-=DGN=- Posted March 15, 2008 Posted March 15, 2008 Машина с вистой не видит никого кроме себя в сетевом окружении. Как WINS сервер прописан сервер с SAMBA. W2K и XP самбу в сетевом окружении видят... Вторая самба была заменена на 3.0.28, проблема осталась. Если висте прописать напрямую шару как \\ip\share - то шары W2K и XP становятся видны, а самбовый ресурс хоть и появляется, но недоступен (выдается указанное сетевое имя недоступно). лог самбы =============================================================== [2008/03/15 15:41:35, 0] lib/util.c:smb_panic(1633) PANIC (pid 45015): internal error [2008/03/15 15:41:35, 0] lib/util.c:log_stack_trace(1787) unable to produce a stack trace on this platform [2008/03/15 15:41:35, 0] lib/fault.c:dump_core(181) dumping core in /var/log/samba/cores/smbd [2008/03/15 15:41:35, 2] smbd/sesssetup.c:setup_new_vc_session(1200) setup_new_vc_session: New VC == 0, if NT4.x compatible we would close all old resources. [2008/03/15 15:41:35, 2] lib/access.c:check_access(323) Allowed connection from (192.168.61.101) [2008/03/15 15:41:35, 2] smbd/connection.c:count_fn(111) pid 45015 doesn't exist - deleting connections 1 [home] [2008/03/15 15:41:35, 1] smbd/service.c:make_connection_snum(1033) 192.168.61.101 (192.168.61.101) connect to service home initially as user games (uid=7, gid=13) (pid 45016) [2008/03/15 15:41:35, 0] lib/fault.c:fault_report(41) =============================================================== [2008/03/15 15:41:35, 0] lib/fault.c:fault_report(42) INTERNAL ERROR: Signal 11 in pid 45016 (3.0.28) Please read the Trouble-Shooting section of the Samba3-HOWTO [2008/03/15 15:41:35, 0] lib/fault.c:fault_report(44) конфиг самбы #======================= Global Settings ==================================== [global] netbios name = fileserver workgroup = dgn server string = Media Server of DGN Home Network guest account = games smb passwd file = /usr/local/etc/samba/smbpasswd null passwords = yes log file = /var/log/samba/%m.log unix password sync = yes max log size = 10000 log level = 2 load printers = no interfaces = 192.168.61.96/28 192.168.61.64/27 security = share encrypt passwords = no announce version = 4.5 announce as = NT # socket options = TCP_NODELAY IPTOS_LOWDELAY SO_SNDBUF=65536 SO_RCVBUF=65536 max xmit = 65536 bind interfaces only = yes browse list = yes enhanced browsing = Yes local master = yes lm announce = Auto lm interval = 60 os level = 255 domain master = yes preferred master = yes name resolve order = wins wins support = yes preserve case = yes display charset = cp1251 unix charset = cp1251 dos charset = cp866 default case = upper preserve case = yes short preserve case = yes wide links = Yes domain logons = no protocol = NT1 max protocol = NT1 min protocol = NT1 max connections = 512 create mask = 0664 directory mode = 0775 map to guest = Bad Password #============================ Share Definitions ============================= [home] comment = Fileserver for All User path = /var/ftp/pub/ALL/ read only = yes public = yes hosts allow = All Вставить ник Quote
sfstudio Posted March 16, 2008 Posted March 16, 2008 оно? http://sadnet.ru/index.php?option=com_cont...5&Itemid=33 И настоятельно рекомендую в связке с говносвистой юзать 3.2.0preX версии самбы. Или 3.0.28а (именно а). Вставить ник Quote
-=DGN=- Posted March 17, 2008 Author Posted March 17, 2008 не оно! и 3.2 нет в портах freebsd 5.3... как апдейтить не знаю ;-( Вставить ник Quote
-=DGN=- Posted March 17, 2008 Author Posted March 17, 2008 поставил 3.0.28a - никакого эффекта... Вставить ник Quote
-=DGN=- Posted March 17, 2008 Author Posted March 17, 2008 прописав security = user добился чтоб виста подключалась к шарам. но видеть в сетевом окружении она их отказывается, подключается только по IP... где копать далее? Вставить ник Quote
