Схема
ISDN->cisco5350->mcca(IVR)
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice modem
isdn send-alerting
no isdn gtd
no cdp enable
dial-peer voice 2 pots
huntstop
incoming called-number 47001
no digit-strip
direct-inward-dial
port 1/0:D
forward-digits all
dial-peer voice 20 voip
tone ringback alert-no-PI
destination-pattern 47001
session target ipv4:192.168.128.82
dtmf-relay h245-alphanumeric
*Dec 14 14:02:02.680: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0015
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838D
Preferred, Channel 13
Progress Ind i = 0x8A83 - Origination address is non-ISDN
Calling Party Number i = 0x0183, '830xxxxxxx'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '47001'
*Dec 14 14:02:02.692: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8015
Channel ID i = 0xA9838D
Exclusive, Channel 13
*Dec 14 14:02:02.784: ISDN Se1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8015
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Dec 14 14:02:02.784: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8015
*Dec 14 14:02:02.808: ISDN Se1/0:15 Q931: RX <- STATUS pd = 8 callref = 0x0015
Cause i = 0x82E41E - Invalid information element contents
Call State i = 0x07
*Dec 14 14:02:02.808: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8015
Cause i = 0x80E5 - Message not compatible with call state
*Dec 14 14:02:02.812: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0015
*Dec 14 14:02:02.812: ISDN Se1/0:15 **ERROR**: Ux_BadMsg: Invalid Message for call state 19, call id 0x1E2, call ref 0x8015, event 0xF
*Dec 14 14:02:02.812: ISDN Se1/0:15 Q931: TX -> STATUS pd = 8 callref = 0x8015
Cause i = 0x80E20F - Message not compatible with call state or not implemented
Call State i = 0x13
*Dec 14 14:02:02.840: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0015
Звонок сбрасывается... Но если делать через донабор, то всё нормально...
Что недоуказал ? Цель, на телефон 47001 сразу перебросить звонок на mcca, которая по адресу 192.168.128.82
