Здравствуйте всем
Пытаюсь собрать jtag под линуксом но всплывают две ошибки.В чём причина сообразить не могу.
Пакеты вроде бы все поставил.До этого собирал под винХР и CYGWIN на другом ноуте то работоло без проблем.
Вот все как происходит:
ur6cv@ubuntu:~/jtag$ sudo ./configure -with-include=/home/ur6cv/include
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether NLS is requested... yes
checking for msgfmt... no
checking for gmsgfmt... :
checking for xgettext... no
checking for msgmerge... no
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for shared library run path origin... done
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ANSI C... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for ranlib... ranlib
checking for the openwince includes... /home/ur6cv/include
checking for library containing ioperm... none rehttp://www.cqham.ru/quired
checking for getline... yes
checking for getdelim... yes
checking for swprintf... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking linux/ppdev.h usability... yes
checking linux/ppdev.h presence... yes
checking for linux/ppdev.h... yes
checking for a readline compatible library... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating doc/Makefile
config.status: creating data/Makefile
config.status: creating include/Makefile
config.status: creating src/Makefile
config.status: creating src/lib/Makefile
config.status: creating src/tap/Makefile
config.status: creating src/part/Makefile
config.status: creating src/bus/Makefile
config.status: creating src/cmd/Makefile
config.status: creating po/Makefile.in
config.status: creating config.h
config.status: config.h is unchangedur6cv@ubuntu:~/jtag$ make
make all-recursive
make[1]: Entering directory `/home/ur6cv/jtag'
Making all in libbrux
make[2]: Entering directory `/home/ur6cv/jtag/libbrux'
make all-recursive
make[3]: Entering directory `/home/ur6cv/jtag/libbrux'
Making all in po
make[4]: Entering directory `/home/ur6cv/jtag/libbrux/po'
make[4]: *** Нет правила для сборки цели `all'. Останов.
make[4]: Leaving directory `/home/ur6cv/jtag/libbrux/po'
make[3]: *** [all-recursive] Ошибка 1
make[3]: Leaving directory `/home/ur6cv/jtag/libbrux'
make[2]: *** [all] Ошибка 2
make[2]: Leaving directory `/home/ur6cv/jtag/libbrux'
make[1]: *** [all-recursive] Ошибка 1
make[1]: Leaving directory `/home/ur6cv/jtag'
make: *** [all] Ошибка 2
config.status: executing default-1 commands
config.status: executing depfiles commands
configure: configuring in libbrux
configure: running /bin/bash './configure' --prefix=/usr/local '-with-include=/home/ur6cv/include' --cache-file=/dev/null --srcdir=.
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
затем
make all-recursive
make all-recursive
Making all in po
Подскажите где моя ошибка?
Заранее спасибо.
