yKpon Posted August 20, 2008 Posted August 20, 2008 система linux asp11, установлен vpn (pptpd) сервер, необходимо одновременно держать всего 2-3 соединения, установлено: ppp-2.3.4-7.fc4.i386.rpm pptpd-1.3.4-1.fc4.i386.rpm конфиги: /etc/pptpd.conf option /etc/ppp/options.pptpd localip 192.168.0.200 remoteip 192.168.0.210-220 /etc/ppp/options.pptpd auth name pptpd mtu 1490 mru 1490 refuse-pap refuse-chap ms-dns 192.168.0.1 proxyarp lock nobsdcomp nologfd рвётся соединение, иногда может и по 1,5 часа сиссия работать, и бывает по 3-4 раза в интервале 1 минуты рваться, в логах вот что: Aug 20 08:48:16 boss pppd[26299]: Modem hangup Aug 20 08:48:16 boss pppd[26299]: Connect time 3.9 minutes. Aug 20 08:48:16 boss pppd[26299]: Sent 567712 bytes, received 86297 bytes. Aug 20 08:48:16 boss pppd[26299]: Connection terminated. Aug 20 08:48:16 boss pppd[26299]: Exit. Aug 20 08:48:16 boss pptpd[26298]: CTRL: Client 85.53.222.42 control connection finished Aug 20 08:48:18 boss pptpd[26960]: CTRL: Client 85.53.222.42 control connection started Aug 20 08:48:18 boss pptpd[26960]: CTRL: Starting call (launching pppd, opening GRE) Aug 20 08:48:18 boss pppd[26961]: pppd 2.4.3 started by root, uid 0 Aug 20 08:48:18 boss pppd[26961]: Using interface ppp0 Aug 20 08:48:18 boss pppd[26961]: Connect: ppp0 <--> /dev/pts/15 Aug 20 08:48:20 boss last message repeated 2 times Aug 20 08:48:21 boss pptpd[26960]: CTRL: Ignored a SET LINK INFO packet with real ACCMs! Aug 20 08:48:21 boss kernel: usb 2-2: usbfs: process 24200 (java) did not claim interface 0 before use Aug 20 08:48:21 boss pppd[26961]: local IP address 192.168.0.200 Aug 20 08:48:21 boss pppd[26961]: remote IP address 192.168.0.207 Aug 20 08:48:25 boss last message repeated 2 times Aug 20 08:48:25 boss pptpd[26960]: GRE: read(fd=10,buffer=8053900,len=8260) from network failed: status = -1 error = Message too long Aug 20 08:48:25 boss pptpd[26960]: CTRL: GRE read or PTY write failed (gre,pty)= (10,9) Aug 20 08:48:25 boss pppd[26961]: Modem hangup Aug 20 08:48:25 boss pppd[26961]: Connect time 0.1 minutes. Aug 20 08:48:25 boss pppd[26961]: Sent 10947 bytes, received 2875 bytes. Aug 20 08:48:25 boss pppd[26961]: Connection terminated. Aug 20 08:48:25 boss pppd[26961]: Exit. Aug 20 08:48:25 boss pptpd[26960]: CTRL: Client 85.53.222.42 control connection finished Aug 20 08:48:27 boss pptpd[27024]: CTRL: Client 85.53.222.42 control connection started Aug 20 08:48:27 boss pptpd[27024]: CTRL: Starting call (launching pppd, opening GRE) Aug 20 08:48:27 boss pppd[27025]: pppd 2.4.3 started by root, uid 0 Aug 20 08:48:27 boss pppd[27025]: Using interface ppp0 Aug 20 08:48:27 boss pppd[27025]: Connect: ppp0 <--> /dev/pts/15 Aug 20 08:48:27 boss pptpd[27024]: CTRL: Ignored a SET LINK INFO packet with real ACCMs! Aug 20 08:48:27 boss pppd[27025]: local IP address 192.168.0.200 Aug 20 08:48:27 boss pppd[27025]: remote IP address 192.168.0.207 и ещё обна проблема, при разрыве соединения иногда зависает pppX сессия и висит достаточно долго, как это пожно исправить? Спасибо Вставить ник Quote
yKpon Posted August 20, 2008 Author Posted August 20, 2008 (edited) + ещё один баг: через произвольное время пропадает пинг на любой адрес, в том числе и на localip, помогает пересоединение Edited August 20, 2008 by yKpon Вставить ник Quote
yKpon Posted August 20, 2008 Author Posted August 20, 2008 в каком именно файрволле? там где стоит pptpd? думаю если бы он не был разрешён то не соединялось бы вообще Вставить ник Quote
yKpon Posted August 20, 2008 Author Posted August 20, 2008 думаю проблема разрывов в этом Aug 20 08:48:25 boss pptpd[26960]: GRE: read(fd=10,buffer=8053900,len=8260) from network failed: status = -1 error = Message too long но где устанавливается размер буфера? Вставить ник Quote
nuclearcat Posted August 20, 2008 Posted August 20, 2008 Очень странное сообщение - по идее GRE пакет не должен быть размером в 8260 байта... хотя может он хитро фрагментирован... Вставить ник Quote
yKpon Posted August 21, 2008 Author Posted August 21, 2008 пробовал ставить 2 предыдущие версии pptpd, но никакой разницы... Вопрос по прежнему ещё не решён!!! Вставить ник Quote
