Guest alexsys
Dlink 3226 управляемы свич 2-го уровня
Кол-во портов:
- 24 порта 10/100BASE-TX
- 2 гигабитных комбо miniGBIC порта SFP/медь
Specifications:
MAC Address Table Size: 4K
Switch Fabric: 8.8Gbps Capacity
Transmission Method: Store-and-forward
VLANs Support: Up To 255 VLAN Groups
Hardware Based Priority: Queues 2 Queues
Packet Buffer Memory: 3Mbits
Multicast Support: IGMP Snooping
Interface Options:
- RJ-45 10BASE-T
- RJ-45 100BASE-TX
- RJ-45 1000BASE-T
Network Management:
- Telnet
- CLI/Console
- RMON
- Web-based HTTP
- SNMPv1/v3 Compatible
- Port Mirroring
Protocols:
- IEEE 802.3 Ethernet
- IEEE 802.3u Fast Ethernet
- IEEE 802.1d Spanning Tree
- IEEE 802.1w Rapid Spanning Tree
- IEEE 802.1p Priority Tags
- IEEE 802.1ad Link Aggregation Control
- IEEE 802.3x Flow Control
- IEEE 802.1x Port Based Network Access Control
- RFC 1157 SNMP
- RFC 1112/2236 IGMPv1/2
- RFC 1757 RMON (4 Groups)
- RFC 1493 Bridge MIB
- RFC 1213 MIB II
- RFC 793 TCP
- RFC 826 ARP
- RFC 854 Telnet
Emissions:
- CE Mark
- FCC Class A
- BSMI
- VCCI Class I
- C-Tick
Power Supply:
- 100-240VAC
- 50/60 Hz Internal Universal Power
Certifications: Safety CSA International
Dimensions:
- Length: 17.36 in. (44.1 cm)
- Width: 15.28 in. (38.8 cm)
- Height: 2.6 in. (6.6 cm)
- Rack-mount Width: 19-inch
- Unit Height: 1U
Operating Temperature: 0°C~40°C (32°F~104°F)
Storage Temperature: -25°C~55°C (-13°F~131°F)
Operating Humidity: 5% to 95% RH, Non-Condensing
Примечание: Шнур питания с амереканским разъемом т.е. надо будет заменить вилку.
Город СПб.
Цена 3000р.
Возможна доставка в другие регионы при условии доп. оплаты доставки.
  • 4 weeks later...
