов, то лучше их описать, а все что не должно приходить - в -j LOG и теребить источник. Вставить ник Quote
inxs Posted September 4, 2008 Author Posted September 4, 2008 А стоит ли трогать вот это: net.ipv4.tcp_mem = 390144 520192 780288 net.ipv4.tcp_wmem = 4096 16384 4194304 net.ipv4.tcp_rmem = 4096 87380 4194304 ? Вставить ник Quote
nuclearcat Posted September 4, 2008 Posted September 4, 2008 Нет, абсолютно не поможет, если conntrack dropping packet. Временно ситуацию можно решить заблокировав ip который боты атакуют, и добавив еще атакуемые ip в raw таблицу т.е. например по инфе приведенной выше типа такого iptables -t raw -I PREROUTING -d 170.128.169.0/24 -j NOTRACK Тогда эта фигня не будет попадать в conntrack и переполнять его. Вставить ник Quote
inxs Posted September 5, 2008 Author Posted September 5, 2008 Поблокировали на доступе гадость, но в таблице conntrack по прежнему полно левых записей. Видимо, придётся ждать пока они стаймаутятся.. Вставить ник Quote
nuclearcat Posted September 5, 2008 Posted September 5, 2008 conntrack -F сбросит все записи или можно -D -s ip напимер удалить все записи по определенному ip-шнику советую все-таки заставить работать эту утилиту Вставить ник Quote
martin74 Posted September 5, 2008 Posted September 5, 2008 а кстати, чем чревато использование NOTRACK ? я так у себя на выходящем роутере маскарадный диапазон и диапазон раздаваемых реалок сделал - NOTRACK. До поры до времени помогало от conntrack dropping packet.. Пару дней назад опять началось. Задрал по примеру из поста - посмотрим, что будет... Вставить ник Quote
nuclearcat Posted September 5, 2008 Posted September 5, 2008 Ничем, только что если в правилах ошибешься и попадет в NOTRACK пакет предназначенный нату - просто дропнется. Ну и правил нежелательно много толкать. Еще кстати если траффика много и юзаете шейперы и прочие потребители таймеров - КРАЙНЕ желательно наличие TSC как таймера. Проверять тут /sys/devices/system/clocksource/clocksource0/current_clocksource Вставить ник Quote
inxs Posted September 5, 2008 Author Posted September 5, 2008 советую все-таки заставить работать эту утилиту Подожду, пожалуй, до понедельника. Делать что-то с критичными сервисами в пятницу - плохая примета.. ;) Вставить ник Quote
inxs Posted September 9, 2008 Author Posted September 9, 2008 Conntrack почистили, но ерунда с загрузкой процессора продолжается. Можно ли сделать что-нибудь ещё без пересборки ядра и перезагрузки? Вставить ник Quote
nuclearcat Posted September 9, 2008 Posted September 9, 2008 вы нашли того кто флудит? если он флудит проспуфленными ip - в этом хорошего мало более детально искать нужно через oprofile, что именно жрет процессор... Вставить ник Quote
inxs Posted September 9, 2008 Author Posted September 9, 2008 Флудило несколько человек (и, видимо, продолжают это делать), но на аксессе понавешено костылей и спуфленные пакеты до бордера не долетают. А, собственно, бордер не загнётся от подсовывания ему профайлера под нагрузкой? Вставить ник Quote
