Приобрели у nag'a FastIron с таким модулем. Пришел с l2 прошивкой , прошивки b2rxxx саппорт прислал , пробуем залить.
FastIron 400 Switch#show version
  SW: Version 07.6.03bT51 Copyright (c) 1996-2003 Foundry Networks, Inc.
      Compiled on May 08 2003 at 22:03:22 labeled as B2S07603b
      (1858032 bytes) from Primary b2s07603b.bin
  HW: FastIron 400 Backbone, SYSIF version 21, Serial #: Non-exist
SL 2: J-FIxGMR4 JetCore Management Module, SYSIF 2 (Mini GBIC), ACTIVE
      Serial #:   CH19032654
4096 KB BRAM, JetCore ASIC IGC version 49, BIA version 89
32768 KB PRAM and 1M-Bit*1 CAM for IGC  4, version 0449
32768 KB PRAM and 1M-Bit*1 CAM for IGC  5, version 0449
Active management module:
  466 MHz Power PC processor 750 (version 8/8302) 66 MHz bus
  512 KB boot flash memory
16384 KB code flash memory
  256 KB SRAM
  256 MB DRAM
The system uptime is 18 minutes 1 seconds
The system : started=warm start   reloaded=by "reload"
FastIron 400 Switch#show flash
Code Flash Type: AMD 29LV033C, Size: 64 * 65536 = 4194304, Unit: 4
Boot Flash Type: AMD 29LV040B, Size: 8 * 65536 = 524288
Compressed Pri Code size = 1858032, Version 07.6.03bT51 (b2s07603b.bin)
Compressed Sec Code size = 1957092, Version 07.6.06kT51 (b2s07606k.bin)
Maximum Code Image Size Supported: 6815232 (0x0067fe00)
Boot Image size = 281376, Version 07.06.05 (M2B07605.bin)
Used Configuration Flash Size=172, Max Configuration Flash Size=524288.
При буте по tftp:
BOOT INFO: init modules .
BOOT INFO: set ip addr to 192.168.001.111, ip mask to 255.255.255.000
BOOT MONITOR> boot system tftp 192.168.1.7 b2r07800k.bin
BOOT INFO: try to boot thru tftp 192.168.001.007, b2r07800k.bin
BOOT INFO: tftp copy successful!
BOOT INFO: bootparam at 2fffffe0, mp_flash_size = 0037ea87
BOOT INFO: code decompression completed
BOOT INFO: start with hardware reset
BOOT INFO: branch to 20000104
Reset all modules ...
Init Management module 2 ...
Init JetCore ASIC 1.2.
ERR: You're loading Router Code which is not meant for a Switch
System Reset!
Во флешку (pri,sec) вообще не дает залить b2r , поэтому по tftp и бутаю - bootloader'у пофиг что грузить.
И такое с любыми b2r.. Может кто уже помучался? Может патченные есть || какой хитрый алгoритм действий для поднятия этого чуда до L3?
моудль у Вас с Basic L3 лицензией.
понимает софт только b2s и b2l
зы. вообще в первый раз вижу, что на JetCore не Full L3 лицензия может быть.
Edited by D^2
Мы тоже брали у NAGа, модуль пришел вот такой:
SW: Version 07.8.00kT53 Copyright © 1996-2004 Foundry Networks, Inc.
Compiled on Oct 04 2005 at 17:13:06 labeled as B2R07800k
(3664519 bytes) from Primary B2R07800k.bin
HW: FastIron 800 Router, SYSIF version 21, Serial #: Non-exist
SL 7: J-FIxGMR4 JetCore Management Module, SYSIF 2 (Mini GBIC), ACTIVE
Serial #: CH49027043
32768 KB PRAM and 1M-Bit*1 CAM for IGC 24, version 0449
32768 KB PRAM and 1M-Bit*1 CAM for IGC 25, version 0449
256 KB SRAM
256 MB DRAM
The system uptime is 77 days 16 hours 42 minutes 21 seconds
The system : started=cold start
Никаких проблем с ним нет, это самая новая прошивка от Foundry. Все, что надо на ней работает. Обновлять даже не пытались.
Edited by PowerPack
Видимо мне так повезло :(. А где интересно информация о типе лицензии хранится не в курсе? А то я уже начал потихоньку дизасмить это чудо , но может фигней занимаюсь и достаточно поправить eeprom'ку какую нибудь..
инфа находится в EEPROM, которая вставляется в панельку на самом модуле.
перестановка такого чипа с модуля Full L3 в модуль Basic L3 эффекта не дает.
  • 2 years later...
Апну старую тему. Ситуация примерно как у топикстартера. Есть шасси Foundry FastIron 800 и двухслотовый модуль с прошивкой B2R080001q.bin (boot M2B07605.bin)
При загрузке пишет:
master arbitrate : become primary arbitrator.
BOOT INFO: Become active CPU module
M2 BI Boot Code Version 07.06.05
Enter 'b' to go to boot monitor ...
BOOT INFO: load from primary copy
BOOT INFO: bootparam at 2fffffe0, mp_flash_size = 003ad91b
Init Management module 1 ...
System Reset!
Однако если этот модуль вставить в Foundry FastIron 400 то он прекрасно загружается и работает как Full L3.
Как заставить работать этот модуль в другом шасси??
Edited by xcme
Никак. Сами года полтора назад перепробовали массу вариантов и не смогли заставить модуль работать в 8ми слотовом шасси.
Edited by nashvill
Вам попалось такое шасси которое не поддерживает Full L3 модули JetCore. Тоже есть такие в руках - не знаем что с ними делать.
