Господа гуру,
подскажите как правильно сделать трансляцию чтоб хост 172.16.1.29 был доступен извне как 1.1.1.4, с учетом того что в сети 172.16.1.x есть свой дефолт гейт с аплинком на другого провайдера.
схемка сетки в аттаче.
Вот текущий конфиг:
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname c2851
boot-start-marker
boot-end-marker
enable secret 5 xxxDELETEDxxx
enable password xxxDELETEDxxx
aaa new-model
aaa authentication login default local
aaa authentication ppp default local group radius
aaa authorization exec default local
aaa authorization network default local group radius if-authenticated
aaa session-id common
ip cef
no ip domain lookup
ip domain name FOOBAR.COM
ip inspect name INSPEKTOR tcp
ip inspect name INSPEKTOR udp
ip inspect name INSPEKTOR icmp
ip inspect name INSPEKTOR pptp
ip inspect name INSPEKTOR smtp
ip inspect name INSPEKTOR ftp
ip inspect name INSPEKTOR cuseeme
ip inspect name INSPEKTOR dns
ip inspect name INSPEKTOR https
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip dhcp-server 10.0.0.2
multilink bundle-name authenticated
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
l2tp tunnel receive-window 1024
ip pmtu
ip mtu adjust
voice-card 0
no dspfarm
username xxxDELETEDxxx privilege 15 password 0 xxxDELETEDxxx
archive
log config
hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
track 1 rtr 1 reachability
delay down 10 up 30
interface GigabitEthernet0/0
description LAN1
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip policy route-map GEN-POLICY
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description TO_LAN2
ip address 172.16.1.3 255.255.255.224
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1/0
description UPLINK_ISP1
ip address 1.1.1.2 255.255.255.248
ip nat outside
ip inspect INSPEKTOR out
duplex auto
speed auto
interface FastEthernet0/3/0
description UPLINK_ISP2
ip address 2.2.2.2 255.255.255.252
ip access-group fw_in in
ip nat outside
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered GigabitEthernet0/0
ip nat inside
ip tcp adjust-mss 1400
autodetect encapsulation ppp
peer default ip address dhcp
no keepalive
compress mppc
ppp encrypt mppe auto
ppp authentication ms-chap-v2 callin
ppp timeout idle 600
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 1
ip route 0.0.0.0 0.0.0.0 2.2.2.1 50
ip route 192.168.193.0 255.255.255.0 10.0.0.254
ip route 192.168.200.0 255.255.255.0 10.0.0.254
ip route 192.168.212.0 255.255.255.0 172.16.1.2
no ip http server
no ip http secure-server
ip nat inside source route-map ISP1-NAT interface FastEthernet0/1/0 overload
ip nat inside source route-map NAT_TO_LAN2 interface GigabitEthernet0/1 overload
ip nat inside source route-map ISP2-NAT interface FastEthernet0/3/0 overload
ip nat inside source static tcp 10.0.0.2 20 2.2.2.2 20 extendable
ip nat inside source static tcp 10.0.0.2 21 2.2.2.2 21 extendable
ip nat inside source static tcp 10.0.0.5 25 2.2.2.2 25 extendable
ip nat inside source static tcp 10.0.0.7 443 2.2.2.2 443 extendable
ip nat inside source static tcp 10.0.0.2 20 1.1.1.3 20 extendable
ip nat inside source static tcp 10.0.0.2 21 1.1.1.3 21 extendable
ip nat inside source static tcp 10.0.0.5 25 1.1.1.3 25 extendable
ip nat inside source static tcp 10.0.0.7 443 1.1.1.3 443 extendable
ip nat inside source static tcp 172.16.1.29 21 1.1.1.4 21 extendable
ip access-list extended fw_in
permit gre any any
permit tcp any any established
deny ip 10.0.0.0 0.255.255.255 any
deny ip 172.16.0.0 0.15.255.255 any
deny ip 192.168.0.0 0.0.255.255 any
deny ip 127.0.0.0 0.255.255.255 any
permit tcp any host 2.2.2.2 eq 22
permit tcp any host 1.1.1.2 eq 22
permit tcp any host 2.2.2.2 eq 1723
permit tcp any host 1.1.1.2 eq 1723
permit tcp any host 2.2.2.2 eq smtp
permit tcp any host 2.2.2.2 eq 443
permit tcp any host 2.2.2.2 eq ftp
permit tcp any host 2.2.2.2 eq ftp-data
permit tcp any host 1.1.1.3 eq smtp
permit tcp any host 1.1.1.3 eq 443
permit tcp any host 1.1.1.3 eq ftp
permit tcp any host 1.1.1.3 eq ftp-data
permit tcp any host 1.1.1.4 eq ftp
permit tcp any host 1.1.1.4 eq ftp-data
deny ip any any
ip sla 1
icmp-echo 192.58.128.30 source-interface FastEthernet0/1/0
timeout 1000
threshold 3
frequency 10
ip sla schedule 1 life forever start-time now
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 172.16.1.0 0.0.0.255
access-list 2 permit 172.16.1.29
access-list 102 permit tcp any host some.outside.box.address eq 22
access-list 104 permit ip 10.0.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 104 permit ip 10.0.0.0 0.0.255.255 172.16.0.0 0.0.255.255
access-list 105 permit icmp any host 192.58.128.30 echo
access-list 106 permit ip any 172.16.1.0 0.0.0.255
access-list 107 permit tcp any host 1.1.1.4 eq ftp
route-map NAT_TO_LAN2 permit 10
match ip address 106
match interface GigabitEthernet0/1
route-map GEN-POLICY permit 5
match ip address 102
set ip next-hop 2.2.2.1
route-map GEN-POLICY permit 10
match ip address 105
set ip next-hop 1.1.1.1
route-map ISP2-NAT permit 10
match ip address 1
match interface FastEthernet0/3/0
route-map ISP1-NAT deny 5
match interface FastEthernet0/1/0
route-map ISP1-NAT deny 6
match ip address 103
route-map ISP1-NAT deny 7
match ip address 104
route-map ISP1-NAT permit 10
match ip address 1
radius-server configure-nas
radius-server host 10.0.0.5 auth-port 1645 acct-port 1646
radius-server key xxxDELETEDxxx
control-plane
line con 0
line aux 0
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
event manager applet ISP_SWITCHED
event track 1
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat trans forced"
end
Эт я читал ужо :) Нужно сделать две трансляции одновременно, 1 inside source и 1 outside source
Вопрос как сделать overload на один адрес при nat outside source? :)
