нашел iperf, попробовал - работает
но у него нет возможности выставлять размер пакета ( шпарит максимальный) размер пакета и все тут, а хочется увидеть что будет на мелких.
Tuning a UDP connection
Iperf creates a constant bit rate UDP stream. This is a very artificial stream, similar to voice communication but not much else.
You will want to adjust the datagram size (-l) to the size your application uses.
The server detects UDP datagram loss by ID numbers in the datagrams. Usually a UDP datagram becomes several IP packets. Losing a single IP packet will lose the entire datagram. To measure packet loss instead of datagram loss, make the datagrams small enough to fit into a single packet, using the -l option. The default size of 1470 bytes works for ethernet. Out-of-order packets are also detected. (Out-of-order packets cause some ambiguity in the lost packet count; Iperf assumes they are not duplicate packets, so they are excluded from the lost packet count.) Since TCP does not report loss to the user, I find UDP tests helpful to see packet loss along a path.
Jitter calculations are continuously computed by the server, as specified by RTP in RFC 1889. The client records a 64 bit second/microsecond timestamp in the packet. The server computes the relative transit time as (server's receive time - client's send time). The client's and server's clocks do not need to be synchronized; any difference is subtracted out in the jitter calculation. Jitter is the smoothed mean of differences between consecutive transit times.
    node2> iperf -s -u -i 1
    Server listening on UDP port 5001
    Receiving 1470 byte datagrams
    UDP buffer size: 60.0 KByte (default)
    [  4] local <IP Addr node2> port 5001 connected with <IP Addr node1> port 9726
    [ ID] Interval       Transfer     Bandwidth       Jitter   Lost/Total Datagrams
    [  4]  0.0- 1.0 sec   1.3 MBytes  10.0 Mbits/sec  0.209 ms    1/  894 (0.11%)
    [  4]  1.0- 2.0 sec   1.3 MBytes  10.0 Mbits/sec  0.221 ms    0/  892 (0%)
    [  4]  2.0- 3.0 sec   1.3 MBytes  10.0 Mbits/sec  0.277 ms    0/  892 (0%)
    [  4]  3.0- 4.0 sec   1.3 MBytes  10.0 Mbits/sec  0.359 ms    0/  893 (0%)
    [  4]  4.0- 5.0 sec   1.3 MBytes  10.0 Mbits/sec  0.251 ms    0/  892 (0%)
    [  4]  5.0- 6.0 sec   1.3 MBytes  10.0 Mbits/sec  0.215 ms    0/  892 (0%)
    [  4]  6.0- 7.0 sec   1.3 MBytes  10.0 Mbits/sec  0.325 ms    0/  892 (0%)
    [  4]  7.0- 8.0 sec   1.3 MBytes  10.0 Mbits/sec  0.254 ms    0/  892 (0%)
    [  4]  8.0- 9.0 sec   1.3 MBytes  10.0 Mbits/sec  0.282 ms    0/  892 (0%)
    [  4]  0.0-10.0 sec  12.5 MBytes  10.0 Mbits/sec  0.243 ms    1/ 8922 (0.011%)
    node1> iperf -c node2 -u -b 10m
    Client connecting to node2, UDP port 5001
    Sending 1470 byte datagrams
    [  3] local <IP Addr node1> port 9726 connected with <IP Addr node2> port 5001
    [  3]  0.0-10.0 sec  12.5 MBytes  10.0 Mbits/sec
    [  3] Sent 8922 datagrams
Notice the higher jitter due to datagram reassembly when using larger 32 KB datagrams, each split into 23 packets of 1500 bytes. The higher datagram loss seen here may be due to the burstiness of the traffic, which is 23 back-to-back packets and then a long pause, rather than evenly spaced individual packets.
    node2> iperf -s -u -l 32k -w 128k -i 1
    Receiving 32768 byte datagrams
    UDP buffer size:  128 KByte
    [  3] local <IP Addr node2> port 5001 connected with <IP Addr node1> port 11303
    [  3]  0.0- 1.0 sec   1.3 MBytes  10.0 Mbits/sec  0.430 ms    0/   41 (0%)
    [  3]  1.0- 2.0 sec   1.1 MBytes   8.5 Mbits/sec  5.996 ms    6/   40 (15%)
    [  3]  2.0- 3.0 sec   1.2 MBytes   9.7 Mbits/sec  0.796 ms    1/   40 (2.5%)
    [  3]  3.0- 4.0 sec   1.2 MBytes  10.0 Mbits/sec  0.403 ms    0/   40 (0%)
    [  3]  4.0- 5.0 sec   1.2 MBytes  10.0 Mbits/sec  0.448 ms    0/   40 (0%)
    [  3]  5.0- 6.0 sec   1.2 MBytes  10.0 Mbits/sec  0.464 ms    0/   40 (0%)
    [  3]  6.0- 7.0 sec   1.2 MBytes  10.0 Mbits/sec  0.442 ms    0/   40 (0%)
    [  3]  7.0- 8.0 sec   1.2 MBytes  10.0 Mbits/sec  0.342 ms    0/   40 (0%)
    [  3]  8.0- 9.0 sec   1.2 MBytes  10.0 Mbits/sec  0.431 ms    0/   40 (0%)
    [  3]  9.0-10.0 sec   1.2 MBytes  10.0 Mbits/sec  0.407 ms    0/   40 (0%)
    [  3]  0.0-10.0 sec  12.3 MBytes   9.8 Mbits/sec  0.407 ms    7/  401 (1.7%)
    node1> iperf -c node2 -b 10m -l 32k -w 128k
    Sending 32768 byte datagrams
    [  3] local <IP Addr node2> port 11303 connected with <IP Addr node1> port 5001
    [  3] Sent 401 datagrams
Вы что-то не то читаете, наверное...
