TheUser Posted April 24, 2008 Posted April 24, 2008 Привет! Имеется следующее решение: Шлюз FreeBSD, ошибок на портах нет. В интерфейс этого шлюза подключен DSL-пул, совместно с модемами являющийся мостом. Проблема. IP_ADDR - адрес железки, висящей за мостом. Пингуем со шлюза FreeBSD. ping -i 0.01 -s 1472 IP_ADDR выдает примерно следующее: PING IP_ADDR (IP_ADDR): 1472 data bytes 1480 bytes from IP_ADDR: icmp_seq=0 ttl=255 time=30.569 ms 1480 bytes from IP_ADDR: icmp_seq=1 ttl=255 time=36.712 ms 1480 bytes from IP_ADDR: icmp_seq=2 ttl=255 time=42.722 ms 1480 bytes from IP_ADDR: icmp_seq=3 ttl=255 time=48.713 ms 1480 bytes from IP_ADDR: icmp_seq=4 ttl=255 time=55.225 ms 1480 bytes from IP_ADDR: icmp_seq=5 ttl=255 time=61.204 ms 1480 bytes from IP_ADDR: icmp_seq=6 ttl=255 time=68.612 ms 1480 bytes from IP_ADDR: icmp_seq=7 ttl=255 time=74.211 ms 1480 bytes from IP_ADDR: icmp_seq=8 ttl=255 time=80.594 ms 1480 bytes from IP_ADDR: icmp_seq=9 ttl=255 time=86.213 ms 1480 bytes from IP_ADDR: icmp_seq=10 ttl=255 time=93.653 ms 1480 bytes from IP_ADDR: icmp_seq=11 ttl=255 time=98.215 ms 1480 bytes from IP_ADDR: icmp_seq=12 ttl=255 time=103.724 ms 1480 bytes from IP_ADDR: icmp_seq=13 ttl=255 time=108.734 ms 1480 bytes from IP_ADDR: icmp_seq=14 ttl=255 time=114.756 ms 1480 bytes from IP_ADDR: icmp_seq=15 ttl=255 time=120.748 ms 1480 bytes from IP_ADDR: icmp_seq=16 ttl=255 time=126.740 ms 1480 bytes from IP_ADDR: icmp_seq=17 ttl=255 time=132.746 ms 1480 bytes from IP_ADDR: icmp_seq=18 ttl=255 time=138.744 ms 1480 bytes from IP_ADDR: icmp_seq=19 ttl=255 time=144.513 ms 1480 bytes from IP_ADDR: icmp_seq=20 ttl=255 time=149.493 ms 1480 bytes from IP_ADDR: icmp_seq=21 ttl=255 time=155.514 ms 1480 bytes from IP_ADDR: icmp_seq=22 ttl=255 time=161.524 ms 1480 bytes from IP_ADDR: icmp_seq=23 ttl=255 time=167.180 ms 1480 bytes from IP_ADDR: icmp_seq=24 ttl=255 time=173.501 ms 1480 bytes from IP_ADDR: icmp_seq=25 ttl=255 time=179.507 ms 1480 bytes from IP_ADDR: icmp_seq=26 ttl=255 time=186.371 ms 1480 bytes from IP_ADDR: icmp_seq=27 ttl=255 time=192.264 ms 1480 bytes from IP_ADDR: icmp_seq=28 ttl=255 time=198.285 ms 1480 bytes from IP_ADDR: icmp_seq=29 ttl=255 time=204.264 ms 1480 bytes from IP_ADDR: icmp_seq=30 ttl=255 time=210.263 ms 1480 bytes from IP_ADDR: icmp_seq=31 ttl=255 time=216.278 ms 1480 bytes from IP_ADDR: icmp_seq=32 ttl=255 time=222.703 ms 1480 bytes from IP_ADDR: icmp_seq=33 ttl=255 time=228.274 ms 1480 bytes from IP_ADDR: icmp_seq=34 ttl=255 time=234.279 ms 1480 bytes from IP_ADDR: icmp_seq=35 ttl=255 time=240.054 ms 1480 bytes from IP_ADDR: icmp_seq=36 ttl=255 time=246.035 ms 1480 bytes from IP_ADDR: icmp_seq=37 ttl=255 time=252.125 ms 1480 bytes from IP_ADDR: icmp_seq=38 ttl=255 time=258.042 ms 1480 bytes from IP_ADDR: icmp_seq=39 ttl=255 time=264.037 ms 1480 bytes from IP_ADDR: icmp_seq=40 ttl=255 time=270.043 ms 1480 bytes from IP_ADDR: icmp_seq=41 ttl=255 time=276.497 ms 1480 bytes from IP_ADDR: icmp_seq=42 ttl=255 time=280.806 ms 1480 bytes from IP_ADDR: icmp_seq=43 ttl=255 time=288.787 ms 1480 bytes from IP_ADDR: icmp_seq=44 ttl=255 time=294.776 ms 1480 bytes from IP_ADDR: icmp_seq=45 ttl=255 time=300.533 ms 1480 bytes from IP_ADDR: icmp_seq=46 ttl=255 time=306.868 ms 1480 bytes from IP_ADDR: icmp_seq=47 ttl=255 time=313.533 ms 1480 bytes from IP_ADDR: icmp_seq=48 ttl=255 time=320.492 ms 1480 bytes from IP_ADDR: icmp_seq=49 ttl=255 time=325.479 ms 1480 bytes from IP_ADDR: icmp_seq=50 ttl=255 time=333.012 ms 1480 bytes from IP_ADDR: icmp_seq=51 ttl=255 time=340.494 ms 1480 bytes from IP_ADDR: icmp_seq=52 ttl=255 time=348.714 ms 1480 bytes from IP_ADDR: icmp_seq=53 ttl=255 time=354.718 ms 1480 bytes from IP_ADDR: icmp_seq=54 ttl=255 time=360.475 ms ^C --- IP_ADDR ping statistics --- 88 packets transmitted, 55 packets received, 37% packet loss round-trip min/avg/max/stddev = 30.569/193.138/360.475/95.705 ms Т.е. пакеты накапливаются в каком-то буфере (скорее всего ADSL-пула) из-за перепада скорости, после чего ждут отправки и т.п.... Версия с перегрузкой железки отвергается - на тестовом стенде подобная железка пингуется нормально. Или в чем может быть проблема? И как победить? П.С. Железка - voip шлюз, держит 8 линий. Вставить ник Quote
Info-lan Posted April 24, 2008 Posted April 24, 2008 (edited) 1480 bytes from IP_ADDR: icmp_seq=54 ttl=255 time=360.475 ms Очень мало железок(практически нет) которые имеют рамер буфера на 360мс. Данные пакеты накапливаются в буффере компьютера. Отключите flowcontrol и задержки будут минимальные.(Но будут теряться пакеты) Edited April 24, 2008 by Info-lan Вставить ник Quote
TheUser Posted April 24, 2008 Author Posted April 24, 2008 1480 bytes from IP_ADDR: icmp_seq=54 ttl=255 time=360.475 ms Очень мало железок(практически нет) которые имеют рамер буфера на 360мс. Данные пакеты накапливаются в буффере компьютера. Отключите flowcontrol и задержки будут минимальные.(Но будут теряться пакеты) flowcontrol на свиче между DSL и шлюзом выключен. На шлюзе не нашел как включить/отключить для ethernet карточек. Вставить ник Quote
