Есть два адпака, AP1100F и AP190. Первый в офисе, второй на очень удаленной площадке.
Вопрос заключается в следующем - почему с AP1100F на AP190 звонок проходит идеально, а обратно 99 из 100
идет обрыв
1048 <H245> : Control channel closed
H323SignalPDU::read - atiDecode Err()
Q931 PDU UUIE Decode Error
Версии:
AP-1100F:
VoiceFinder Gateway Series (AP1100F)
Serial Number: AP1100F-046460
32BIT RISC Processor With 50MHz Clock
32 Mbytes System Memory.
512 Kbytes System Boot Flash Memory
4 Mbytes System Flash Memory
Real-Time Clock Device with EEPROM
1 RS232 Serial Console Interface
1 Ethernet/IEEE 802.3 Interface (100BaseTX)
1 Ethernet/IEEE 802.3 Interface (10BaseT)
AP1100F System software Revision 8.23K
Released at Tue Apr 24 16:41:54 2007
Program is 2967632 bytes, checksum is 0x1782915d
AP-190:
VoiceFinder Gateway Series (AP190)
Serial Number: AP190-03d326
32BIT RISC Processor With 133MHz Clock
16 Mbytes System Memory.
2 Mbytes System Flash Memory
2 Ethernet/IEEE 802.3 Interface (100BaseTX)
AP190 System software Revision 8.238
Released at Wed Feb 1 21:42:00 2006
Program is 1572240 bytes, checksum is 0xc4c2146
Конфиги:
AP-1100F:
interface ether0.0
ip address XXX.XXX.XXX.XXX ZZZ.ZZZ.ZZZ.ZZZ
voice service voip
fax protocol t38 redundancy 0
fax rate 9600
h323 call start fast
h323 call tunnel enable
! Voice port configuration.
! FXO
voice-port 0/0
connection plar 357
description Chert-i-Gde#357
no caller-id enable
! Pots peer configuration.
dial-peer voice 10 pots
destination-pattern 9357
port 0/0
! Voip peer configuration.
dial-peer voice 100 voip
destination-pattern 357
session target YYY.YYY.YYY.YYY
dtmf-relay h245-alphanumeric
vad
gatekeeper
! Gateway configuration.
gateway
h323-id voip.XXX.XXX.XXX.XXX
no ignore-msg-from-other-gk
! SIP UA configuration.
sip-ua
! MGCP configuration.
mgcp
codec g711ulaw
vad
AP-190:
interface ether0.0
ip address YYY.YYY.YYY.YYY ZZZ.ZZZ.ZZZ.ZZZ
qos-control 200 100
! VoIP configuration.
! Voice service voip configuration.
voice service voip
fax rate 9600
! FXS
voice-port 0/0
connection plar 9357
port 0/0
session target XXX.XXX.XXX.XXX
gateway
h323-id voip.YYY.YYY.YYY.YYY
mgcp
codec g711ulaw
vad
Дебаг:
AP-1100F:
200 <Call> : ****************** Call Created status(InitiatedByNet) *******************
201 <NetCon> : Found inbound voip peer by dest-pattern id(100)
202 <H323> : local capabilities.
number of capabilities = 4
1 : g711alaw-64k
2 : T.38
3 : UserInput/basicString
4 : UserInput/hookflash
203 <H225> : Remote Endpoint (AddPac VoIP,8.23,97,0,22)
204 <Q931> : Received SETUP from (YYY.YYY.YYY.YYY) : FastStart(0) Tunneling(0)
205 <Call> : From Net - calledParty(9357) callingParty(357)
206 <Call> : MatchedPerfect
207 <Call> : MatchAllProcess After Sorted <0> id(10) dest(9357) prefer(0) selected(52)
208 <Call> : Initiate callee with dial-peer(9357) status(CalleeDeterminedAll) id(3d313347-4d23-b9a2-8045-0002a403d326)
209 <CEP> : InitiateOutCall : calledNum(), callingNum(357), callerPort(ffffffff) type(FXO)
210 <CEP> : Outbound call to CEP callId(3d313347-4d23-b9a2-8045-0002a403d326) callNum(245)
211 <Q931> : Send CALL PROCEEDING
212 <Q931> : build PROGRESS (with h245 address)
213 <Q931> : Send ALERTING/PROGRESS
214 <Call> : Connected from(0)
215 <Q931> : Send CONNECT
216 <Q931> : startH245(forced with Facility)
217 <Q931> : Send FACILITY
218 <H245> : Send TCS request.
219 <H245> : Send MSD request.
220 <H245> : Control channel closed
221 <Q931> : Received RELEASE COMPLETE
222 <Call> : Terminated from(ffffffff) this(Remote:Unknown) before(NULL) forced(0)
223 <CEP> : DisconnectCall at Busy
224 <CEP> : StopSignal
225 <CEP> : Disconnect (0)
226 <NetEP> : Call FROM <voip> terminated reason(Remote:Unknown)
227 <CEP> : Disconnected(16) at Disconnecting
AP-190:
1026 <CEP> : Call Received
1027 <CEP> : Call Initiated : calledNumber() crv(0) total(0)
1028 <Call> : ****************** Call Created status(InitiatedByFXS) *******************
1029 <CEP> : Calling number(357)
1030 <CEP> : Call id(3d313347-4d23-b9a2-8045-02a43d326) callNum(46)
1031 <Call> : MatchAllProcess After Sorted <0> id(100) dest(9357) prefer(0) selected(34)
1032 <Call> : Initiate callee with dial-peer(9357) status(CalleeDeterminedAll) id(3d313347-4d23-b9a2-8045-02a43d326)
1033 <NetEP> : InitiateOutCall: calledNum(9357) callingNum(357) target(XXX.XXX.XXX.XXX)
1034 <NetEP> : DoCall: calledAddr(9357@XXX.XXX.XXX.XXX) callingAddr(357)
1035 <H323> : local capabilities.
1 : g729-8k
2 : T.38
1036 <H225> : Try signalling TCP connect (XXX.XXX.XXX.XXX:1720)
1037 <H225> : Signalling TCP connect success (46)
1038 <Q931> : Send SETUP
1039 <Q931> : Received CALL PROCEEDING
1040 <Q931> : Received CALL PROCEEDING
1041 <Q931> : Received PROGRESS
1042 <Q931> : Received Progress Indicator : desc(8), coding(0), location(0)
1043 <H245> : Send TCS request.
1044 <H245> : Send MSD request.
1045 <Call> : Progress from(ffffffff)
1046 <Q931> : Received CONNECT
1047 <H225> : Remote Endpoint (AddPac VoIP,8.23,97,0,22)
1049 <Q931> : Received FACILITY
1050 <Q931> : Received RELEASE COMPLETE
1051 <Call> : Terminated from(ffffffff) this(Remote:Unknown) before(NULL) forced(0)
1052 <CEP> : DisconnectCall at Busy
1053 <CEP> : StopSignal
1054 <CEP> : Disconnect (0)
1055 <NetEP> : Call TO <voip> terminated reason(Remote:Unknown)
1056 <CEP> : Disconnected(16) at Disconnecting
Я конечно не спец в Адпаках и эксплуатацией не занимаюсь...
Но поверхностно вижу что в Q931 в одной коробке и в другой разные тоесть гдето есть лишнии биты в сообщениях, илинет того что надо. А прошивку подновить не пробовали ?
Мне интересно как у вас AddPac'и собираются догадаться о том какой кодек использовать?
Edited by facility
