privetstvuju vseh.
u meani est' rabotajushij script s ispolzyvanijem ipfw i natd
code:--------------------------------------------------------------------------------
gwip1="212.59.9.1"
gwip2="213.252.192.141"
gwip3="213.252.192.161"
gw1="212.59.9.59"
gw2="213.252.192.142"
gw3="213.252.192.162"
lan="192.168.0.0/16"
natd -a $gw2 -p 8672
#battle.net
ipfw add 100 divert 8672 tcp from $lan to not $lan 6111
ipfw add 101 divert 8672 tcp from $lan to not $lan 6112
ipfw add 102 divert 8672 tcp from $lan to not $lan 6113
ipfw add 103 divert 8672 tcp from $lan to not $lan 6114
ipfw add 104 divert 8672 tcp from $lan to not $lan 6115
ipfw add 105 divert 8672 tcp from $lan to not $lan 6116
ipfw add 106 divert 8672 tcp from $lan to not $lan 6117
ipfw add 107 divert 8672 tcp from $lan to not $lan 6118
ipfw add 108 divert 8672 tcp from $lan to not $lan 6119
ipfw add 150 divert 8672 udp from $lan to not $lan 6111
ipfw add 151 divert 8672 udp from $lan to not $lan 6112
ipfw add 152 divert 8672 udp from $lan to not $lan 6113
ipfw add 153 divert 8672 udp from $lan to not $lan 6114
ipfw add 154 divert 8672 udp from $lan to not $lan 6115
ipfw add 155 divert 8672 udp from $lan to not $lan 6116
ipfw add 156 divert 8672 udp from $lan to not $lan 6117
ipfw add 157 divert 8672 udp from $lan to not $lan 6118
ipfw add 158 divert 8672 udp from $lan to not $lan 6119
#################### DNS
ipfw add 200 divert 8672 tcp from $lan to not $lan 53
ipfw add 201 divert 8672 udp from $lan to not $lan 53
### eof DNS
ipfw add 250 fwd $gwip2 ip from $gw2 to any
ipfw add 260 divert 8672 ip from any to $gw2
########## eof GW2
natd -a $gw3 -p 8686
ipfw add 303 divert 8686 tcp from $lan to not $lan 80
ipfw add 306 divert 8686 tcp from $lan to not $lan 81
ipfw add 307 divert 8686 tcp from $lan to not $lan 110
ipfw add 309 divert 8686 tcp from $lan to not $lan 443
ipfw add 399 fwd $gwip3 ip from $gw3 to any
ipfw add 400 divert 8686 ip from any to $gw3
natd -a $gw1
ipfw add 1000 divert natd ip from $lan to not $lan
ipfw add 1001 divert natd ip from any to $gw1
### eof gw1
ps. eto chaist' rabotajushego script'a
kak zamenit' eto na ipant + ipfiler ?
proboval tak:
/etc/ipf.rules
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6111
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6112
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6113
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6114
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6115
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6116
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6117
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6118
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6119
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6111
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6112
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6113
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6114
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6115
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6116
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6117
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6118
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6119
################################# EoF War Craft III ################################
######################################## GAMES ###############################
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 4000
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7787
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7777
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7877
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7887
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 9990
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27005
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27015
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27500
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27501
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27960
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 4000
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7787
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7777
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7877
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 7887
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 9990
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27005
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27015
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27500
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27501
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 27960
################################## EoF GAMES ###############################
# DNS
pass in on fxp0 to vlan0:213.252.192.141 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 53
pass in on fxp0 to vlan0:213.252.192.141 proto udp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 53
# main gw (gw1)
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 22
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 25
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 79
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 80
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 81
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 110
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 113
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 443
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 5050
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 5190
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 6667
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 1863
pass in on fxp0 to rl0:213.252.192.161 proto tcp from 192.168.0.0/16 to ! 192.168.0.0/16 port = 2082
pass in on fxp0 to rl0:213.252.192.161 proto icmp from 192.168.0.0/16 to any
# unknown traffic go via gw3
pass in on fxp0 to rl1:212.59.9.1 proto ip from 192.168.0.0/16 to any
/etc/ipnat.rules
map fxp0 192.168.0.0/16 -> 213.252.192.162/32
map rl1 192.168.0.0/16 -> 212.59.9.59/32
map vlan0 192.168.0.0/16 -> 213.252.192.142/32
no kogda zapuskal ping 192.168.1.8 (ip routera) polucahil reply ot 213.252.192.162
es't idei?
spasibo
chiutok smenil ipant.rules
map 213.252.162.162 from 192.168.0.0/16 ! to 192.168.0.0/16 -> 213.252.192.162/32 portmap tcp/udp 10000:60000
map rl1 from 192.168.0.0/16 ! to 192.168.0.0/16 -> 212.59.9.59/32 portmap tcp/udp 10000:60000
map vlan0 from 192.168.0.0/16 ! to 192.168.0.0/16 -> 213.252.192.142/32 portmap tcp/udp 10000:60000
[code]
poskolku fxp0 eto setevoj interface + alias
no kogda ja dobavliaju pravila ipf.rules
ping do servera voobshe propadaet
hotia is SSH nevykidyvaet, i loginitsa normalno
na ftp tozhe zahodit...
pomogite dobrije liudi ;)
Spasibo bolshoe
