lemut Posted May 5, 2008 Posted May 5, 2008 Cisco 7206VXR (NPE-G1) IOS c7200-is-mz.122-31.SB11.bin vpdn enable ! vpdn-group HOMENETS ! Default PPTP VPDN group accept-dialin protocol pptp virtual-template 1 class-map type traffic match-any traffic_local match access-group output 130 match access-group input 120 ! class-map type traffic match-any traffic_world match access-group input 140 match access-group output 150 ! class-map type control match-all PPP_SESSION match protocol vpdn ! class-map type control match-all PPP_UP available authenticated-username ! policy-map type service VPDN service vpdn group HOMENETS sg-service-type primary ! policy-map type service traffic_local class type traffic traffic_local accounting aaa list ISG ! class type traffic default in-out drop ! ! policy-map type service traffic_world class type traffic traffic_world accounting aaa list ISG ! class type traffic default in-out drop ! ! policy-map type control L2_ACCESS class type control PPP_SESSION event session-start 5 authenticate aaa list ISG 10 authorize aaa list ISG identifier authenticated-username 15 service-policy type service name traffic_local 20 service-policy type service name traffic_world ! ! ! ! class-map match-any ftp match access-group 126 access-list 126 permit ip host 10.10.4.18 any access-list 126 permit ip 10.10.15.0 0.0.0.255 any policy-map 128K class ftp shape average 2000000 *May 5 01:17:54.158: RADIUS: Cisco AVpair [1] 27 "ip:sub-qos-policy-in=128K" *May 5 01:17:54.158: RADIUS: Vendor, Cisco [26] 34 *May 5 01:17:54.158: RADIUS: Cisco AVpair [1] 28 "ip:sub-qos-policy-out=128K" *May 5 01:17:54.170: %SW_MGR-3-CM_ERROR_FEATURE_CLASS: Connection Manager Feature Error: Class SSS: (QoS) - install error, ignore. -Traceback= 6106434C 610744BC 61F32564 61F32624 61074744 6107492C 61074D00 61062D78 610630C0 610631B0 6105EC64 6105F080 При такой настройкие шэйпинга вылизает подобная ошибка, может я где то ошибся??? Пробывал policy-map 128K class ftp police cir 2000000 exceed-action drop при такой настройке трафик идет всплесками, и не соответсвует скорости указаной в настрйке попытки измениея размеров буфера, всплесков не превело к желаем результатом. Вставить ник Quote
Bambuk Posted May 5, 2008 Posted May 5, 2008 shape там только в class class-default может работать. но и то пакеты дропаются без превышения очередей под нагрузкой необъяснимо. выделить этот трафик в отдельный сервис и навесить CAR там с burst и exceed - не вариант? Вставить ник Quote
lemut Posted May 5, 2008 Author Posted May 5, 2008 To Bambuk Хотелось бы на каждого абонента выделять полосы, разных велечин и в зависимости от напровлений. Если выделить трафик в сервис, то получится труба. То есть вы хотите сказать что это *May 5 01:17:54.170: %SW_MGR-3-CM_ERROR_FEATURE_CLASS: Connection Manager Feature Error: Class SSS: (QoS) - install error, ignore вызвано не правельной настройкой? На cisco.com не нашел информацию по этой ошибке Вставить ник Quote
cmhungry Posted May 5, 2008 Posted May 5, 2008 мы все-таки вот так давали на впн-кошку, так наиболее четко было с точки зрения резания скорости ''lcp:interface-config#1=rate-limit input XXX 12000 12000 conform-action continue exceed-action drop \n rate-limit output XXX 12000 12000 conform-action continue exceed-action drop Вставить ник Quote
Bambuk Posted May 5, 2008 Posted May 5, 2008 lemut, еще на EFT 3 года назад мы наступили на эти грабли. Выглядело примерно так же. Вот нашел переписку с cisco: Dec 7 15:05:25.443 MSK: %SW_MGR-3-CM_ERROR_FEATURE_CLASS: Connection Manager Feature Error: Class SSS: (QoS) - install error, ignore.-Traceback= 607209C4 60D848EC 60D94430 622DA7BC 622DA87C 60D946B8 60D948A0 60D94C74 60D83340 60D83660 60D83750 60D7F348 60D7F750 Было сказано: You cannot define a shaping under a user-defined class map. Traffic Shaping feature is not supported in user defined class of parent level policy cmhungry, lcp:interface-config для навешивания QoS - устаревшая конструкция, для масштабируемости надо применять ip:sub-qos-policy-in/out. Вставить ник Quote
Cr_net Posted May 5, 2008 Posted May 5, 2008 lemut, еще на EFT 3 года назад мы наступили на эти грабли. Выглядело примерно так же. Вот нашел переписку с cisco:Dec 7 15:05:25.443 MSK: %SW_MGR-3-CM_ERROR_FEATURE_CLASS: Connection Manager Feature Error: Class SSS: (QoS) - install error, ignore.-Traceback= 607209C4 60D848EC 60D94430 622DA7BC 622DA87C 60D946B8 60D948A0 60D94C74 60D83340 60D83660 60D83750 60D7F348 60D7F750 Было сказано:You cannot define a shaping under a user-defined class map. Traffic Shaping feature is not supported in user defined class of parent level policycmhungry, lcp:interface-config для навешивания QoS - устаревшая конструкция, для масштабируемости надо применять ip:sub-qos-policy-in/out. Для масштабируемости, учитывая что у них c7200-is-mz.122-31.SB11 лучше применять rate-limit в профилях конкретного сервиса ISG, а не вешать на всю сессию. Опять же в этом иос работает вот такая конструкция с CBWFQ, а не CAR, назначаемая через av-pair "ip:sub-qos-policy-out=256K".policy-map do_256K class world-out bandwidth percent 80 policy-map do_inet_256K class world-out shape average 256000 service-policy do_256K class local-out bandwidth percent 80 policy-map 256K class class-default shape average 10485760 service-policy do_inet_256K Но применять её не надо, так как под нагрузкой на 72xx у небольшого, но достаточного количества пользователей policy-map применяется, но нифига не отрабатывает, счётчики попаданий по нулям, (кейс открыт, но на проблему забито с обеих сторон, хотя интересно если такой баг на ESR 10К) . К тому же применение CAR по сравнению с CBWFQ даёт экономию cpu примерно 30%. Вставить ник Quote
Bambuk Posted May 5, 2008 Posted May 5, 2008 На 10К/PRE2 вообще shape нельзя, даже в class-default :( Поэтому мы заказали парочку 1004 на пробу. Вставить ник Quote
cmhungry Posted May 5, 2008 Posted May 5, 2008 cmhungry, lcp:interface-config для навешивания QoS - устаревшая конструкция, для масштабируемости надо применять ip:sub-qos-policy-in/out. Наверное да. Ибо мы для 71хх ее пользовали Вставить ник Quote
lemut Posted May 6, 2008 Author Posted May 6, 2008 (edited) To Cr_net Вы предлаегаете вещать конструкцию с ограничением CBWFQ на виртуальный интрефес, получаем у всех одинаковое ограничение скорости в зависимости от направления. Хотелось бы ограничивать в зависимости от типа клиента, и направления, но как я понял ни чего у меня не получится??? Инетересно кстати была вот такая версия для 122-31.SB11, а теперь 12.2(33)SB только для 10К. А для 7200 только 12.2(33)SRC.... Edited May 6, 2008 by lemut Вставить ник Quote
Bambuk Posted May 6, 2008 Posted May 6, 2008 Если направлений и типов клиентов не так много, то заведи соответствующее количество сервисов и включай их через RADIUS профиль, а не через policy-map type control железно в конфиге. Каждому клиенту собственный набор сервисов. Вставить ник Quote
lemut Posted May 6, 2008 Author Posted May 6, 2008 To Bambuk то есть service-policy передавать по CiscoAVPair? Подскажите пожалуйста радиус CiscoAVPair для передачи этого параметра... Вставить ник Quote
Cr_net Posted May 6, 2008 Posted May 6, 2008 To Cr_net Вы предлаегаете вещать конструкцию с ограничением CBWFQ на виртуальный интрефес, получаем у всех одинаковое ограничение скорости в зависимости от направления.Кто мешает завести необходимое количество policy-map? Вряд ли вы в ограничение упрётесь. Проблема в другом, CBWFQ на 72xx не работает так как должно, поэтому применять его не надо. Можете применять CAR по классам так же через ip:sub-qos-policy-out= , но лучше CAR непосредственно в сервисе.Хотелось бы ограничивать в зависимости от типа клиента, и направления, но как я понял ни чего у меня не получится??? http://www.cisco.com/en/US/docs/ios/12_2sb...uide/isg_c.htmlhttp://www.cisco.com/en/US/docs/ios/12_2sb...ide/isg_ig.html Вставить ник Quote
Bambuk Posted May 6, 2008 Posted May 6, 2008 lemut, сами service-policy можно прописать и в конфиге. Если их там не будет, то они будут загружены с RADIUS. В качестве UserName будет имя сервиса, в качестве пароля то что вы в конфиге укажете для загрузки профилей. А в пользовательских профилях сервисы включаются с помощью атрибутов: Cisco-Account-Info = "Aимя_сервиса_1" Cisco-Account-Info = "Aимя_сервиса_2" и т.д. при этом ваш policy-map type control L2_ACCESS можно вообще убрать и рулить всем с RADIUS. Вставить ник Quote
lemut Posted May 12, 2008 Author Posted May 12, 2008 (edited) Передаю Cisco: Account-Info = "Atraffic_local" Cisco: Account-Info = "Atraffic_world" *May 12 01:29:30.392: RADIUS: Vendor, Cisco [26] 22 *May 12 01:29:30.392: RADIUS: ssg-account-info [250] 16 "Atraffic_local" *May 12 01:29:30.392: RADIUS: Vendor, Cisco [26] 22 *May 12 01:29:30.392: RADIUS: ssg-account-info [250] 16 "Atraffic_world" policy-map type service traffic_local class type traffic traffic_local accounting aaa list ISG ! class type traffic default in-out drop ! ! policy-map type service traffic_world class type traffic traffic_world accounting aaa list ISG ! class type traffic default in-out drop ! ! Сесия поднимается, а трафик не попадает под правила... Подскажите пойжалуства в чем дело??? На виртуал темплете сервисов не весит... Edited May 12, 2008 by lemut Вставить ник Quote
Bambuk Posted May 12, 2008 Posted May 12, 2008 Оно не знает в каком порядке их просматривать. Добавьте приоритет. Например чтоб сначала просматривался локальный, а затем весь надо сделать так: policy-map type service traffic_local 100 class type traffic traffic_local accounting aaa list ISG ! class type traffic default in-out drop ! ! policy-map type service traffic_world 200 class type traffic traffic_world accounting aaa list ISG ! class type traffic default in-out drop ! Что после этого будет в sh subscriber session username ... detailed ? Вставить ник Quote
lemut Posted May 12, 2008 Author Posted May 12, 2008 (edited) vpn_7206VXR#sh subscriber session username *** detailed Unique Session ID: 141 Identifier: lem SIP subscriber access type(s): VPDN/PPP Current SIP options: Req Fwding/Req Fwded Session Up-time: 00:00:26, Last Changed: 00:00:26 Interface: Virtual-Access2.1 Policy information: Context 65094B7C: Handle A70000F8 AAA_id 0000005D: Flow_handle 0 Authentication status: authen Downloaded User profile, excluding services: sub-qos-policy-in "128K" ssg-account-info "Atraffic_local" ssg-account-info "Atraffic_world" Downloaded User profile, including services: sub-qos-policy-in "128K" ssg-account-info "Atraffic_local" ssg-account-info "Atraffic_world" Config history for session (recent to oldest): Access-type: PPP Client: SM Policy event: Process Config Connecting Profile name: apply-config-only, 2 references sub-qos-policy-in "128K" ssg-account-info "Atraffic_local" ssg-account-info "Atraffic_world" Session inbound features: Feature: QoS Policy Map Input Policy Map: 128K Configuration sources associated with this session: Interface: Virtual-Template1, Active Time = 00:00:26 По ACL не видно что бы пакеты попадали под правила *May 12 02:41:33.080: RADIUS/ENCODE: Best Local IP-Address 217.*.*.* for Radius-Server 10.10.8.254 *May 12 02:41:33.080: RADIUS(0000005D): Send Access-Request to 10.10.8.254:1812 id 1645/87, len 91 *May 12 02:41:33.080: RADIUS: authenticator CD 1B 26 96 DC 2F 2A D7 - 07 5D EF 35 74 2C A0 22 *May 12 02:41:33.080: RADIUS: Framed-Protocol [7] 6 PPP [1] *May 12 02:41:33.080: RADIUS: User-Name [1] 5 "***" *May 12 02:41:33.080: RADIUS: CHAP-Password [3] 19 * *May 12 02:41:33.080: RADIUS: NAS-Port-Type [61] 6 Virtual [5] *May 12 02:41:33.080: RADIUS: NAS-Port [5] 6 141 *May 12 02:41:33.080: RADIUS: NAS-Port-Id [87] 17 "Uniq-Sess-ID141" *May 12 02:41:33.080: RADIUS: Service-Type [6] 6 Framed [2] *May 12 02:41:33.080: RADIUS: NAS-IP-Address [4] 6 217.*.*.* *May 12 02:41:33.368: RADIUS: Received from id 1645/87 10.10.8.254:1812, Access-Accept, len 97 *May 12 02:41:33.368: RADIUS: authenticator 42 0F F5 B5 34 15 FF CC - 40 86 FC 2A 96 2C 47 83 *May 12 02:41:33.368: RADIUS: Vendor, Cisco [26] 33 *May 12 02:41:33.368: RADIUS: Cisco AVpair [1] 27 "ip:sub-qos-policy-in=128K" *May 12 02:41:33.368: RADIUS: Vendor, Cisco [26] 22 *May 12 02:41:33.368: RADIUS: ssg-account-info [250] 16 "Atraffic_local" *May 12 02:41:33.368: RADIUS: Vendor, Cisco [26] 22 *May 12 02:41:33.368: RADIUS: ssg-account-info [250] 16 "Atraffic_world" *May 12 02:41:33.372: RADIUS(0000005D): Received from id 1645/87 *May 12 02:41:33.372: RADIUS/ENCODE(0000005D):Orig. component type = VPDN *May 12 02:41:33.372: RADIUS(0000005D): Config NAS IP: 0.0.0.0 *May 12 02:41:33.372: RADIUS/ENCODE(0000005D): acct_session_id: 151 *May 12 02:41:33.372: RADIUS(0000005D): sending *May 12 02:41:33.372: RADIUS/ENCODE(0000005D):Orig. component type = VPDN *May 12 02:41:33.372: RADIUS(0000005D): Config NAS IP: 0.0.0.0 *May 12 02:41:33.372: RADIUS/ENCODE(0000005D): acct_session_id: 151 *May 12 02:41:33.372: RADIUS(0000005D): sending *May 12 02:41:33.372: RADIUS/ENCODE: Best Local IP-Address 217.*.*.* for Radius-Server 10.10.8.254 *May 12 02:41:33.372: RADIUS(0000005D): Send Access-Request to 10.10.8.254:1812 id 1645/88, len 94 *May 12 02:41:33.372: RADIUS: authenticator 90 3D 36 14 8D C4 9F DC - E7 7D 13 C5 5C 63 83 EC *May 12 02:41:33.372: RADIUS: User-Name [1] 15 "traffic_world" *May 12 02:41:33.372: RADIUS: User-Password [2] 18 * *May 12 02:41:33.372: RADIUS: NAS-Port-Type [61] 6 Virtual [5] *May 12 02:41:33.372: RADIUS: NAS-Port [5] 6 141 *May 12 02:41:33.372: RADIUS: NAS-Port-Id [87] 17 "Uniq-Sess-ID141" *May 12 02:41:33.372: RADIUS: Service-Type [6] 6 Outbound [5] *May 12 02:41:33.372: RADIUS: NAS-IP-Address [4] 6 217.*.*.* *May 12 02:41:33.372: RADIUS/ENCODE: Best Local IP-Address 217.*.*.* for Radius-Server 10.10.8.254 *May 12 02:41:33.372: RADIUS(0000005D): Send Access-Request to 10.10.8.254:1812 id 1645/89, len 94 *May 12 02:41:33.372: RADIUS: authenticator C7 2B 3E 29 71 15 78 0D - A2 D0 18 7A 48 07 1A 71 *May 12 02:41:33.372: RADIUS: User-Name [1] 15 "traffic_local" *May 12 02:41:33.376: RADIUS: User-Password [2] 18 * *May 12 02:41:33.376: RADIUS: NAS-Port-Type [61] 6 Virtual [5] *May 12 02:41:33.376: RADIUS: NAS-Port [5] 6 141 *May 12 02:41:33.376: RADIUS: NAS-Port-Id [87] 17 "Uniq-Sess-ID141" *May 12 02:41:33.376: RADIUS: Service-Type [6] 6 Outbound [5] *May 12 02:41:33.376: RADIUS: NAS-IP-Address [4] 6 217.*.*.* *May 12 02:41:33.688: RADIUS: Received from id 1645/88 10.10.8.254:1812, Access-Reject, len 36 *May 12 02:41:33.688: RADIUS: authenticator 6C 71 53 74 86 D8 7A 4E - E7 15 A6 17 9F 9C A6 21 *May 12 02:41:33.688: RADIUS: Reply-Message [18] 16 *May 12 02:41:33.688: RADIUS: 52 65 71 75 65 73 74 20 44 65 6E 69 65 64 [ Request Denied] *May 12 02:41:33.688: RADIUS(0000005D): Received from id 1645/88 vpn_7206VXR# *May 12 02:41:33.688: RADIUS/DECODE: Reply-Message fragments, 14, total 14 bytes *May 12 02:41:33.728: RADIUS: Received from id 1645/89 10.10.8.254:1812, Access-Reject, len 36 *May 12 02:41:33.728: RADIUS: authenticator 2F D4 09 28 0C 9A 86 12 - 94 42 F6 04 1B 12 66 48 *May 12 02:41:33.728: RADIUS: Reply-Message [18] 16 *May 12 02:41:33.728: RADIUS: 52 65 71 75 65 73 74 20 44 65 6E 69 65 64 [ Request Denied] *May 12 02:41:33.728: RADIUS(0000005D): Received from id 1645/89 *May 12 02:41:33.728: RADIUS/DECODE: Reply-Message fragments, 14, total 14 bytes Читаю пример конфигурации, в котором сервисы передаются через радиус, это не обязательный вариант создания сервисов??? Edited May 12, 2008 by lemut Вставить ник Quote
Cr_net Posted May 12, 2008 Posted May 12, 2008 vpn_7206VXR#sh subscriber session username *** detailedUnique Session ID: 141 Identifier: lem SIP subscriber access type(s): VPDN/PPP Current SIP options: Req Fwding/Req Fwded Session Up-time: 00:00:26, Last Changed: 00:00:26 Interface: Virtual-Access2.1 Policy information: Context 65094B7C: Handle A70000F8 AAA_id 0000005D: Flow_handle 0 Authentication status: authen Downloaded User profile, excluding services: sub-qos-policy-in "128K" ssg-account-info "Atraffic_local" ssg-account-info "Atraffic_world" Downloaded User profile, including services: sub-qos-policy-in "128K" ssg-account-info "Atraffic_local" ssg-account-info "Atraffic_world" Config history for session (recent to oldest): Access-type: PPP Client: SM Policy event: Process Config Connecting Profile name: apply-config-only, 2 references sub-qos-policy-in "128K" ssg-account-info "Atraffic_local" ssg-account-info "Atraffic_world" Session inbound features: Feature: QoS Policy Map Input Policy Map: 128K Configuration sources associated with this session: Interface: Virtual-Template1, Active Time = 00:00:26 По ACL не видно что бы пакеты попадали под правила *May 12 02:41:33.080: RADIUS/ENCODE: Best Local IP-Address 217.*.*.* for Radius-Server 10.10.8.254 *May 12 02:41:33.080: RADIUS(0000005D): Send Access-Request to 10.10.8.254:1812 id 1645/87, len 91 *May 12 02:41:33.080: RADIUS: authenticator CD 1B 26 96 DC 2F 2A D7 - 07 5D EF 35 74 2C A0 22 *May 12 02:41:33.080: RADIUS: Framed-Protocol [7] 6 PPP [1] *May 12 02:41:33.080: RADIUS: User-Name [1] 5 "***" *May 12 02:41:33.080: RADIUS: CHAP-Password [3] 19 * *May 12 02:41:33.080: RADIUS: NAS-Port-Type [61] 6 Virtual [5] *May 12 02:41:33.080: RADIUS: NAS-Port [5] 6 141 *May 12 02:41:33.080: RADIUS: NAS-Port-Id [87] 17 "Uniq-Sess-ID141" *May 12 02:41:33.080: RADIUS: Service-Type [6] 6 Framed [2] *May 12 02:41:33.080: RADIUS: NAS-IP-Address [4] 6 217.*.*.* *May 12 02:41:33.368: RADIUS: Received from id 1645/87 10.10.8.254:1812, Access-Accept, len 97 *May 12 02:41:33.368: RADIUS: authenticator 42 0F F5 B5 34 15 FF CC - 40 86 FC 2A 96 2C 47 83 *May 12 02:41:33.368: RADIUS: Vendor, Cisco [26] 33 *May 12 02:41:33.368: RADIUS: Cisco AVpair [1] 27 "ip:sub-qos-policy-in=128K" *May 12 02:41:33.368: RADIUS: Vendor, Cisco [26] 22 *May 12 02:41:33.368: RADIUS: ssg-account-info [250] 16 "Atraffic_local" *May 12 02:41:33.368: RADIUS: Vendor, Cisco [26] 22 *May 12 02:41:33.368: RADIUS: ssg-account-info [250] 16 "Atraffic_world" *May 12 02:41:33.372: RADIUS(0000005D): Received from id 1645/87 *May 12 02:41:33.372: RADIUS/ENCODE(0000005D):Orig. component type = VPDN *May 12 02:41:33.372: RADIUS(0000005D): Config NAS IP: 0.0.0.0 *May 12 02:41:33.372: RADIUS/ENCODE(0000005D): acct_session_id: 151 *May 12 02:41:33.372: RADIUS(0000005D): sending *May 12 02:41:33.372: RADIUS/ENCODE(0000005D):Orig. component type = VPDN *May 12 02:41:33.372: RADIUS(0000005D): Config NAS IP: 0.0.0.0 *May 12 02:41:33.372: RADIUS/ENCODE(0000005D): acct_session_id: 151 *May 12 02:41:33.372: RADIUS(0000005D): sending *May 12 02:41:33.372: RADIUS/ENCODE: Best Local IP-Address 217.*.*.* for Radius-Server 10.10.8.254 *May 12 02:41:33.372: RADIUS(0000005D): Send Access-Request to 10.10.8.254:1812 id 1645/88, len 94 *May 12 02:41:33.372: RADIUS: authenticator 90 3D 36 14 8D C4 9F DC - E7 7D 13 C5 5C 63 83 EC *May 12 02:41:33.372: RADIUS: User-Name [1] 15 "traffic_world" *May 12 02:41:33.372: RADIUS: User-Password [2] 18 * *May 12 02:41:33.372: RADIUS: NAS-Port-Type [61] 6 Virtual [5] *May 12 02:41:33.372: RADIUS: NAS-Port [5] 6 141 *May 12 02:41:33.372: RADIUS: NAS-Port-Id [87] 17 "Uniq-Sess-ID141" *May 12 02:41:33.372: RADIUS: Service-Type [6] 6 Outbound [5] *May 12 02:41:33.372: RADIUS: NAS-IP-Address [4] 6 217.*.*.* *May 12 02:41:33.372: RADIUS/ENCODE: Best Local IP-Address 217.*.*.* for Radius-Server 10.10.8.254 *May 12 02:41:33.372: RADIUS(0000005D): Send Access-Request to 10.10.8.254:1812 id 1645/89, len 94 *May 12 02:41:33.372: RADIUS: authenticator C7 2B 3E 29 71 15 78 0D - A2 D0 18 7A 48 07 1A 71 *May 12 02:41:33.372: RADIUS: User-Name [1] 15 "traffic_local" *May 12 02:41:33.376: RADIUS: User-Password [2] 18 * *May 12 02:41:33.376: RADIUS: NAS-Port-Type [61] 6 Virtual [5] *May 12 02:41:33.376: RADIUS: NAS-Port [5] 6 141 *May 12 02:41:33.376: RADIUS: NAS-Port-Id [87] 17 "Uniq-Sess-ID141" *May 12 02:41:33.376: RADIUS: Service-Type [6] 6 Outbound [5] *May 12 02:41:33.376: RADIUS: NAS-IP-Address [4] 6 217.*.*.* *May 12 02:41:33.688: RADIUS: Received from id 1645/88 10.10.8.254:1812, Access-Reject, len 36 *May 12 02:41:33.688: RADIUS: authenticator 6C 71 53 74 86 D8 7A 4E - E7 15 A6 17 9F 9C A6 21 *May 12 02:41:33.688: RADIUS: Reply-Message [18] 16 *May 12 02:41:33.688: RADIUS: 52 65 71 75 65 73 74 20 44 65 6E 69 65 64 [ Request Denied] *May 12 02:41:33.688: RADIUS(0000005D): Received from id 1645/88 vpn_7206VXR# *May 12 02:41:33.688: RADIUS/DECODE: Reply-Message fragments, 14, total 14 bytes *May 12 02:41:33.728: RADIUS: Received from id 1645/89 10.10.8.254:1812, Access-Reject, len 36 *May 12 02:41:33.728: RADIUS: authenticator 2F D4 09 28 0C 9A 86 12 - 94 42 F6 04 1B 12 66 48 *May 12 02:41:33.728: RADIUS: Reply-Message [18] 16 *May 12 02:41:33.728: RADIUS: 52 65 71 75 65 73 74 20 44 65 6E 69 65 64 [ Request Denied] *May 12 02:41:33.728: RADIUS(0000005D): Received from id 1645/89 *May 12 02:41:33.728: RADIUS/DECODE: Reply-Message fragments, 14, total 14 bytes Читаю пример конфигурации, в котором сервисы передаются через радиус, это не обязательный вариант создания сервисов??? У Вас не видно Active services associated with session: В aaa не указано где железка должна брать сервисы локально или с радиуса. aaa authorization network default парампампам или local aaa authorization subscriber-service default group парампампам или local Плясать отсюда: show run | inc aaa debug debug subscriber aaa authorization debug subscriber service debug subscriber error debug subscriber fsm ter monitor Вставить ник Quote
Bambuk Posted May 12, 2008 Posted May 12, 2008 aaa authorization subscriber-service default local group ... local имеется и стоит на первом месте? Если нет, то оно в конфиг за сервисами смотреть не будет. По вашему дебагу как раз видно, что оно сервисы с RADIUS сервера хочет загрузить. И в RADIUS профиль пользователя я бы еще как минимум добавил: Framed-Protocol = PPP Service-Type = Framed-User Вставить ник Quote
lemut Posted May 12, 2008 Author Posted May 12, 2008 Благодарю, таким образом сервисы подключаются Вставить ник Quote
