nahash Posted August 13, 2008 Posted August 13, 2008 Возможно ли на Foundry BigIron 4000 поднять NAT. Если да, то как?Ткните носом какие линейки и описания к ним. Вставить ник Quote
D^2 Posted August 14, 2008 Posted August 14, 2008 You can configure a Foundry Layer 3 Switch to perform standard Network Address Translation (NAT). The following types of NAT are supported: • Inside source NAT – Enables private IP networks that use nonregistered IP addresses to connect to the Internet. • Inside destination NAT – Enables you to translate the global (Internet) IP addresses of traffic received from those addresses into private addresses. Foundry Enterprise Configuration and Management Guide.pdf если не ошибаюсь поддержка НАт появилась в BI4000/8000/15000 начиная с управляющих модулей М2. Вставить ник Quote
