Требуется каждому dialpeer назначать свой радиус сервер
Пробую так
aaa group server radius group1
server 192.168.128.82 auth-port 1812 acct-port 1813
aaa group server radius group_test
server 192.168.128.65 auth-port 1812 acct-port 1813
aaa authentication login group_test group group_test
aaa authentication login group1 group group1
aaa authorization exec group_test group group_test
aaa authorization exec group1 group group1
aaa accounting connection group_test start-stop group group_test
aaa accounting connection group1 start-stop group group1
aaa session-id common
voice class aaa 20
authorization method group_test
accounting method group_test
voice class aaa 10
authorization method group1
accounting method group1
application
service ivr_test flash:test.tcl
  paramspace russian location flash:prompts/ru/
  param uid-len 9
  param pin-len 0
  paramspace russian prefix ru
  paramspace russian language ru
  paramspace russian index 1
service ivr_dogovor flash:dogovor.tcl
  param uid-len 9
  param pin-len 0
package russian flash:ru_translate.tcl
  param prefix ru
  param language ru
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 1/1
controller E1 1/2
controller E1 1/3
gw-accounting aaa
suppress pots
translation-rule 1
Rule 0 ^. 9999#
radius-server host 192.168.128.82 auth-port 1812 acct-port 1813
radius-server host 192.168.128.65 auth-port 1812 acct-port 1813
radius-server key 7 00140011
radius-server vsa send accounting
radius-server vsa send authentication
dial-peer voice 100 pots
huntstop
service ivr_dogovor
voice-class aaa 10
incoming called-number 47003
dial-peer voice 500 pots
huntstop
service ivr_test
voice-class aaa 20
incoming called-number 47009
authentication и authorization проходит тама где и предузумевается, но accounting идет только в тот радиус, который первым стоит в конфиге.
Прошивка: c5350-jk9s-mz.124-7a.bin
