okulski Posted January 26, 2008 Posted January 26, 2008 народ собрал кабель виглер без буфера глюкаво работал на моём атлоне потом перестал тыкал его на 3х буках на 2х не работал на 1 (чужом) работал идеально чё может быть за глюконафтика? вчера воткнул на работе в обычную машину тоже прекрасно работает с 2100й и вопрос номер 2 с 7100 точкой выдаёт такой гон куда копать? или мож софт подскажите другой? jtag> include athsw Initializing Macraigor Wiggler JTAG Cable on parallel port at 0x378 IR length: 5 Chain length: 1 Device Id: 00000000000000000000000000000001 Manufacturer: Atheros Part: ar2312 Stepping: 1 Filename: /usr/local/share/jtag/atheros/ar2312/ar2312 ImpCode=01000000010000000100000000000000 EJTAG version: 2.6 EJTAG Implementation flags: R4k ASID_8 NoDMA MIPS32 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ImpCode=01000000010000000100000000000000 EJTAG version: 2.6 EJTAG Implementation flags: R4k ASID_8 NoDMA MIPS32 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 dev ID=0000 man ID=0000 Using CFI flash chip detection, not jedec ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 ejtag.c(139) No processor access, ctrl=00000000000000000000000000000001 Flash not found! No. Manufacturer Part Stepping Instruction Register --------------------------------------------------------------------------------------------- 0 Atheros ar2312 1 EJTAG_CONTROL EJCONTROL Active bus: *0: EJTAG compatible bus driver via PrAcc (JTAG part No. 0) start: 0x00000000, length: 0x20000000, data width: 8 bit start: 0x20000000, length: 0x20000000, data width: 16 bit start: 0x40000000, length: 0x20000000, data width: 32 bit Вставить ник Quote
RAW Posted January 30, 2008 Posted January 30, 2008 Собирай нормальный JTAG кабель и будет тебе счастье. Вставить ник Quote
okulski Posted January 31, 2008 Author Posted January 31, 2008 Собирай нормальный JTAG кабель и будет тебе счастье.не умничай, а конкретно скажи чего не так! этот с 2100 на ура работает а вот 7100 надух не переносит. какую схему (какой вариант) или какой обвесухи не хватает (буферная микруха нужна?) или софт этот корявый? Вставить ник Quote
PitBeast Posted January 31, 2008 Posted January 31, 2008 dlc5 не пробовал? Он попроще вигглера будет. Это добрище покажи: athsw Вставить ник Quote
tchern Posted January 31, 2008 Posted January 31, 2008 Собирай нормальный JTAG кабель и будет тебе счастье.не умничай, а конкретно скажи чего не так! этот с 2100 на ура работает а вот 7100 надух не переносит. какую схему (какой вариант) или какой обвесухи не хватает (буферная микруха нужна?) или софт этот корявый? для 7100 cable parallel 0x378 WIGGLER detect include atheros/ar2312/ar2312 poke 0x58400000 0x100e3ce1 (если 0x000e3ce1 будут повторяться байты) detectflash 0x3fc00000 (0x1fc00000 не работает) readmem 0x3fc00000 0x400000 ar5312-flash.bin Вставить ник Quote
okulski Posted February 15, 2008 Author Posted February 15, 2008 для 7100 cable parallel 0x378 WIGGLER detect include atheros/ar2312/ar2312 poke 0x58400000 0x100e3ce1 (если 0x000e3ce1 будут повторяться байты) detectflash 0x3fc00000 (0x1fc00000 не работает) readmem 0x3fc00000 0x400000 ar5312-flash.bin дельный ответ гут завтра попробую я так понял можно просто скопировать athsw в athsw7100 и там переправить нужные строчки Вставить ник Quote
