raveren Posted August 20, 2008 Posted August 20, 2008 Здравствуйте! Возникла задача сделать маршрутизацию в зависимости от источника. С route-map'ами проблем не возникло, а вот на применении ip policy route-map Test к vlаn возникла. Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1) Copyright (c) 1986-2007 by Cisco Systems, Inc. Compiled Thu 19-Jul-07 18:15 by nachen trampampam(config)#interface vlan 2 trampampam(config-if)#? Interface configuration commands: arp Set arp type (arpa, probe, snap) or timeout bandwidth Set bandwidth informational parameter bgp-policy Apply policy propogated by bgp community string carrier-delay Specify delay for interface transitions cdp CDP interface subcommands dampening Enable event dampening default Set a command to its defaults delay Specify interface throughput delay description Interface specific description eou EAPoUDP Interface Configuration Commands ethernet Ethernet interface parameters exit Exit from interface configuration mode help Description of the interactive help system hold-queue Set hold queue depth ip Interface Internet Protocol config commands link Configure Link load-interval Specify interval for load calculation for an interface logging Configure logging for interface loopback Configure internal loopback on an interface macro Command macro max-reserved-bandwidth Maximum Reservable Bandwidth on an Interface no Negate a command or set its defaults ntp Configure NTP private-vlan Configure private VLAN SVI interface settings rate-limit Rate Limit service-policy Configure QoS Service Policy shutdown Shutdown the selected interface snmp Modify SNMP interface parameters source Get config from another source spanning-tree Spanning Tree Subsystem standby HSRP interface configuration commands timeout Define timeout values for this interface Я так понимаю, что моя IOS не поддерживает PBR? Вставить ник Quote
catalist Posted August 20, 2008 Posted August 20, 2008 оно внутри ip+1 делаешь ip policy route-map NAME_ROUTE_MAP Вставить ник Quote
raveren Posted August 20, 2008 Author Posted August 20, 2008 оно внутри ip Извиняюсь, не то сначала показал. trampampam(config)#interface vlan 2 trampampam(config-if)#ip ? Interface IP configuration subcommands: access-group Specify access control for packets accounting Enable IP accounting on this interface address Set the IP address of an interface admission Apply Network Admission Control authentication authentication subcommands bandwidth-percent Set EIGRP bandwidth limit broadcast-address Set the broadcast address of an interface cef Cisco Express Forwarding interface commands dhcp Configure DHCP parameters for this interface directed-broadcast Enable forwarding of directed broadcasts hello-interval Configures IP-EIGRP hello interval helper-address Specify a destination address for UDP broadcasts hold-time Configures IP-EIGRP hold time information-reply Enable sending ICMP Information Reply messages irdp ICMP Router Discovery Protocol load-sharing Style of load sharing local-proxy-arp Enable local-proxy ARP mask-reply Enable sending ICMP Mask Reply messages next-hop-self Configures IP-EIGRP next-hop-self probe Enable HP Probe support proxy-arp Enable proxy ARP rarp-server Enable RARP server for static arp entries redirects Enable sending ICMP Redirect messages rip Router Information Protocol route-cache Enable fast-switching cache for outgoing packets security DDN IP Security Option split-horizon Perform split horizon summary-address Perform address summarization unnumbered Enable IP processing without an explicit address unreachables Enable sending ICMP Unreachable messages vrf VPN Routing/Forwarding parameters on the interface Вставить ник Quote
ingress Posted August 20, 2008 Posted August 20, 2008 (edited) PBR доступен в ipservices и sdm нужен, отличный от default(допустим routing) для 3560 прошивки можно взять бесплатно, зарегаться только надо на cisco.com Edited August 20, 2008 by ingress Вставить ник Quote
raveren Posted August 21, 2008 Author Posted August 21, 2008 PBR доступен в ipservicesи sdm нужен, отличный от default(допустим routing) для 3560 прошивки можно взять бесплатно, зарегаться только надо на cisco.com Все, разобрался. Спасибо! Вставить ник Quote
