Подскажите что делать.
Есть сервер - на нем поднято pptp, используется mppe и mschapV2.
Есть Di-604 (заведомо исправный)на нем пытаюсь настроить подключение по pptp (прошивки пробывал разные)
логи Di-604 (время не выставлено)
Monday August 20, 2007 00:26:08 LCP1: terminate request
Monday August 20, 2007 00:26:09 PPP1: TX(0) LCP Request
Monday August 20, 2007 00:26:11 PPP1: TX(1) LCP Request
Monday August 20, 2007 00:26:11 PPTP:error=-200
Monday August 20, 2007 00:26:12 PPP1: TX(2) LCP Request
Monday August 20, 2007 00:26:13 PPP1: TX(3) LCP Request
Monday August 20, 2007 00:26:14 PPP1: TX(4) LCP Request
Monday August 20, 2007 00:26:16 PPP1: TX(5) LCP Request
Monday August 20, 2007 00:26:16 PPP1: closed
на стороне сервера
Feb 9 15:32:43 ns ppp[28922]: Phase: Using interface: tun5
Feb 9 15:32:43 ns ppp[28922]: Phase: deflink: Created in closed state
Feb 9 15:32:43 ns ppp[28922]: Phase: Listening at port 3005.
Feb 9 15:32:43 ns ppp[28922]: Phase: PPP Started (direct mode).
Feb 9 15:32:43 ns ppp[28922]: Phase: bundle: Establish
Feb 9 15:32:43 ns ppp[28922]: Phase: deflink: closed -> opening
Feb 9 15:32:43 ns ppp[28922]: Phase: deflink: Connected!
Feb 9 15:32:43 ns ppp[28922]: Phase: deflink: opening -> carrier
Feb 9 15:32:43 ns ppp[28922]: Phase: deflink: carrier -> lcp
Feb 9 15:32:45 ns ppp[28922]: Phase: deflink: Too many LCP REQs sent - abandoning negotiation
Feb 9 15:32:45 ns ppp[28922]: Phase: deflink: Disconnected!
Feb 9 15:32:45 ns ppp[28922]: Phase: deflink: Connect time: 2 secs: 416 octets in, 1001 octets out, Local: 0 0
Feb 9 15:32:45 ns ppp[28922]: Phase: deflink: 16 packets in, 17 packets out
Feb 9 15:32:45 ns ppp[28922]: Phase: total 708 bytes/sec, peak 0 bytes/sec on Sat Feb 9 15:32:43 2008
Feb 9 15:32:45 ns ppp[28922]: Phase: deflink: lcp -> closed
В тех же условиях planet XRT-401D работает нормально
Допускаю что проблемы могут быть и на стороне сервера.
Где то читал что Длинк не поддерживает mppe - пробывал отключить - результат тотже.
Как победить данную ситуацию.
Заранее благодарен
Edited by kaats
Д-линк вообще очень плохо работает с РРТР. 604-ый чуть лучше, но тоже очень хреново (подсоединяется через раз, не пересоединяется при разрыве). Рекомендую взять Acorp WR-G (ни в коем случае не ПЛЮС) и обновить прошивку. Либо Асус.....перепрошивать тоже придется. Устройств такого типа работающих с заводской прошивкой по РРТР без проблем я лично еще не встречал.
Еще. Поддержка у Д-линка отстойная. Обращался по проблеме 604-го, даже звонил(в ответ: "Опишите проблему в письме", ответа нет), динамо полное.
Edited by muller
muller, то вы ей пользоваться не умеете ;) мне почему то длинк в течении нескольких часов отвечает.... Правда у меня железо немного посерьезнее....
На стороне сервера mppe и mschap-v2 отключите - длинк соединится...
Спасибо за советы.
Не охота отключать mppe и mschap-v2....
Погляжу в сторону других устройств и в торону дополнительного сервера без mschap.
Спасибо
необязательными - это как? пример конфига. Я рабочий пример искал долго. В результате поднял отдельный сервер без mppe. А на основном mppe обязателен потому, что так по умолчанию настроена винда. Я хочу минимизировать клиентские настройки.. Если создать впн - это достаточно просто, а вот потом лазить по галочкам и выключать шифрование....
Поделитесь опытом,конфигом.
Это бы решило многое - как сделать их не обязательными?
Подскажите как настроить еще один pptp сервер с другими параметрами соединения на том же компьютере.
Можно ли это сделать одним ppp.conf для обоих?
Хотя бы "направление движения".
Edited by kaats
на одной машине мне это сделать не удалось. Все равно я шел к разделению vpn серверов на несколько машин, поэтому просто на один сервер больше поставили ;)
