в IOS тока начинаю разбираться, сечас трафик считается через loopback, ткнули носом в новую фичу ip flow ingress, подскажите что надо подправить в конфиге?
version 12.4
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
no service password-encryption
service internal
hostname gatew
boot-start-marker
boot-end-marker
logging buffered 4096
aaa new-model
aaa authentication login userauthen local
aaa authorization exec default local
aaa authorization network vpnuser1 local
aaa session-id common
memory-size iomem 15
clock timezone GMT+3 3
clock summer-time GMT+3 recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip source-route
ip cef
no ip bootp server
ip domain name domain.ru
ip name-server xxx.xxx.xxx.xxx
multilink bundle-name authenticated
voice-card 0
no dspfarm
interface Loopback0
ip address 192.168.10.1 255.255.255.0
ip route-cache policy
ip route-cache flow
interface FastEthernet0/0
description connected to LAN
ip address yyy.yyy.yyy.yyy 255.255.255.0
ip access-group LAN_Firewall in
ip nat inside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
description connected to INTERNET
ip address xxx.xxx.xxx.xxx 255.255.255.128
ip access-group Inet_Firewall in
ip nat outside
ip route-cache flow
ip policy route-map MAP
duplex auto
speed auto
no cdp enable
ip route 0.0.0.0 0.0.0.0 zzz.zzz.zzz.zzz
ip route 192.168.0.0 255.255.0.0 192.168.0.101
ip flow-cache timeout inactive 60
ip flow-cache timeout active 10
ip flow-export version 5
ip flow-export destination 192.168.1.11 20001
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
ip access-list extended Inet_Firewall
remark internalPorts
permit tcp any any eq 22 log-input
remark allowALL
permit ip any any
ip access-list extended LAN_Firewall
remark FullAccess
permit tcp host 192.168.0.6 any
permit tcp host 192.168.1.11 any
permit icmp 192.168.0.0 0.0.255.255 any
access-list 1 permit 192.168.0.100
access-list 1 permit 192.168.0.6
access-list 101 permit ip any 192.168.0.0 0.0.255.255
no cdp run
route-map MAP permit 10
match ip address 101
set interface Loopback0
ip flow ingress это не новая фич, это как раз старая.
Традиционно NetFlow экспортирует только трафик ВХОДЯЩИЙ на интерфейс.
Относительно недавно появилась возможность писать:
ip flow egress
Что позволяет экспортировать и ИСХОДЯЩИЙ трафик тоже.На одном и том же интерфейсе.
По этому пропала необходимость прокидывать его через лупбак.
Та,что пиши
ip flow egress
ip flow ingress
И убирай "заворот" на loopback
