doubtpoint Posted March 25, 2008 Posted March 25, 2008 freebsd 6.3 ipcad 3.7.3_1 и ipcad 3.7 При запуске вылетает Opening locnet0... [LCap] [ERSH] [4096] [locnet0/interactive] Initialized as 1 Opening inet0... [LCap] [ERSH] [4096] [inet0/interactive] Initialized as 2 Opening ng*... [LCap] [ERSH] [DYNAMIC] Initialized as 0 Aggregate ports 1024..65535 into 65535 Aggregate ports 3128..3128 into 3128?? S<s 12:32AM 86:28.66 /usr/local/bin/ipcad -rds -c /usr/local/etc/ipcad.conf Configured RSH Server listening at 127.0.0.1 12:03AM 0:00.00 /bin/csh -c ps -waux | grep ipcad RSH Server thread 134960128 started.p0 RL+ 12:03AM 0:00.00 grep ipcad Thread 134960640 processing ng* started. Thread 134961152 processing inet0 started.apacity Mounted on Thread 134961664 processing locnet0 started. 1% / Opening ng0... [LCap] [ERSH] [4096] [ng0/interactive] Initialized as 3 Opening ng1... [LCap] [ERSH] [4096] [ng1/interactive] Initialized as 4 Opening ng2... [LCap] [ERSH] [4096] [ng2/interactive] Initialized as 5 .... pening ng445... [LCap] [ERSH] [4096] [ng445/interactive] Initialized as 381 Opening ng448... [LCap] [ERSH] [4096] [ng448/interactive] Initialized as 382 Opening ng449... [LCap] [ERSH] [4096] [ng449/interactive] Initialized as 383 Opening ng450... [LCap] [ERSH] [4096] [ng450/interactive] Initialized as 384 ipcad in free(): error: chunk is already free Abort (core dumped) Конфиг один в один работает на другом сервере(Может какие ни будь параметры ядра забыл включить?). capture-ports enable; # Enable ports capturing for RSH (no effect on NetFlow). interface locnet0; # Listen on Ethernet interface... interface inet0; # ...and another onw. interface ng*; # Listen on all ng* interfaces. aggregate 1024-65535 into 65535; /* Aggregate wildly */ aggregate 3128-3128 into 3128; /* Protect these ports */ rsh enable at 127.0.0.1; rsh root@127.0.0.1 admin; /* Can shutdown ipcad */ rsh 127.0.0.1 view-only; /* Other users can view current tables */ rsh ttl = 3; rsh timeout = 30; pidfile = /var/log/ipcad/ipcad.pid; # Will be created under chroot memory_limit = 64m; dumpfile = /var/log/ipcad/ipcad.dump; Если из конфига убрать ng то прекрасно работает. #interface ng*; # Listen on all ng* interfaces. В какую сторону капать? Вставить ник Quote
edwin Posted March 26, 2008 Posted March 26, 2008 Кроме того в самом mpd есть свой NetFlow генератор. Работает вполне даже ничего Вставить ник Quote
mikevlz Posted March 28, 2008 Posted March 28, 2008 mpd в качестве нетфлоу-генератора использует именно ng_netflow Вставить ник Quote
doubtpoint Posted April 3, 2008 Author Posted April 3, 2008 Проблема решилась комментированием в loader.conf следующих строчек(сервер имеет 4гб памяти) #kern.dfldsiz="2548M" #kern.maxdsiz="2548M" Вставить ник Quote
