  • 1 year later...
Resources, Manual for the latest firmware, etc: http://ftp.dlink.ru/pub/Switch/DES-3000%20Series/
D-Link DES-3026 Complete Upgrade + Password Recovery Procedure (Firmware Recovery) (compatible with DES-3018 etc. DES-30xx):
1. Connet with RS232 Cable ~ 9600-N-8-1-N (No Flow Control !) (If previus admin changed baud rate - find it by trial & error/bruteforce method)
2. (As read in DES-3000_HOWTO_upgrade_PROM_code.doc (Rus)) - reboot and quickly press Shift + 3 (# sign)
3. Change to 115200 baud rate to upload the latest firmware (I did this first for PROM and then for Firmware image: PROM - 30xx_prom_1.01.009.had and the actual Firmware - DES3000_V4.20.027.had)
4. Reboot the switch. After firmware image has loaded 100% quickly press Shift + 6 (^ sign) ( Password Recovery Procedure.pdf from .fr FTP server ) (available since v4.00.018/PROM 1.01.007 R4.20.B27 changelog)
5. Enter ? to see the reset-related commands. Do the thing you need - reset, etc..
6. When the switch is upgraded and the accounts reset - the default login is D-Link/D-Link (as I found on the net and probably in the manual phenoelit-us.org/dpl/dpl.html default-password.info/d-link/)
It took me half a day to find and read all the documents for this ... and the trial & error technique to actually find out the full procedure. I did everything with SecureCRT but it will work with HyperTerminal as well.
Thanks to D-Link for maintaining their producst and FTP servers.
Interesting hardware hack of another model: blog.springdaemons.com/2008/3/12/hacking-the-d-link-dgs-1248t-switch
Edited by NetworkPro
  • 7 years later...
Привезли с сети старичка des-3026 с симптомами циклической перезагрузки, в консоли видно:
 Boot Procedure                                                    V1.01.009
 Power On Self Test ........................................ 100 %
 MAC Address   : 00-1B-11-11-58-CE
 H/W Version   : A3
 Please Wait, Loading V4.30.B23 Runtime Image .............. 100 %
Fatal Error : DRV_PORT_Init->PHY_Init(port 3) Fail! current task : myRoot HALT !
и так по кругу.
Вставил в 3й порт "хвостик" с замкнутыми накоротко приемом и передачей - не помогло.
Через Shift+3 перезалил boot_prom и софт - симптомы не исчезли.
В морг? Или как-то можно реанимировать?
В морг, свич-матрица битая, а замены уже нет - сняты с производства.
Она в какой-то микрухе? А то валяется еще парочка таких свичей с большии кол-вом битых портов или другими неисправностями. Может получится собрать из них работающий?
Она там одна и есть - BCM5324 и матрица и портовка всё-в-одном. Тот случай, когда из кучи калек ничего не собрать, т.к. выгорело у всех одно и то же.
