Привет всем!
Пытаюсь завести hostapd с 802.1x через драйвер wired
Ubuntu 7.10+Debian 4.0r0
Из репозиториев ли я ставлю hostapd или компилю из исходников разных версий, всё равно получаю
одно и то же
1) подключаю по схеме ( compex ps2208B или любой L2)
wired_eth <-----> hub <---------> client_eth
& получаю REAUTH_TIMER при любых методах авторизации |md5, peap or tls|
________________________________________________________________________________
_____________
Configuration file: /etc/hostapd/hostapd.conf.peapmschap
1204615804.443995: ctrl_interface_group=0
1204615804.447058: TLS: Trusted root certificate(s) loaded
Opening raw packet socket for ifindex 2
BSS count 1, BSSID mask ff:ff:ff:ff:ff:ff (0 bits)
1204615804.499185: eth0: IEEE 802.11 Fetching hardware channel/rate support not supported.
1204615804.499197: Flushing old station entries
1204615804.499200: Deauthenticate all stations
Using interface eth0 with hwaddr 00:13:8f:b7:54:8d and ssid 'test'
1204615804.499286: eth0: Setup of interface done.
Got DHCP broadcast packet from 00:00:f0:73:ad:7c
Data frame from unknown STA 00:00:f0:73:ad:7c - adding a new STA
New STA
1204615819.204563: eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: start authentication
1204615819.204569: EAP: State machine created
1204615819.204573: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state INITIALIZE
1204615819.204579: IEEE 802.1X: 00:00:f0:73:ad:7c BE_AUTH entering state INITIALIZE
1204615819.204582: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615819.204587: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_KEY_TX entering state NO_KEY_TRANSMIT
1204615819.204590: IEEE 802.1X: 00:00:f0:73:ad:7c KEY_RX entering state NO_KEY_RECEIVE
1204615819.204594: IEEE 802.1X: 00:00:f0:73:ad:7c CTRL_DIR entering state IN_OR_BOTH
1204615819.204598: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state INITIALIZE
1204615819.204601: IEEE 802.1X: 00:00:f0:73:ad:7c BE_AUTH entering state IDLE
1204615819.204604: IEEE 802.1X: 00:00:f0:73:ad:7c KEY_RX entering state NO_KEY_RECEIVE
1204615819.204607: IEEE 802.1X: 00:00:f0:73:ad:7c CTRL_DIR entering state FORCE_BOTH
1204615819.204610: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state INITIALIZE
1204615819.204613: IEEE 802.1X: 00:00:f0:73:ad:7c KEY_RX entering state NO_KEY_RECEIVE
1204615819.204628: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state DISCONNECTED
1204615819.204634: eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: unauthorizing port
1204615819.204637: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615819.204641: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state RESTART
IEEE 802.1X: Integrated EAP server in use - do not generate EAP-Request/Identity
1204615819.204644: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615819.204648: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615819.204654: EAP: EAP entering state INITIALIZE
1204615819.204657: EAP: EAP entering state SELECT_ACTION
1204615819.204660: EAP: getDecision: no identity known yet -> CONTINUE
1204615819.204662: EAP: EAP entering state PROPOSE_METHOD
1204615819.204665: EAP: getNextMethod: vendor 0 type 1
1204615819.204668: EAP: EAP entering state METHOD_REQUEST
1204615819.204672: EAP: building EAP-Request: Identifier 103
1204615819.204675: EAP: EAP entering state SEND_REQUEST
1204615819.204678: EAP: eapReqData -> EAPOL - hexdump(len=5): 01 67 00 05 01
1204615819.204684: EAP: EAP entering state IDLE
1204615819.204686: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state CONNECTING
1204615819.204690: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615819.204693: IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state AUTHENTICATING
1204615819.204696: IEEE 802.1X: 00:00:f0:73:ad:7c BE_AUTH entering state REQUEST
IEEE 802.1X: Sending EAP Packet to 00:00:f0:73:ad:7c (identifier 103)
1204615819.204711: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615819.204716: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615820.210136: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615821.210198: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615822.210261: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615823.210324: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615824.210387: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615825.220450: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615826.220513: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615827.220576: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615828.220639: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615859.222590: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615860.222653: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615861.222716: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615862.222778: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615863.222841: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615864.222904: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615865.222967: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615866.223030: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615867.223093: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615868.223156: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615869.223219: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615897.244982: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615898.245045: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615899.245108: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615900.245170: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
1204615901.245234: IEEE 802.1X: 00:00:f0:73:ad:7c REAUTH_TIMER entering state INITIALIZE
Signal 2 received - terminating
Removing station 00:00:f0:73:ad:7c
1204615901.457257: EAP: State machine removed
1204615901.457261: Flushing old station entries
1204615901.457264: Deauthenticate all stations
_____________
2) Но если подключаю напрямую, то все ок!
wired_eth <-----> client_eth |md5, peap or tls|
_____________
eapol_version=1
New STA
Received EAPOL packet
IEEE 802.1X: 46 bytes from 00:00:f0:73:ad:7c
IEEE 802.1X: version=1 type=1 length=0
ignoring 42 extra octets after IEEE 802.1X packet
eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: received EAPOL-Start from STA
IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state ABORTING
eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: aborting authentication
EAP: building EAP-Request: Identifier 198
EAP: eapReqData -> EAPOL - hexdump(len=5): 01 c6 00 05 01
IEEE 802.1X: Sending EAP Packet to 00:00:f0:73:ad:7c (identifier 198)
EAP: building EAP-Request: Identifier 105
EAP: eapReqData -> EAPOL - hexdump(len=5): 01 69 00 05 01
EAP: building EAP-Request: Identifier 115
EAP: eapReqData -> EAPOL - hexdump(len=5): 01 73 00 05 01
IEEE 802.1X: Sending EAP Packet to 00:00:f0:73:ad:7c (identifier 115)
IEEE 802.1X: version=1 type=0 length=6
ignoring 36 extra octets after IEEE 802.1X packet
EAP: code=2 identifier=115 length=6 (response)
eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: received EAP packet (code=2 id=115 len=6) from STA: EAP Response-Identity (1)
eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: STA identity '1'
IEEE 802.1X: 00:00:f0:73:ad:7c BE_AUTH entering state RESPONSE
EAP: EAP-Response received - hexdump(len=6): 02 73 00 06 01 31
EAP: EAP entering state RECEIVED
EAP: parseEapResp: rxResp=1 respId=115 respMethod=1 respVendor=0 respVendorMethod=0
EAP: EAP entering state INTEGRITY_CHECK
EAP: EAP entering state METHOD_RESPONSE
EAP-Identity: Peer identity - hexdump_ascii(len=1):
31 1
EAP: getDecision: another method available -> CONTINUE
EAP: getNextMethod: vendor 0 type 4
EAP: building EAP-Request: Identifier 116
EAP-MD5: Challenge - hexdump(len=16): ee 94 27 95 1a 37 93 ed a2 14 78 af e5 d5 f1 06
EAP: eapReqData -> EAPOL - hexdump(len=22): 01 74 00 16 04 10 ee 94 27 95 1a 37 93 ed a2 14 78 af e5 d5 f1 06
IEEE 802.1X: Sending EAP Packet to 00:00:f0:73:ad:7c (identifier 116)
IEEE 802.1X: version=1 type=0 length=23
ignoring 19 extra octets after IEEE 802.1X packet
EAP: code=2 identifier=116 length=23 (response)
eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: received EAP packet (code=2 id=116 len=23) from STA: EAP Response-MD5-Challenge (4)
EAP: EAP-Response received - hexdump(len=23): 02 74 00 17 04 10 da 3a 94 58 f0 b6 2b 43 9c 36 fe ad 85 74 7d 13 31
EAP: parseEapResp: rxResp=1 respId=116 respMethod=4 respVendor=0 respVendorMethod=0
EAP-MD5: Response - hexdump(len=16): da 3a 94 58 f0 b6 2b 43 9c 36 fe ad 85 74 7d 13
EAP-MD5: Done - Success
EAP: getDecision: method succeeded -> SUCCESS
EAP: EAP entering state SUCCESS
EAP: Building EAP-Success (id=116)
EAP: eapReqData -> EAPOL - hexdump(len=4): 03 74 00 04
IEEE 802.1X: 00:00:f0:73:ad:7c BE_AUTH entering state SUCCESS
IEEE 802.1X: 00:00:f0:73:ad:7c AUTH_PAE entering state AUTHENTICATED
eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: authorizing port
eth0: STA 00:00:f0:73:ad:7c IEEE 802.1X: authenticated - EAP type: 0 (Unknown)
_____________
Может кто знает решение этой проблемы
3) И ежё вопрос, возможно ли использование 802.1ч при такой схеме построения
client_eth <----> wired_eth <---VLAN_TARGED---->server_eth0.x |поднятый конец VLAN + hostapd на нём|
Please help!!!!
