Народ столкнулся с проблемой
есть сеть User <-> Dlink DES3526 <-> Dlink DGS3612G <-> Cisco 7201 <-> DHCP server (isc-dhcpd)
на Dlink DES3526 и Dlink DGS3612G включен dhcp relay и в качестве сервера стоит Cisco 7201
надо чтоб Cisco 7201 делала relay на DHCP server (isc-dhcpd)
настройка на Cisco 7201
c7201-core1-1#sh running-config
Building configuration...
Current configuration : 2052 bytes
! Last configuration change at 14:15:44 UTC Wed Apr 9 2008 by snake
! NVRAM config last updated at 14:10:31 UTC Wed Apr 9 2008 by snake
upgrade fpd auto
version 12.2
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname c7201-core1-1
boot-start-marker
boot-end-marker
enable secret 5 ********
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip subnet-zero
ip cef
ip name-server 77.87.152.9
ip dhcp use vrf connected
ip dhcp-server xx.yy.152.43
call rsvp-sync
no scripting tcl init
no scripting tcl encdir
no file verify auto
username snake secret 5 ****
interface Loopback0
no ip address
interface FastEthernet0/0
no ip address
shutdown
speed auto
duplex auto
interface GigabitEthernet0/0
no ip address
media-type rj45
speed auto
duplex auto
negotiation auto
interface GigabitEthernet0/0.5
description # Uplink from C3560E_SW
encapsulation dot1Q 5
ip address xx.yy.152.66 255.255.255.224
no snmp trap link-status
interface GigabitEthernet0/1
no ip address
media-type rj45
speed auto
duplex auto
negotiation auto
interface GigabitEthernet0/1.999
description # network iface
encapsulation dot1Q 999
ip address 10.10.10.1 255.255.0.0
ip helper-address xx.yy.152.43
interface GigabitEthernet0/2
no ip address
shutdown
speed auto
duplex auto
negotiation auto
interface GigabitEthernet0/3
no ip address
shutdown
speed auto
duplex auto
negotiation auto
ip classless
ip route 0.0.0.0 0.0.0.0 xx.yy.152.65
no ip http server
control-plane
dial-peer cor custom
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
ntp clock-period 17180509
ntp server 81.171.98.5
ntp server 80.190.251.105
ntp server 82.133.58.132
end
c7201-core1-1#
на Cisco 7201 включен дебаг
c7201-core1-1#
Apr 9 14:17:25.386: DHCPD: Reload workspace interface GigabitEthernet0/1.999 tableid 0.
Apr 9 14:17:25.386: DHCPD: tableid for 10.10.10.1 on GigabitEthernet0/1.999 is 0
Apr 9 14:17:25.386: DHCPD: client's VPN is .
Apr 9 14:17:25.386: DHCPD: Sending notification of DISCOVER:
Apr 9 14:17:25.386: DHCPD: htype 1 chaddr 0013.7731.474e
Apr 9 14:17:25.386: DHCPD: remote id 020a00000a0a0a01010003e7
Apr 9 14:17:25.386: DHCPD: circuit id ffffffff
Apr 9 14:17:25.386: DHCPD: setting giaddr to 10.10.10.1.
Apr 9 14:17:25.386: DHCPD: BOOTREQUEST from 0100.1377.3147.4e forwarded to xx.yy.152.43.
Apr 9 14:17:28.386: DHCPD: Reload workspace interface GigabitEthernet0/1.999 tableid 0.
Apr 9 14:17:28.386: DHCPD: tableid for 10.10.10.1 on GigabitEthernet0/1.999 is 0
Apr 9 14:17:28.386: DHCPD: client's VPN is .
Apr 9 14:17:28.386: DHCPD: Sending notification of DISCOVER:
Apr 9 14:17:28.386: DHCPD: htype 1 chaddr 0013.7731.474e
Apr 9 14:17:28.386: DHCPD: remote id 020a00000a0a0a01010003e7
Apr 9 14:17:28.386: DHCPD: circuit id ffffffff
Apr 9 14:17:28.386: DHCPD: setting giaddr to 10.10.10.1.
Apr 9 14:17:28.386: DHCPD: BOOTREQUEST from 0100.1377.3147.4e forwarded to xx.yy.152.43.
Apr 9 14:17:36.386: DHCPD: Reload workspace interface GigabitEthernet0/1.999 tableid 0.
Apr 9 14:17:36.386: DHCPD: tableid for 10.10.10.1 on GigabitEthernet0/1.999 is 0
Apr 9 14:17:36.386: DHCPD: client's VPN is .
Apr 9 14:17:36.386: DHCPD: Sending notification of DISCOVER:
Apr 9 14:17:36.386: DHCPD: htype 1 chaddr 0013.7731.474e
Apr 9 14:17:36.386: DHCPD: remote id 020a00000a0a0a01010003e7
Apr 9 14:17:36.386: DHCPD: circuit id ffffffff
Apr 9 14:17:36.386: DHCPD: setting giaddr to 10.10.10.1.
Apr 9 14:17:36.386: DHCPD: BOOTREQUEST from 0100.1377.3147.4e forwarded to xx.yy.152.43.
в чем проблема? кто то знает?
Edited by MrSnaKe
нет вопрос в том, что конечный пользователь подключен в Dlink DES3526 попадает на Dlink DGS3612G и релеется на Cisco 7201, которая есть дхцп сервером, но проблема в том, что надо, чтоб Cisco 7201 выдавала ИП не со своего пула, а релей делала на DHCP server (isc-dhcpd), который стоит на отдельной машыне на FreBSD. Получается, что к Cisco 7201 приходить не чистой ДХЦП запрос, а уже с опцией 82, и команда ip helper-address здесь не проходит.
смотрел здесь
http://www.cisco.com/en/US/docs/ios/ipaddr...cp_rly_agt.html
пока что резутьтата нет. Поможешь?
А если в качестве сервера ставить не 7201?
Не очень понятно - зачем столько релеев...
В том же документе:
A DHCP relay agent may receive a message from another DHCP relay agent that already contains relay information. By default, the relay information from the previous relay agent is replaced. If this behavior is not suitable for your network, you can use the ip dhcp relay information policy {drop | keep | replace} global configuration command to change it.
мне надо чтоб ISG работало, а оно инициюется DHCP дискавером, а вешать маршрутизацию между юзерами на БРАС ето лишняя нагрузка ... вот и по етому так сложно
Очевидно Cisco делает dhcp-релей, но ответа не получает. Связность между 10.10.10.1 и xx.yy.152.43 имеется? До DHCP-сервера запросы доходят?
DHCP relay agent может получить сообщение от другого DHCP relay agent'а, которое уже содержит дополнительную информацию. По-умолчанию, дополнительная информация от предыдущего relay agent'а заменяется. Если такое поведение не годится для Вашей сети, вы можете использовать команду глобальной конфигурации ip dhcp relay information policy {drop | keep | replace}, чтобы изменить его.
А оно так вообще будет работать? Разме можно на dhcp пакет навесить две 82 опции?
говорят что будет ... Циско говорит ... но сказать как именно настроить неможет
