Коммутаторы:
3com SuperStack II 1000 12-port (12x10BaseT, 1x100BaseTx, 1xModule) - 160$
3com SuperStack II 1000 24-port (24x10BaseT, 1x100BaseTx, 1xModule) - 190$
3com SuperStack II 1100 24-port (24x10BaseT, 2x100BaseTx, 1xModule) - 230$
5*3com 1100 24-port - 5*220$
10*3com 1100 24-port - 10*210$
15*3com 1100 24-port - 15*200$
3com SuperStack II 3000FX (5x100BaseFX, 1x100BaseTx, 1xModule) - 250$
5*3com 3000FX - 5*230$
10*3com 3000FX - 10*200$
3com SuperStack II 3300 12-port (12x100BaseTx, 1xModule) - 260$
3com SuperStack II 3300 24-port (24x100BaseTx, 1xModule) - 320$
3com SuperStack II 3800 (24x100BaseTx, 1xGBIC, Layer3) - 800$
3com SuperStack II 9300 (12x1000BaseLX) - 2400$
3com CoreBuilder 3500 (18x100BaseFX, 6x100BaseTx, Layer3) - 1200$
Allied Telesyn AT-8126XL (24x100BaseTx, 2x100BaseFX) - 450$
Allied Telesyn AT-8316F/SC (16x100BaseFX) - 700$
Bay Networks BayStack 350T (16x100BaseTx) - 350$
Bay Networks BayStack 350F (12x100BaseTx, 2x100BaseFX) - 400$
Cisco Catalyst 2902 (12x100BaseFX, 2x100BaseTX) - 750$
Cisco Catalyst 2916M-XL (16x100BaseTx, 2xModule) - 500$
Cisco Catalyst 2924-XL (24x100BaseTx) - 650$
Cisco Catalyst 2924C-XL (22x100BaseTx, 2x100BaseFX) - 650$
Cisco Catalyst 2924M-XL (24x100BaseTx, 2xModule) - 750$
Cisco Catalyst 2950T-24 новый (24x100BaseTx, 2x1000BaseT, Layer 3 filtering) - 900$
Cisco Catalyst 3200 (10x100BaseFX, 6x10BaseFL) - 600$
Cisco Catalyst 3550-12T (10x1000BaseT, 2xGBIC, Layer 3 up to EMI) - 6000$
Cisco CSS 11052 (8x100BaseTx, 1x1000BaseSX, 128Mb, HD) новый полнокомплектный - 8000$
Intel Express 510T (24x100BaseTx) - 250$
Lucent Cajun P120 (24x100BaseTx) - 440$
Lucent Cajun P333 (24x100BaseTx) - 440$
Lucent Cajun P334 (48x100BaseTx) - 650$
Модули к коммутаторам:
3com SuperStack II 1000/3000:
1-port 100BaseFX - 50$
1-port 1000BaseSX - 150$
1-port ATM OC-3c MM - 100$
3com SuperStack II 1100/3300:
Matrix module - 100$
Matrix cable - 50$
1-port 100BaseFX - 90$
2-port 100BaseFX - 160$
Lucent Cajun P120/P333/P334:
2xGBIC - 150$
1x1000BaseSX - 250$
2x1000BaseSX - 350$
GBIC:
GBIC 1000BaseSX - 150$
GBIC 1000BaseLX - 200$
Маршрутизаторы:
Cisco 1601 - 300$
Cisco 1721 новый в коробке - 800$
Cisco 3620 - 1200$
Cisco 3640 - 2400$
Cisco 4500-M (12.2 enterprise IOS) - 500$
Cisco 7206VXR (NPE-300, IO-FE) - 6500$
Cisco AS5300 2xE1 VoIP (C549) - 9500$
Cisco AS5300 4xE1 VoIP (C549) - 14500$
Cisco AS5300 2xE1 Modem (MICA, V.92) - 6500$
Cisco AS5350 2xE1 новый - 10000$
Cisco AS5350 4xE1 новый - 18000$
Модули к маршрутизаторам:
Cisco WIC-1ENET (1x10BaseT для 17xx) - 150$
Cisco WIC-2A/S (2 x Low speed smart serial) - 250$
Cisco WIC-1T (1 x Serial) - 120$
Cisco WIC-2T (2 x Smart Serial) - 350$
Cisco WIC-1B-S/T - 250$
Cisco VIC-2FXO (2 x Foreign exchange office) - 250$
Cisco VIC-2B-S/T TE (2 x ISDN BRI) - 250$
Cisco NM-1E2W (1 x 10BaseT, 2 x WIC) - 600$
Cisco NM-1E1R2W (1 x 10BaseT, 1 x Token ring, 2 x WIC) - 650$
Cisco NM-2FE2W новый (2 x 100BaseTx, 2 x WIC) - 1600$
Cisco NM-2V (2 x VIC) - 500$
Cisco NP-1FE (1 x 100BaseTx) - 1200$
Cisco NP-4T (4 x Serial) - 600$
Cisco PA-4E1G/120 - 2000$
Cisco PVDM-12 (12 voice resourses) - 700$
Сетевые карты
Allied Telesyn AT-2560FX/ST (100BaseFX ST) - 50$
SMC Etherpower II (100BaseFX SC) - 70$
Медиаконверторы:
Transition Networks 100BaseT/Tx <-> 100BaseFX/MM-SC новый без БП - 65$
Transition Networks Token Ring <-> Fiber MM ST новый без БП - 40$
Transition Networks 10Base2 <-> Fiber MM ST новый без БП - 40$
Rack Mount на 8 Transition Networks с БП на 220В новый - 100$
Серверы для стоек 19" (новые, с годовой гарантией):
1U 2xPIII - 1Ghz / Intel SAI2 / 512Mb ECC / 36Gb U160 SCSI / SVGA / FDD / 52x CD / LAN 100 / Case Chiftec UNC-110S-B 200W - 1470$
2U 2xXEON - 1.8Ghz / Supermicro / 1Gb PC2100 ECC / RAID 2xU160 SCSI / SVGA / FDD / 52x CD / LAN 1000 / Case Chiftec UNC-210S 420W - 2240$
1U 2xPIII - 1Ghz / Supermicro 3TDDE / 512Mb ECC / Raid IDE 2x40Gb / SVGA / FDD / 52x CD / LAN 100 / Case Chiftec UNC-110S 200W - 1140$
2U 2xAthlon MP 2200+ / Tyan Thunder S2462GN / 1Gb PC2100 Registered / Raid SCSI U160 2x18Gb / SVGA / FDD / 52x CD / LAN 1Gb / Case Chiftec TS50 420W - 2200$
_____________________________________________
Оптовым и постоянным покупателям - скидки.
Работаем без выходных!
Мы предлагаем Вам различное сетевое оборудование по низким ценам.
Все оборудование оттестировано. На оборудование Cisco и 3Com установлены последние прошивки.
Форма оплаты любая. На б/у оборудование гарантия месяц.
Бесплатная доставка по Москве. Возможна доставка в регионы.
По вопросу приобретения оборудования обращайтесь по e-mail: sales@esale.pp.ru, по icq: 163732367 или по телефону (095)722-46-52, 8(916)608-4347
www.esale.pp.ru
