Специалисты подскажите как войти в меню бриджа CISKO через консоль тельнетом по сети не пускает.
A straight-through 9-pin serial extension cable is required to connect the COM1 or COM2 port on the computer to the RS-232 serial port on the Access Point. After the cable is connected, use a terminal emulator, such as HyperTerminal, and set the session to:
9600 bits per second (bps)
8 data bits
No parity
1 stop bit
XON/XOFF flow control
1. While the terminal emulator is connected to the console at 9600 bps, 8-N-1, power up the Access Point. The following prompt appears:
Type <esc> within 5 seconds for menu.
2. To enter the menu, press the escape <esc> key. The following prompt appears.
Type '=' for main menu.
3. Type "=" to go to the main menu:
c -- Copy file
f -- File dir
l -- downLoad file into DRAM
u -- Upload file
p -- xfer Protocol
n -- coNsole
r -- Run
s -- System info.
! -- FORMAT memory bank
